MAXIM 26 INCH LCD TV, FAULT: TURNED OF ONE DAY, AND NOW THE RED LIGHT ( WHEN ON STANDBY STAYS RED ) AND NOW WHEN TURNING ON NOTHING ON THE SCREEN BUT THE RED LIGHT BLINKS AROUND 12 TIMES THE SCREEN FLICKERS AND THEN THE CYCLE STARTS AGAIN BLINKING... FLICKERS, WHEN THIS HAPPENED FOR THE FIRST TIME I SMELT A LITTLE BURNING... PLEASE HELP ! IF I OPEN IT UP I MAY BE ABLE TO SEE SOME DAMAGE IF ANY I NO WHERE THE DISTINCT SMELL COME FROM SOMEWHERE FROM THE TOP CENTRE WHERE THE ON BUTTON IS AND THE RED LIGHT...
  • 1 more comment
  • rizy Aug 11, 2008
    Where would the main power be? inside the tv or the main plug? I did open up the tv and i didnt really find anything except a little dust which smelt similer to the smell when the tv went bust should i examine that a little further? ,
  • rizy Aug 11, 2008
    I have inspected the tv there are no bad solder points, no damage no
    burn marks at all everything seems perfect i actually took everything
    apart inspected the pcd boards, put it alback together and stil the
    same problem !
  • bbiillllyy Dec 02, 2008
    hi i have the same problem red light blink then the screem flickers repeats over and over again turn power light off light back telly flashes like there s power going thought but not power up the screem
    any idears
    wood be greatfull
    Problem Solver:
  • 17 Answers
THE MAIN POWER IS BAD ,TRY LOOK FOR ANY CONDENSER BAD SOLDERING
Posted on Aug 10, 2008
  • alexis valdivia Aug 11, 2008
    you need look all pcb ,you have a soldering bad,you need look for the filter around of radiador of hot,will have a bad soldering.
Light on beko lcd tv goes from red to green and back to red without coming on
Main board fault. Shorted component/s on this board. Contact any service technician. This is not a user repairable fault. Gopakumar Gopalan Google
Mar 05, 2014 | Beko 17WLB450S 17 in. LCD TV
Tv stuck on standby
The internal power supply may have failed.
Nov 04, 2013 | Televison & Video
Hi i own a 26 inch Didgatrax tv model cfd2685....
suggest you take it to a repair shop for a repair estimate. normally done free if you decide to have them fix it .
Sep 07, 2017 | Televison & Video
My TV was taking forever to turn on
YES SIREEE, THE BULDGING CAPACITORS ARE MOST LIKELY YOUR PROBLEM. DO YOU KNOW HOW TO CHANGE THEM OUT??? IF YOU DO, I WOULD SUGGEST REPLACING THEM WITH NICHICON OR PANASONIC CAPACITORS.
May 10, 2012 | Vizio VW26L 26 in. LCD TV
I turn tv on then the standby light goes green then goes to red flashing
It is a common Fault on some lcd tvs you will need a replacement switch mechanism fitted don't know the correct name for it but it can be fixed .I had exactly the same problem with my BUSH 26 inch LCD tv took it to a local independent tv shop and the owner repaired it for me it cost around £67 if my memory is correct this fault started on my TV 14 month after i bought it - 2 month out of warranty. hope this response helps
Good Luck
Eddie Hall
Nov 27, 2010 | Televison & Video
Polaroid 26inch lcd tvred standby light on but power wont turn on. I've unplugged the tv, changed the batteries in the remote. The tv stays with the red standby light only.
You need to open it up and checking the voltages in the power supply sections, you should have 5v (for logic circuits), 12v for sound, 24v for backlight inverter circuits. Look for bad caps with bulging tops in power supply also.
Jan 12, 2010 | Polaroid FXM-2611C 26 in. LCD Television
My emerson tv standby light is on the power light flashes twice
Mine stayed in stanby mode and all I had to do was to switch the plug to a different outlet. The power strip it was on wasn't providing enough power. It worked fine for a month before I had a problem.
Dec 04, 2008 | Emerson EWL3706 37 in. LCD Television
BUSH IDLCD27TV006
http://www.chsinteractive.co.uk/pdf_data/KT02.pdf
Order Code….. KT02
POWER SUPPLY REPAIR KIT
BUSH MAXIM 1157 1154 Medion
Goodmans (Standard) 04TA069I 05TA71B 05TA071C
A standard power supply repair kit for faults attributed to the standby +5v rail.
BUSH IDLCD27TV006.
MAXIM 1154, 1157.
MEDION MD30112.
GOODMANS IDLCD27TV006.
The numbers off the boards will read: 04TA069I 26” 27” 30” 32”
& 05TA71B, 05TA071C.
LCD TV POWER SUPPLY PROFILO-TELRA.
Please check the primary of TR20 before fitting the kit.
Primary windings should read approx 2.700mH / 4.00 Ohm.
We recommend all kits are fitted by qualified engineers
We accept no responsibility for loss, injury or damage caused by your use of this kit as a successful repair
depends on your own skill and fault finding ability.
Circuit Reference
Loc Description
F300 T3.15A FUSE
IC21 FSD200
IC30 ICE1QS01
D315 12V ZENER
D318 2V4 ZENER
Q300 BC337
Q302 BC848C SMD
D325 1N4007
C213 33UF
C322 47UF
C356 47UF
C330 1000UF
LINK (IF NEEDED)
Oct 31, 2008 | Televison & Video
Maxim lcd tv stays on standby.
got the same here, turned it off via on/off button, then the big lightning storm happened ,next morning same as the rest, anyone got a clue how to fix it, ive opened it up but even thats beyond me.
Ant
Mar 26, 2008 | Televison & Video
Televison & Video Logo
271 people viewed this question
Top Televison & Video Experts
