Question about Panasonic Microwave Ovens
My microwave NNCS596S stops working and the code H598 flashes on the timer display. If I power it down and then up again it works but only for a short while. Any ideas?
  • Panasonic Master
  • 9,098 Answers
H598? Are you sure?
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Posted on Aug 12, 2008
I need a glass plate and plastic trivet table for NNCS596S microwave
You can obtain all available parts by calling the Panasonic National Parts Center at 1-800-833-9626.
May 31, 2014 | Panasonic NNCS596S Microwave Oven
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    I have a Jvm1090aw. After using the convection oven the microwave will not function. Is this a moisture sensor or?
    I have a jvm1090aw microwave oven and for some reason it just stopped working. It will still count down the timer but it won't light up and turn on. Also there is a small microwave icon flashing at the bottom right of the screen. Any ideas? Today I tested it again and started it for 30 seconds. The first 8-10 seconds nothing but silent counting down then it turned on for the last 20 seconds. It then turned on again when I tried it immediately after that but nothing 5 minutes later.
    May 01, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
    We have an Amana AMC6138AAS microwave/convection oven. I was cooking popcorn last night and opened the door before the timer stopped. When I opened the door the inside light and the control panel went...
    Did you have a power failure? Could be an overheat situation. Try unplugging the unit, wait 30 seconds and plug it in again. This resets the unit as long as there isn't a breaker or fuse blown. If it is a power issue, the display should start flashing. Did you get any error codes?
    Dec 20, 2017 | Amana Microwave Ovens
    Hi, I have a Kenmore 87103 microwave and it has started acting up lately. When I place something in the microwave and set the timer, the timer counts down however the microwave doesn't work (no sound and...
    Mine also does the same thing however I only need to lift the door upwards slightly (after it's closed) and it engages the High Voltage Transformer, thus working as normal.
    Once you know that, you can get it to work every time. I beleive the clips on the door don't properly stop latch in correctly and the safety feature keep the microwave from acutally turning truly "ON".
    Nov 28, 2010 | Kenmore Microwave Ovens
    EVERY PART OF THE MICROWAVE STOPPED WORKING
    There is an internal fuse inside. Need to find the cause for it blowing or it will just go again. Check the monitor switch and door switches. Eric
    Aug 08, 2009 | Jenn-Air JMV8208AAS Microwave Oven
    Microwave GE MD JVM140K Spacemaker yr= 1994 NOHEAT, DISP/TIMER OK
    Call GE answer center 1-800-626-2000
    ask for tech help
    Have you model # off your data plate ready.
    May 10, 2009 | GE Profile Spacemaker Over-the-Range...
    GE xl 1800 beep
    The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
    Let us know if the hard reset doesn't fix it.
    Jul 10, 2008 | GE JVM1660 Microwave Oven
    Siemens HF 87960 GB Microwave/Combo Oven
    Please, Can somebody tell me where can I get one of this oven??? Thanks Andy
    Dec 08, 2007 | Siemens HF87950GB Convection Microwave...
    Microwave Ovens Logo
    65 people viewed this question
    Top Panasonic Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
