My Staples chair Model# 16346-US, bought August 9, 2008, did not have two(2) parts in its sealed box. The parts missing are: the gas lift, and the telescopic cover Please send the named items,and you pay all shipping and handling costs.Send to: H. Paul Cone 3024 Brook Hollow Lane Mountain Brook, Alabama 35243-5508
    Top Expert:
  • Office Equip... Master
  • 30,301 Answers
2008?? i wouldnt expect much from staples now
Posted on Jul 29, 2017
SOURCE:
SOURCE: THIN BLACK LINE IN PANASONIC PLASMA SCREEN
If it is a cable...There are many(from 7-11)driver ribbon cable with horizontal driver chips mounted on them!!!! So if problem didn´t go away after fixing all cables...your plasma has died.
Posted on Sep 20, 2008
SOURCE: Telescope does not focus
Check to see if they have loosened the lens end of the scope. As it screws on, maybe they unscrewed it enough to make it get out of focus range.
Posted on Feb 13, 2009
SOURCE: instructions for telescope assembly
I really don't understand the actual problem? You have the manual-- have you assembled the scope according to the manual?
If you have --- put the eyepiece with the LARGEST number written on it into the telescope-- this is your LOWEST magnification. (Never use the 2x or 3x barlow that comes with these small telescopes -- it is useless-- just too much magnification. )
Now go outside during the daytime and point the telescope at a distant land object and practice focusing-- the moon should be your first target at night. Spend a little time during the day and line up the small finder scope which is usually mounted on top of the tube --- with the main telescope. Once they are lined up you can use the finder like a gun sight to point the telescope.
Posted on May 18, 2009
  • 6 Answers
SOURCE: My Laser-class 710 will not send. Items seem to
your machine may not have a proper dial tone
or the modem may not be working if you have a dial tone.
check the trasmision report Errors
Posted on Jul 08, 2009
  • 116 Answers
SOURCE: the document cover has two whites square supports
that is called hinge assembly . cost is depending on models
Posted on Sep 17, 2009
Hydraulic assembly for staples chair Model : 24115D
You would need to contact staples on this, but really doubt that the chairs parts are available.
Nov 23, 2016 | Furniture
How do I get missing hardware?
Go to your local Staples store and request the missing hardware.
Jun 28, 2016 | Staples Bermond Fabric Mid-Back Managers...
Looking for replacement shock for seat bar lift.
Amazon.com: HomCom 3.2" Universal Replacement ...
www.amazon.com/...Replacement.../B008XVEZG8
Amazon.com, Inc.
Rating: 4.2 - ‎123 reviews
Office Chair Pneumatic Gas Lift Cylinder Piston Replacement - Universal Size ... much right on the money and I have to say that the price just simply cannot be beat when you start looking for pneumatic gas lifts! ... ·With PP gas bar cover ....Replacement Office Chair Gas Lift Cylinder Pneumatic Shock - 5" Travel - S6111.
Lift Kits -Body Suspension Lift Kits, Bump Stops & Sway Bar ...
www.4wheelparts.com > Suspension
Lift Kits -Body Suspension Lift Kits, Bump Stops & Sway Bar Bushings ... ShockAbsorber Bushing. Upgrade or replace your ... Shock Link Kit. Shock Link Kit. Lift ...
Complete Suspension Systems and Lift Kits - 4 Wheel Parts
Dec 27, 2015 | Toys
Home Meridian Comfort Lift Chair - lift mechanism is sloppy in partially reclined positions
Bolts commonly loosen up on these. You may be able to tighten them. I had to turn the chair over, pull out some of the staples that hold the material on and find the nut that went on the inside, then I was able to tighten the bolt again and staple the material back in place. I also had to make a new plastic cross bar for the scissor assembly by using a half inch PVC pipe and two flat plugs and two couplings, I then drilled a hole in the center for the screws to go in. Painted the newly made one with black plastic paint from Lowes and it's stronger now then before. If you want parts here is Home Meridian's contact..........
Jan 24, 2014 | Home Meridian Comfort Lift Recliner
Office chair lowers on its own
It will be one of two things, either the gas strut is no good and in this case you might as well get a new chair. Or the lower lever is stuck in the " lower" position, if this is the case freeing it up should cure your problem
Aug 28, 2013 | Furniture
Gas cylinder
seal in gas lift is bad...replace gas lift
Aug 14, 2012 | Furniture
56 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
