Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Aquarus 1200 hotpoint motor not working
Motor belt is intact and water extraction and exhaust is perfectly fine the only probelm is that the drum in not rotating, seems that something wrong with mototr.
First make sure the plug into the motor hasn't worked loose.
Posted on Mar 12, 2010
  • 3 Answers
Check the motor brushes for wear.
Replacement carbon mototr brushes available at :
www.hotpointspares2u.co.uk
Regards
Steve - SDA Ltd
Posted on Aug 17, 2008
Hotpoint 1200 wd62n banging noise when loaded but ok when its empty ?
There are many reasons that this could be noisy...
When you turn the drum (quickly) when it's empty does it rumble? Bearings, drum support or motor bearings.
If it sounds like a pneumatic drill when filled and spinning it could be drum support, bearings, balance weight or suspension.
These are not an exhaustive list but the usual suspects.
Jun 02, 2014 | Hotpoint Aquarius WMA42 Front Load Washer
Spinning drum
yes it does have belt can you turn drum in side by hand if yes and belt hasent broke must have come of pully belt should be tight on drum
Sep 13, 2013 | Hotpoint TDC32 Electric Dryer
The drum of the dryer does not turn.
Remove the top panel of the dryer and confirm whether or not the belt is tight on the drum. You can also remove the panel near the exhaust to observe the motor. If the belt is intact, the motor is most likely at fault.
Oct 27, 2010 | Kenmore 63942 Dryer
Dryer works but drum will not go round also the belt is perfect so it is not that
is the belt a good tight fit on the drum??? is the motor turning? can you turn the drum by hand? if you cant turn the drum by hand its likley to be drum bearings stuck up or sezed up motor?
Aug 08, 2010 | Hotpoint Dryers
Hotpoint dryer was moved, now only clicks, won't start
Rough handling may have the drum belt to get binded. Try turning the drum by hand to see if it turns free or is locked. This may align the belt to the motor or may just take off the belt altogether from the motor. You will have to get inside access to see whats up. Once inside realign the belt to the motor and pulley assembly. Then CHECK ALSO that no wire connections inside came apart during moving. Good luck
Jul 10, 2010 | Hotpoint NLL113EYWO Electric Dryer
Hotpoint wms38 1200 spin motor question
Hi.
Unfortunately, you cannot fit new bearings to the motor.
Your only option is to replace the complete motor.
Jan 05, 2010 | Washing Machines
The drum wont spin on my Hotpoint CTD00 dryer
Remove top cover, and see if the belt is intact, if it is then it could be the motor is not working for one reason or another, this would entail further investigation.
Please rate my solution.
Thanks.
Nov 04, 2009 | Hotpoint Dryers
WMA54 Hotpoint Aquarius drum does not turn during wash or spin
If the machine pumps water inside but does not start :
Start checking the lid switch, if this is stuck the machine wont start.
If the drum does not move at all, the motor, the motor control unit, the motor coupler, the control board may be faulty.
For more details , see: It doesn't spin
See also a general diagram here: redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Jan 06, 2009 | Hotpoint WMA30 Front Load Washer
For more details you need to observe if machine is draining and pumping water inside during cycle, see: It doesn't spin
Jan 06, 2009 | Hotpoint WMA54 Front Load Washer
Condensing tumble dryer not running
has the belt shredded and wrapped itself around the shaft? try to manually rotate the drum to see if the belt is free and the motor shaft moves. it sounds like the motor is stuck and the smell is the uncirculated heat at the back. let me know your results.
taking the lid off will gain access.
Feb 16, 2008 | Dryers
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
78 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
