I have a toshiba laptop which needs formatting. Whenever I start the procedure the laptop shuts down 10% into formatting. I have tried this several times. The laptop runs normally if I am in windows. Please advise.
  • linda_dawson Aug 13, 2008
    Thanks for the advice. Everthing seems to be running fine now.
    Scholar:
  • 65 Answers
Start with a boot disk. run a scandisk to find any errors, then try using fdisk to reconfigure your partitions, enabling you to format. this has worked for me in the past with desktop pcs.
Posted on Aug 10, 2008
  • matthew carroll
    matthew carroll Aug 13, 2008
    glad to help any more questions, just ask. i'll be glad to help
My laptop was formatted recently from vista to xp and now whenever I plug and external device like flash drive, it freezes/hangs the system and will only normalise after I force shut down.
You should install the drivers required to run the system correctly.
Go to www.toshiba.computers-europe.com and there you will be able to update the firmware and software as you require it.
Hope that helps.
Nov 03, 2010 | Toshiba Satellite A135-S2276 Notebook
Laptop start up problem
Have you tried performaing a recovery ?
Feb 15, 2010 | Toshiba Satellite Pro M10 Notebook
M55-S135 Randomly Powers Off Whenever Moved
The only problem i see here is the Battery contact with your laptop.
Its somewhere loosely connected. Just get it checked or you can test it yourself, hold the battery tight to your laptop and shake it and test it like it will shut down in any other case, if its not, then surely its a battery loose contact problem.
Hope this helps.
Thanks.
Mar 18, 2009 | Toshiba Satellite M55-S135 Notebook
My Toshiba Satellite L300D keeps shutting down when I start it up
restart in bios setup
then click to default settings press f10 to save and exit
if problem persists let me know
don't forget to rate
Feb 05, 2009 | Toshiba Satellite A100-S8111TD Notebook
Toshiba laptop reboots when on AC Power
I have the same problem with my Toshiba too, prima facie, it looks like Toshiba and Vista don't make a good combo. I suspected this to be a pure hardware problem, but was disproven when I booted in safe mode. It does not have any problems with the AC Power on in Safe mode.
Jan 12, 2009 | ASUS G1S-A1 Notebook
SYSTEM REBOOTS AFTER SHUTTING DOWN
It seems that when you formatted, you took your Bios settings with it. The latest bios can be obtained from toshibas website....Below is a direct link to the bios.
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=1976812xml&sliceId=&dialogID=51709196&stateId=0%200%2051707515
Sep 24, 2008 | Toshiba Satellite A215-S7422 Notebook
Hard disk Problem
dont repair it do the full system format
May 19, 2008 | Toshiba Satellite A105 Notebook
SHUTTING DOWN
I have the same problem and I tried everything and finally I realised it was one of the two ram modules installed. I took it out and it didnt turn off anymore.  But then I installed a 1gb ram module from my other laptop and the computer started shutting off whenever I connected the power adapter so I think it might be the wrong memory but taking the bad chip out solved the problem
Oct 30, 2007 | Toshiba A45-S121 Notebook
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
