Question about Bissell Vacuums
REPLACEMENT FILTERS FOR THE POWERFORCE 6 BAGLESS VACUM.IS THERE A BISSELL STORE IN THE DETROIT MICHIGAN AREA I CAN FIND BISSELL BELTS FILTERS ETC.
    President:
  • 1,673 Answers
Here are Bissel's numbers, they can tell you who to contact.
Service Center Dept. Phone Number:
(800) 457-1509
Service Center Dept. Fax Number:
(800) 517-9535
Hours:
M-F 8:00 a.m. - 5:00 p.m. ET
Posted on Aug 10, 2008
I cannot get the brushes to turn, now here is a dumb question does it take a belt as I am not seeing one on the brushes
Yes it does take a belt. This belt needs to be replaced every 6 to 12 months. Here is the belt you need and a manual with instructions:
Bissell PowerForce Belt and Manual
Mar 09, 2010 | Bissell 6594 PowerForce Bagless Upright...
Bissle vacume can not fit belt around motor
It sounds like you got a belt that was too small, if it is the right belt it will be hard to get on. But once its on you will be all set.
Jan 17, 2010 | Bissell 6594 PowerForce Bagless Upright...
My bissel vacume was not picking up the dirt on the carpet. So I found that the hose was clogged. I unclogged it but the vacume still is not picking up the dirt. I also changed the filters.
I found out that if you remove the front filter holder, tip vacuum back and look down inside. Sometimes there is hair caught back in there and you won't get suction. I had to use something long, knife, very long type tweezers, to pull all the hair out. Worked great after that. About half way through vacuuming I will stop and remove the foam rubber filter and clean it. Oh yea, you will have to use a flashlight to look down inside to see all the hair caught behind the foam rubber filter cup.
Dec 14, 2009 | Bissell 6594 PowerForce Bagless Upright...
I have a bissell powerforce bagless vacuum. My
Its probably is the roller brush causing the noise.
Nov 28, 2009 | Bissell 6594 PowerForce Bagless Upright...
Bissell powerforce bagless extremely loud.
It could be that the belt is worn. You can get replacement belts and the manual here:
Bissell PowerFrorce Belts and Manual
Nov 21, 2009 | Bissell 6594 PowerForce Bagless Upright...
My bissel upright vaccum cleaner belt got damaged and i replaced it with a new one , but it got damaged immd after replacing
In the area where you replace the belt, see if you can remove the beater bar, and check that there is nothing stuck in the area that is causing the damage, like a small screw or similar item.
Sep 11, 2009 | Bissell 6594 PowerForce Bagless Upright...
Bissell won't start
no reset (self resetting motor) Pull the plu,g leave it off for a day, plug it in a try it again tomorrow. If it doesn't work, the motor is gone
You also need to make sur ethat you get the vacuum back together correctly, some vacums put a swithc in there so that you can't hurt yourself while performing this repair
Feb 01, 2009 | Bissell 3594 CleanView PowerTrak Bagless...
My Bissel powerforce vacume filters
Remove the lower half of the dirt bowl by turning counterclockwise. Turn the filter counterclockwise, remove the foam filter and clean both with soap and water.
Jun 16, 2007 | Bissell 6594 PowerForce Bagless Upright...
Vacuums Logo
50 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
