Motherboards
Problem for Motherboards
Generic problem for all Motherboards
Cmos checksum error - defaults loaded
By Markk7171 on Aug 10, 2008
I am working on an older Windows 98 computer. When I turn it on, the screen shows the bios manufacturer and version number, identifies the primary and secondary drives, then posts the following error message:
CMOS Checksum Error - Defaults Loaded
Press F1 to continue, DEL to enter setup.
Pressing either key does not work, as a matter of fact the lights on the keyboard flicker, but none of the keys will work. tried pressing Cntrl-Alt-Del to reboot but nothing happens. I replaced the cmos battery with one that I know is good and get the same results. I cannot enter setup or the boot menu to diagnose the problem. I think there is something wrong with the PS2 port that the keyboard is plugged into, because I know the keyboard works in another computer.
There is only one PS2 port, the other port is a larger 5 pin port, normally used for a mouse. Could this 5 pin port also be used for a keyboard, and maybe I need a keyboard with a 5 pin plug to make the computer boot?
Or . . . am I diagnosing the problem incorrectly?
Comments:
Aug 10, 2008
- I do not have the manual, and the make and model of the computer is not known. I think it was a custom build. The only thing listed on the motherboard is MB - 8500TDU-A ver 1.1.
I will try an older keyboard.
Clarification Request
Posted by hockeyguyJC on Aug 16, 2008
Are there jumper settings on the motherboard that will allow you to manually reset the BIOS settings?
Same Problem
Dec 21, 2008
-   I have a same proble, same massege is displyed and keyboard does not work..what is the resulation for it?? Please help! -   Guest
Best Solution
posted on Aug 10, 2008
Helpful)
steve6375
Rank: Wiz
Rating: 82%, 159 votes
Ports are usually labelled - look carefully.
Try manufacturers manual.
Could be that keyboard is the larger 5 pin DIN socket (old IBM AT keyboard).
Was this helpful?
Yes
No
Popular Solutions for Motherboards
Questions and Unsolved Problems for Motherboards
Answer
Ive just looked at the specs for two motherboards 1,Asus P6T Deluxe V2 2,Asus M4A785TD-V EVO. WHATS... (More)
Answer
compaq presario mother board, what should I replace it with
Answer
I just want to change my ASUS P5PE-VM mobo because I think it's broken. I still want to keep the... (More)
Answer
i need aero support video drivers for windows 7.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboard Experts
Top Computer & Laptop Repairmen
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
