Formatting memory card - Computers & Internet
  • 477 Answers
Click my computer rightclick on the device and format.
Posted on Aug 10, 2008
Reset console now r4 card will not work
memory-card-formatting
check above link for memory card formatting and solution of memory card problems like memory card not formatting, memory card showing errors etc
Jul 31, 2013 | Electronics - Others
I forget password of sandisk 2gb micro sd memory card
you can unlock your sd card by formatting*.
formatting memory card will delete all datas
formatting method*
use a softtwaer phone for formatting.. (example nokia 6120c, 5800etc )
insert your sd card into the softwaer phone.. select SETTINGS > DATA MGR > MEMORY > OPTIONS > FORMAT MEMORY CARD
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
My 1GB micro SD memory card needs formatting. But, when I am formatting it fails. ?What should I do?
Try formatting it in another device such as another card reader with another PC or formatting it in a digital camera
If that doesnt work, its likely the card is dead
Jul 21, 2010 | SanDisk 1GB microSD Memory Card
Cannot find instructions in manual for Nikon Coolpix S210 on how to delete ALL photos from memory disk. It will let me delete one at a time but I want to wipe the memory card clean. Thanks for any and all...
These instructions are from the Instruction Manual of the Coolpix S 210 and need to be carried out within the Set-Up Menu.
Refer Page 19:
Removing Memory Cards
Before removing memory cards, turn the camera off
and confirm that the power-on lamp is off. Open the
battery-chamber/memory card slot cover and press the
card in 1 to partially eject the card 2. The card can
then be removed by hand.
B Formatting Memory Cards
If the message at right is displayed, the memory card must be
formatted before use (A110). Note that formatting permanently
deletes all pictures and other data on the memory card. Be sure
to make copies of any pictures you wish to keep before formatting
the memory card.
Use the multi selector to choose Yes and press k. The
confirmation dialog will be displayed. To start formatting, choose
Format and press k.
Do not turn the camera off or open the battery-chamber/memory card slot cover until
formatting is complete.
• The first time you insert the memory cards used in other devices into the COOLPIX S210, be sure to
format them using this camera (A110).
Refer Pg 110:
 Format Memory/m Format Card
Use this option to format the internal memory or a memory card.
Formatting the Internal Memory
To format the internal memory, remove the memory
card from the camera.
The Format memory option appears in the setup
menu.
Formatting a Memory Card
When the memory card is inserted in the camera, the
Format card option appears in the setup menu.
Hope this helps
Ian
Aug 09, 2009 | Nikon Coolpix S210 Digital Camera
My Kodak EasyShare C315 needs formatting.
For all the camera users whose cameras won't format...they can't accept all the info on a 2 gb memory card... install a 1 gb card...worked like a charm for me! C315 and others were made before the 2 gb card. Only 1 gb cards work in the older cameras.
Tami
Dec 27, 2008 | Holga Flash, 120 Medium Format Camera...
Memory card needs formatting.
take a look at your memory card to make sure it is not locked, then try formatting you memory card
Dec 26, 2008 | Kodak EasyShare C713 Digital Camera
Nokia 6300 won't recognise Memory Card
If your memory card is not working properly, back up any data from your device's memory card to your PC, then format the memory card using your Nokia device. Please refer to your device's user guide for information on formatting the memory card.
If you get an error message during the formatting process, or an error message after formatting stating that your device cannot read the memory card volume, please take the memory card to your nearest Nokia service point.
Warning: Formatting your memory card will permanently erase all data stored on the memory card. Please back up all data stored on your memory card before formatting.
Important: The memory card inside your Nokia device should ONLY be formatted using your Nokia device. Do not attempt to format your memory card on another device such as a PC, otherwise your memory card may not work properly.
Happy to help
Have a nice day!
tc
May 31, 2008 | Nokia 6300 Cellular Phone
Formatting memory card.
Formatting erases all the data recorded on the SD Memory Card. If an SD Memory Card becomes unreadable, formatting may make it reusable.
Sep 06, 2005 | Panasonic AG-185 Camcorder
Cards not working with camera
If you used the SD/MMC memory card in another brand of camera or device, you may need to format the card in your new EasyShare digital camera. (You may have noticed a "Memory Card Needs Formatting" message when you inserted the card.) CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card. To format the SD/MMC memory card or the internal memory of the camera: Transfer images to the computer before formatting the memory card. Press the camera Menu button. Highlight SETUP MENU, and then press the OK button. Highlight FORMAT, and then press the OK button. Highlight an option - MEMORY CARD (deletes everything on the card), CANCEL (exits without formatting), or INTERNAL MEMORY (deletes everything in internal memory). Press the OK button. Highlight Continue, and then press the OK button. Wait until formatting is finished before removing the card. When formatting is complete, the SETUP MENU is displayed. Press the Menu button to exit the menu.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
