Question about Vacuums
Bissell Quicksteamer Powerbrush, modele 2080 leaking water from Clean water tank. I think ther's missing gasket on tank's cap.
  • 7dogmama Apr 12, 2009
    I ordered the new cap and it is still leaking, what else could be the problem?
    President:
  • 1,673 Answers
There is a gasket on the cap, part #2035541 , gasket will come with the new cap.
Posted on Aug 10, 2008
Bissell proheat 2x 9500e leaking water
Hello, this is Ava with Think Crucial.
First, make sure that the caps are on securely and the red rubber auto-load gaskets are in place. If the red rubber auto-load gasket is missing, check to see if it's stuck in the reservoir. Next, check the tanks for cracks or damage. If there is damage then you may need to replace it. If your gaskets are correctly assembled and your tanks don't seem to be damaged, at this point it might be best to take your carpet cleaner to a technician. You can call Bissell at 1-800-237-7691 for authorize service center near your area.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=bissell
Ava B.
Think Crucial Customer Care
Jun 22, 2016 | Bissell 9500 ProHeat 2X CleanShot Upright...
When cleaning bissell quicksteamer powerhouse model #2080. I took the dirty water tank off and cleaned it out, I removed The brush, cleaned it & put it back together and now it will not turn on...
It sounds like you didn't get the drive belt seated properly. If that's not it than try the Bissell Consumer Care number is 1-800-237-7691 they have a better troubleshooter guide than I do.
Nov 28, 2015 | Bissell Vacuums
I need to repair my bissell quick steam cleaner
hi , the motors in these units are screwed in the base of the system and have a pulley that spins the roller brush. take the side cap off and check to see if the belt is off the pulley, if so i would make it perform as if something is loose. good luck
May 09, 2015 | Bissell Quicksteamer Powerbrush...
Can i use this machine to do laminate floors
no not recomendid it will scratch all the laminate
Feb 06, 2013 | Unknown Bissell 2080-3 Bissell...
I have a Bissell Quicksteamer plus model # 1950 and when I plug it in it begins to heat the water then trips the circuit. Can this issue be corrected?
Have you cleaned the tanks recently? If not do it.
Remove water from the solution tank and collection tank.
Keep the tanks open and allow to dry in sunlight.
If you can, remove the solution tank and see whether there are any leakage signs where the tube connects to the solution tank. If there are, use an adhesive that can withstand heat and stops the leak.
You can also contact Bissell consumer service on 1-800-237-7691.
Aug 07, 2011 | Bissell 1960-3 QuickSteamer Plus Upright...
I recently bought a model number 2080 3 Bissel quicksteamer powerbrush multi-surface cleaner. I cannot find the instruction manual and I am very frustrated as I need some information NOW!!!!
Here is your manual:
http://www.bissell.com/DownloadAsset.aspx?id=561
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 09, 2011 | Bissell Vacuums
Where can i order a quicksteamer plus 1950 clean water tank?
I had a look at the Australian variant of this model and located parts number 407-0931 Clean Water Tank.
My best suggestion is that take this part number and contact your local Bissell Service Center, go to the Bissell International website to locate information for your country.
May 26, 2010 | Bissell 1950-3 Quicksteamer Plus Vacuum
How to fill the clean water tank???
The clean water tank cap is two-part. Unscrew the threaded ring and then pull out the center piece. There is a rubber gasket around the center piece, so it may take light force to remove it. Fill the tank with solution to the "solution" line, and fill with hot water to the "water" line. Cheers.
Jun 21, 2008 | Bissell 1770 Quicksteamer II Upright...
Bissell 1770 Quicksteamer ii
Is the front nozzle fitted correctly, Is the tank seated correctly,
On the dirty water tank there is a sponge filter make sure this is clesn,
Nov 19, 2007 | Bissell 1770 Quicksteamer II Upright...
Vacuums Logo
619 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
