Hello roger. I am the bearer of bad news for this answering machine. There is no easy fix to this problem as the circuit board is bad. This happens because the solder in the circuit board eventually deteriorates and no longer works properly. Joe
The ring time setting allows you to set the number of rings the caller hears before your answering system plays the outgoing message. You can set the ring time to answer after two, four, or six rings. If you enable the Toll Saver (TS) setting, the answering system picks up after two rings if you have new messages, and after four rings if there are none.
Setting the Number of Rings
I have tried your solution. It still does not work. The machine still comes on and cuts off my phone calls.
