Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Toro 6.5 ez start
I was having a problem keeping it running. I soaked the carborator in gumout. now fuel runs out the air filter please help me
    Champion:
  • 313 Answers
See www.smallengineadvisor.com for trouble shooting & repair of what wrong with ur mower
Posted on Aug 13, 2008
I have toro recycler 6.75 oil keeps soaking the air filter please help
check oil level in the sump
if the fuel system does not have a tap the fuel can get to the sump
next the sunp breaths through a tube connected to the back if the air filter
If the motor and rings are worn then excessive blow by will push the oil fumes to the air filter and if the oil level is high then oil will come out as well
May 29, 2016 | Toro Garden
My lawn mower wont keep running, I have put on new spark plug, cleaned the carborator, changed the air filter. Any other ideas?
How thoroughly did you clean the carb? They need to be fully disassembled. There are some small orifices in them that need to be cleaned with either a jet cleaning tool or a piece of wire.
Aug 18, 2012 | Toro Lawn Mower With Toro Power Tools
Have a 93 vulcan kawasaki and am trying to find a diagram of how hoses are wired to carborator. Also, I am trying to find out what the screw settings are on the throttle cable and the other cable that...
Hi, Candyl_white (you still have a carb or intake issue) if your bike has been sitting idle for months or years and you did not do any pre-storage maintenance I feel your pain it will probably have a dead battery and not want to start or if it starts it will not idle unless the choke is full on and run poorly then stall, here are the following steps necessary to complete in order to get your bike back to an acceptable running condition and in the future pour in a bottle of fuel stabilizer and injector cleaner for you FI folks at least 2 times a year and before storage.
1. If your battery was 2-3 years old when you last had the bike running you should replace it.
2. If you believe your battery might still be serviceable remove it from the bike and put it on a 1 or 2 amp trickle charger for 24 hours. If it is the old lead acid type with visible cells and acid levels fill each cell to the top line with distilled water and replace the caps, run the vent tube into a plastic or styrofoam cup, any cells that are cloudy/milky replace the battery.
3. After charging remove the leads and let the battery sit for a couple of hours then check the battery voltage with a volt meter, you should have 12.5 volts or more, any readings in the 11 volt range you need to do a proper "LOAD" test on the battery and replace as necessary, you may have 12.5 volts or better but little or zero amps, any readings in the 10 volt range you have a dead cell and the battery needs to be replaced.
4. Drain and flush fuel tank, google " how to clean a motorcycle gas tank" find a couple forums to view the different options available.
5. Remove and inspect your air cleaner paper elements that are not oil soaked can be cleaned with a soft brush and low pressure compressed air, oil soaked elements must be replaced. Gause mesh and foam elements can be cleaned by soaking them in a container big enough to completely cover them with a solution of 1 gallon of water and 1 oz. of Dawn dishwashing liquid for small and medium size elements, for monster size double the formula and let soak for at least one hour then rinse with warm water shake off excess and let air dry, "WARNING" do not use compressed air as this will embed micro-sized dirt and road grime and destroy the mesh pattern and stretch foam elements out of shape just squeeze it like a sponge and let air dry, use a fan if you're in a hurry. When completely dry spray a very fine mist of air filter oil evenly around the whole element.
6. Remove the carburetors, disassemble and decontaminate with a carb dip or if you have EFI remove injectors and clean with carb spray and compressed air
7. Check intake manifold and seals for leaks and cracks.
8. Remove fuel valve and filter disassemble and clean as necessary, remove, clean, and inspect fuel and vacuum lines and replace as necessary.
9. Replace spark plugs with new ones and check for spark.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Vulcan 500 idle
How To Get Your Motorcycle Up Running Randys Cycle Service
Kawasaki EN500 Vulcan 500 LTD Service Manual
OEM Parts for Kawasaki
2009 Kawasaki Vulcan 500 LTD Owner Manual
May 20, 2017 | kawasaki EN 500 Vulcan Classic Motorcycles
My 1992 dodge dakota wont run. i will start it but i will have to feather the gas to keep it alive. it has over a half a tank of gas in it can you help me?
when was this vehicle as serviced?
this could one of several issues.
1 the idle jet on the carborator maybe dirty so the engine is not getting enough fuel at tickover to keep running.
2 the fuel filter is blocking up and may need replacment.
3. the carborator may need an overhaul as the float chamber is not activating correctly.
4. fuel cap may be blocked give a run with the fuel cap off see if that helps. if you get aload hiss each time you fill up that indiates a blocked fuel cap which will need clearing or replacing.
5. dirt in the fuel line if filled from jerry cans contaminents can get in th tank and block the line. when you put pressure on the gas this causes higher vacum from the pump and hides the problem.
6 airfilter may be blocking and needs replacement so there is not enough air at ldle.
7 check plugs if they are sooty or covered in white then the mix is wrong and needs resetting. or indicats reduced fuel or air to engine.
8. plugs may need replacement.
Nov 13, 2009 | 1992 Dodge Dakota
Mower will start and die. wont run for more than a few seconds
Sounds like the carburetor is dirty and needs cleaned. I would suggest trying some fuel line cleaner such as gumout or seafoam in the fuel tank and start and run it a few times to circulate the cleaner, then let it set overnight. May have to start over several times to get it to work. It will eventually start running, tho not real good, until the cleaner gets in there.
Oct 23, 2009 | Toro Lawn Mower With Toro Power Tools
Yerf dog go-kart, engine wont rev when gas pettal is mashed
This is probably, a timing problem.
check the plug, and the magneto.
Also, if you haven't already, make sure the air and fuel filters are in good order.
Have fun.
Jul 26, 2009 | Toro Lawn Mower With Toro Power Tools
I have a 6 HP Ariens whipper snipper on two 18" wheels, it is about 5 years old and ran perfectly since new with no maintenance, this year wont start. fires but will not run. changed the fuel and plug...
Check to see if fuel is leaving the tank, the internal screen might be plugged up. Check the rubber fuel lines and if provided the in line fuel filter for flow. Don't always trust carb cleaners and compressed air to clean a carb., you might have to use a steel wire from a wire brush to open the jets and passages.
Jun 22, 2009 | Toro Lawn Mower With Toro Power Tools
Mower will not stay running
cleaning the carb might work soak it in gas foe a lil wile and it may fix the problem
May 31, 2009 | Toro Lawn Mower With Toro Power Tools
Engine surging
sounds like it is "hunting". it is a fuel mixture issue.
May 22, 2009 | Toro Lawn Mower With Toro Power Tools
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
56 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
