Question about Panasonic NN-S541 Microwave Oven
Microwave does'nt heat up everything else works,just don't heat up
  • 2,071 Answers
WHAT IS WRONG WITH YOUR MICROWAVE?
microwave - small_6_37.jpg For a detailed Microwave illustration, click below.
Counter top
redarrow.gif Built in
Danger! You can receive a serious electrical shock from the components inside your microwave oven--even when it's unplugged. Only a qualified appliance repair technician should perform any repair.
It doesn't work at all
It sounds normal, but there's no heat
I can't adjust the power level
The carousel won't turn
I have intermittent cooking problems
The display flickers
There's no heat, but it buzzes loudly
It quit after I slammed the door
It looks like there's lightning (arcing) inside my microwave
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 10, 2008
Everything working but no heat
Timer working but not heating - Microwave - iFixit
https://www.ifixit.com/Answers/.../Timer+working+but+not+heating
iFixitMy fridgadire microwave oven is not heating, it acts like it is heating by the timerworking and .... I have a GE Profile and everything worked but it would not heat.
Microwave Not Heating Troubleshooting Guide - YouTube
? 2:45
https://www.youtube.com/watch?v=_3SbJueEn1w
Aug 31, 2012 - Uploaded by Repair.com
If the water is not consistently warm, you've confirmed there's a problem. ..... Everything works except the microwave- it wontheat anything up. ... How to Fix a Microwave Oven - Simple Fuse Replacement - Duration: 18:04. by
Nov 28, 2015 | Electrolux E30SO75FPS 1000 Watts Microwave...
Everything works but it want heat I don,t heard any buzzing noise
Most likely the magnetron is dead. This is what creates the microwaves. If that is the case, deep six the device and get a new one.
Oct 22, 2015 | GE Microwave Ovens
MICRO DOES'NT HEAT
First, check to make sure that the door is closing and latching fully and that there is nothing jamming any of those mechanisms. There are safety devices that keep microwaves from turning on if they think the door is open/ajar.
If the door is fine and the rest of the functions (timer, etc.) are behaving, it's probably a busted magnetron. That's the part that actually emits the waves that do the heating. It's a part that can be replaced, but probably cheaper to get a new microwave.
Oct 02, 2012 | Sharp Microwave Ovens
My plate just cracked while microwaving popcorn
Make sure you don't put any dishes in the microwave with something like popcorn because they retain more heat and have nothing to transfer the heat too. If you mean the built in spinning plate that you set stuff on and you have an older model the fan might be broken. Something similar happened to my microwave as it is pretty old i just removed the panels and cleaned everything/blew it off with an air hose and it started working again. I'd check with the manufacturers also!
Sep 25, 2012 | Panasonic NN-T694SF Microwave Oven
The microwave does not heat up the food but everything works except the fact that it don't heat up the food
Hi!
The most common cause of the problem you described is a burned fuse. It is normally located inside the case, directly on a wire leading from the transformator to the magnetron. If you are not sure about those parts, please get a professional to fix the issue.
Aug 20, 2011 | Samsung SMH9187ST Microwave Oven
Will hot heat...everything else on appliance works.
It could be anything from a simple door switch to a capacitor or magnetron. Either way I don't recommend do it yourselfers trying to repair a microwave. The capacitor stores enough electricity to knock you out even when the machine is unplugged. Leave this one to a professional.
Aug 06, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave oven isn't heating my food. Everything else works, the fan, the lights and the keypad. The microwave turns and sounds like everything is working but the food won't get hot. We used it about an...
Usually when it doesn't het there is a problem with either the magnetron or one of the power tranistors. You would have to get a shop to tell you what the problem is as it can be a few things. If you have warrenty either maytags or from the store just find out from the store/maytag where the repair depot is. They will either repair or replace it. If no warrenty then don;t do anything without getting an estimate. It may be just as cheap to buy a new microwave.
Aug 12, 2010 | Maytag MMC5000 Microwave Oven
Samsung mw87L microwave does`nt emit heat, light works, turn table works, controls work, but no heat. Had it just over a year.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
dhj
Apr 21, 2010 | Samsung MS1040BB Microwave Oven
Will not heat up
The time set mode was not reset to regular setting.
Everything would work but would not engage heat.
it works now!
thanks Don
PS you need to have a way to talk to you, when new equpment is installed and have problems and to registered
Apr 06, 2008 | Microwave Ovens
Microwave is nt heating
The problem of shutting down after 29 seconds is due to a defect in either the magnetron or the inverter. It will need service, preferably by a professional due to the lethal voltages inside. You should be able to find a servicer at the Indian site: http://nationalpanasonicindia.com
May 03, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Panasonic NN-S541 Microwave Oven Logo
171 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
