Question about Kitchen Appliances - Others
Basement up flush tiliet.
Emerson motor # 22922. pump an motor assembley modle# K48ZZDEG-1844.the name of the unit is Zoeller. I need to know how to get pump an motor dissembled, the motor runs if you spin it, i need to get inside to check motor switch or capacitor.thank you.
    Scholar:
  • 68 Answers
Is this a grinder pump with float switch? Or is it built into toilet sump?
First in either case if you can identify the capacitor, get one and replace it, they wear out over time anyway. If that fixes it, you are done the easy way.
Many of these type motors are throw aways, and finding the switch, let alone getting it apart and replacing it is more trouble than buying a new motor if available.
If you are plumbed in, and have no other choice but major construction to replace an up toilet, we can attempt a repair at our shop, if that is against the rules here, sorry, but I know what a complicated and near impossible fix this might be, sometimes the motors are riveted together, so if you need help and want to mail it to me for an estimate, we are happy to take a quick look.
wbwill@sbcglobal.net
Will
Posted on Sep 16, 2008
I need the through bolts for the wet end of a emerson R63 mwena 4727 pump
I do not believe that thru bolts have a part number? Which means, they are something you can not purchase separately?
But...
Try an electric motor shop in your area. They may have some junk motors laying around?
Or...
Try a pool and spa repair service company in your area, they too may have junk motors laying around, that they can remove the thru bolts from. I know I have many of them in my junk pile.
And by the way... Emerson does not make a Pump! They just manufacture the Motor as a third party vendor to a pump manufacturer. To know the type of thru bolt, we will need the name and model of the PUMP.
Apr 29, 2015 | Emerson Pool & Spa
Zoeller m267-f pump has power going to the motor but will nut run
Does it have a float switch? Does the motor run when you lift the float switch? If not... then the motor's gone.
Jul 23, 2014 | Zoeller Sump Pump with 25 foot cord 2" 1/2...
BACK UP BATTERY FOR MY SUMP PUMP KEEPS BEEPING. I HIT THE RE-SET BUTTON TURNS OFF BUT COMES BACK ON WHEN THE PUMP KICKS ON. THE PUMP DOES SOUND DIFFERENT NOW THAN A FEW DAYS AGO. NOT SURE IF THE BATTERY...
Replace the battery first. It is cheaper than a whole pump. The battery is constantly being charged and will go bad after time even though it does not get used.
Dec 16, 2013 | Zoeller 507-0005 Basement Sentry Battery...
507 new back-up battery, pump does not function
yes or c.breaker, try to test the terminal voltage to the motor-pump, if there are voltage the pump-motor is faulty. Otherwise, test the adapater+battery, fuse or c.brekaer or main switch, and ANY LOOSE wires or connector. However they have some RELAIS, see if the relais is coming ON, and try to clean the contacts with contacts cleaner. Look for some small switch, if there are close or open test with the multimeter for continuity.
God bless you
Nov 06, 2013 | Zoeller 507-0005 Basement Sentry Battery...
Charging light continuous blinking while green charging light is on.
Check your manual it could be either battery burn out and overcharge indication.
Sep 02, 2013 | Zoeller 507-0005 Basement Sentry Battery...
Thinking about installing basement Saniflo toilet
Zoeller makes the best unit out there do you research first
Nov 15, 2009 | Saniflo 013/003/005 Sanibest Toilet with...
What is the maintenance for a zoeller extractor pump?Should it be serviced so there won't be a problem?
There really is no maintenance for a Zoeller submersible pump. When these fail it is typically the switch or the motor itself. If it is a smaller unit 1/2HP to 10HP I consider the pump trash if it is the motor that does fail. Yes they may be rebuilt but when compared to the cost of a replacement it can be hard to justify, especially when a new unit will give you a warranty.
I hope this may have helped,
Tom
Sep 23, 2009 | Plumbing
Water backing up into my basement ejector pump during heavy rain
I have seen this problem several times before. The ejector pump should be in a separate crock in the ground by itself. Someone has installed it in the crock that is meant to pump out drain water. Probably the result of adding a bathroom in the basement. You need to bust another hole in the floor and install a separate crock to solve this problem correctly. If it just started happening go outside and look at he gutters to make sure water is running away from the house and not up against the foundation.
Please rate if this helps-
Mar 24, 2009 | Zoeller E282 Nonautomatic Waste-Mate
Kitchen Appliances - Others Logo
171 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
