I want to get onto FB on my home desktop. It says it loading by the moving circle and then that circle is gone and nothing happens. I'm really puzzled. How can I access my account? I can get into it by internet or by my FB icon in my aol mail toolbar. Please send instructions. I'm at work right now, but if you send it here, I can work on it when I get home. thanks
Instead repainting or
staining your table, I recommend a have a great method, using a product you
probably already have at home.
Mayonnaise! Coat a thick layer of
it onto the circles and let it sink I for one hour. You should see some improvement. If the circles are lightened but not
completely gone, repeat the cycle.
Youtube downloads the song in the background as you listen to it. If this process, called buffering, happens too slowly, then youtube will pause.
Make sure you aren't downloading anything in the background, otherwise you'll need to load the page, pause the video, and let it sit for a few moments before playing. Getting a faster connection can solve this problem.
If you like my solution, please vote for me.
go into control panel and create a new user (dont make it the same name as your old profile) then restart the pc and log into that new profile. To retrieve all your settings favourites etc you will need to say what version of windows you are using
Normally page load error represents, there is busy at serve side or otherwise low web access, but you have fine access, so there is a problem in server side, but you are accessing in iphone, so there is a problem in laptop, that is as like Iphone, there is lack of in-built functions in laptop to retrieve FB. dont worry about it right now!
if you want you can access FB which is integrated with IM such as digsby / Gabtastik / adium! have fine!
this "bringing you back to your own homepage" thing happens to me occasionaly. I would try, restarting the computer. If that doesn't work, wait a little while, it usually fixes itself, and seems to be more of a problem with FB that with what you are doing. If it continues, email the support staff at FB and explain the problem.
Typically when the drum spins and walks the washer, it is a loading issue. As the clothes spin, they collect on 1 side, due to cintrifical force acting upon an uneven load. THis is especially prevalent in loads that are: 1. small, 2. contain lots of towels and 3. anything else that really holds water and is very heavy when wet (like comfortors, pillows)
These will very quickly throw the load off-balance.
When it happens, pull out some of the itmes, and re-load the laundry more evenly around the drum. Be sure to circle the post with towels and sheets, etc.
If you continue to run the machine off-balance for an extended time, the bearings and seals will wear quickly. Unfortunately, you will only know this when the washer begins to leak out under the machine onto the floor.
Hopefully this will fix-ya....if not let me know please!
If the colour circle shows...
find a tiny bit of wallpaper showing through the back,
then click.
Then, you should see it labled finder instead of preview.
Next, click on the blue apple.
If it doesn't happen immediatly, a dropdown bar will show in a couple minutes.
In the dropout bar, click Force Quit.
It usually takes 2 minutes for the Force Quit window to show up.
It'll ask you what you want to force quit,
Look at the choices and force quit all of the ones that say: NOT RESPONDING.
Then the computer will clear up for a while, in wich you can probably preview your pictures.
It is the hard drive. The EXACT same thing happened to me. You will need to replace the hard drive. You can backup all the info onto another computer using a firewire cable as I did. Boot your computer and hit "apple" "T" while booting, a firewire logo should appear and bounce around the screen. Makes your computer a giant external hard drive.
