when I use the espresso part, I fill with water, turn on, and very little water drips out.. then it pushes steam out through the espresso part. I turn it to Stream out the nozzle, and it blasts out. So something is clogging the water from coming out. I've taken the strainer off and cleaned it, and cleared out the whole where the water drips from, tried again and still minimal drops of water and steam coming from the espresso side?
I fill the 2-cup thing full to almost the rim, then mash it in using the circle on the end of the...
(More)
I fill the 2-cup thing full to almost the rim, then mash it in using the circle on the end of the scoop thingy. I learned not to smash too hard, as my machine doesn't like that. After it has warmed up, I put the espresso "bowl" thing with the handle onto the machine, locking it in place. I then hit the 1-cup button, and less than 1 shot of espresso comes out before it beeps several times, and the lights flash on and off repeatedly. It seems angry when it does this. I wait a couple minutes, then try again, and finally get a full shot of espresso. What am I doing wrong? I'm just trying to get a double-shot, but it now barely gives me 1. I even replaced the little metal cup thing with a new one, no change. I switched to pre-ground espresso in case it was the grind being too fine, but still not better. Did I buy a bad machine???
My coffee and filter are in place, the water is in, the bottom gets very hot....but no coffee...
(More)
My coffee and filter are in place, the water is in, the bottom gets very hot....but no coffee brews/drips. I need coffee...help!!
