Question about Coleman Electric Cooler 40 Beverage Cooler
Fan blower coleman electric cooler
Which direction should the fan blow the air - should it be exhausting off the heat sink or blowing downward. I have ice building up inside the cooler. The cooler is new but I had fan fan blades break so I replace the fan with a 12 v brushless fan and now have this ice problem. The frig stays 20 degrees cooler than outside temp, but is building ice.
  • 3 Answers
The fan should blow air into the heat sink. The warm air exits the heat sink at both ends. (It might work the other way, haven't tried it.)
When you have ice in your cooler, you know the thermo-electric element is working well--it's below freezing!
Ice builds up because there is water in the cooler. For example, in humid weather, you open the cooler, some humid air gets in, and the cooler temperature condenses the water. You have to empty this water, either by tipping the cooler, or using a sponge.
You can easily defrost the cooler by unplugging it for an hour or so. You know it's time to defrost when you hear the fan blades making a racket because they're hitting something--a thick buildup of ice.
Posted on Jun 13, 2009
  • jiminminn Jun 13, 2009
    The fan is a common size used in personal computers. It's 92mm square by 25mm deep. (For us in America, that's 3-5/8" square and 1" deep.) You can get one where computer parts are sold, for example to people who want to build their own PC. (I found mine at a local Microcomputer store.) You might as well buy a good quality replacement fan, so get one with ball bearings (double ball bearings is even better). Expect to pay $10-15. If you can't find one locally, just Google and you will find them available on the web.
  • Bubbly Bullseye Feb 03, 2012
    The original motor should have power leads, one white, one black, or one red, one black.
    The white will most likely be your 'hot' and the black is your ground, though some times these are reversed it isn't often.
    Red would be your hot and black would be your ground.
    Wiring it "backwards" wont ruin anything it will only cause the fan to blow the wrong way. You should be 'sucking' air off of the heat sink so if the fan is blowing on TO the heat sink you need to switch the wires.
    The best way to connect something like this with with Solder and shrink wrap tubing. However you CAN use crimp connections in place of solder but it won't be as secure.
  1. my cooler is warm inside my fan is barely turning. How do I get parts?
Posted on Oct 05, 2008
    You can find replacement fan motors for coolers here
    This Fan Motor works as a replacement for most Thermoelectric Coleman Coolers.
    http://www.12volt-travel.com/replacement...
I had a problem with ice build up also then discovered that the cooler fan needs room to breathe I moved objects out of its way then it worked great no more ice even with standing water in the bottom keep the inside motor clear. I also had a problem with the outside fan slowing down and not cooling, solution remove cover then remove fan from the backside pop out the blades with your thumb put a drop of oil in the hole where the fan shaft goes in works like new.
Posted on Feb 28, 2010
Any suggestions on how to wire it to the cooler?
Posted on Dec 18, 2009
Which way does the rear fan go in a compaq computer tower
The proper installation of a CPU fan is often the subject of debate. Though there are conflicting theories as to which direction the CPU fan should face, there are methods to ascertain which CPU fan installation best suits your needs. The determining factors of your CPU fan installation direction include the manufacturer specifications, your case design and the specific design of your heat sink
Horizontal Installation
  • The installation of a CPU fan horizontally to the plane of the motherboard is the most common installation orientation there is. Your options when installing your CPU fan are to blow cool air onto the heat sink or to pull cool air through the heat sink from the motherboard. Horizontal installations show negligible advantages in either installation direction. The differences in temperature usually vary by only 1 or 2 degrees Celsius. The main point to consider when installing a horizontal CPU fan is the location of the rear exhaust fan on the case. If the rear exhaust fan on the case is parallel to the processor, it is advantageous to have the fan pull cool air from the motherboard and push it out above the heat sink. This is because the case fan will quickly draw that hot air away from the CPU and out of the case, allowing for quick cooling.
Vertical Installation
  • Vertical, or tower, heat sinks rise high enough off the motherboard to allow for a fan to be installed perpendicular to the plane of the motherboard. This allows for cooling to go from the front to the back of the case, as opposed to going from the bottom to the top. Optimal installations for vertical heat sinks are blowing toward either the back or the top of the case. If there is no exhaust fan in the top face of your computer's case, it is more effective to orient your fan on your vertical heat sink so that it blows toward the rear exhaust fan of the case. If there is an exhaust fan on the top face of your computer case, it is almost always more effective to mount your CPU fan so that it blows air up toward the top of your case. The reasoning behind this is that hot air rises and will more naturally flow off the top of your case. Also, top-mounted fans are usually larger and allow for faster airflow out of the case.
Manufacturer Recommendations
  • It is often the case with nonstock heat sinks that the manufacturer has designed the heat sink's fan to be mounted in a limited number of orientations. This is usually evidenced by limited mounting notches on the heat sink itself. Most aftermarket heat sinks use technologies such as heat pipes that have specific cooling needs to operate appropriately. Because of this, it is important that in any CPU fan installation you follow the manufacturer's installation instructions.
Performance chips of BMW
May 31, 2012 | Compaq Hp - 375376-001 - Dc7600 Tower...
2003 trailblazer I have no heat or air coming out of my dash vents
Is it no heat/air when sitting still, or no heat air period? If the heat and air blow slightly when driving you have a bad blower mower/resisitor and its not allowing the air to blow into the cab. If not blowing period when moving probably bad heater controls or fuse... Worst case scanario is you have an electrical problem that needs to be diagnosed
Jul 15, 2010 | 2003 Chevrolet TrailBlazer
My Coleman Evcon heating and air unit will not blow air
bad blower motor. recommend a new blower motor and capacitor.
May 28, 2010 | Coleman Heating & Cooling
Coleman model 5645 inside fan motor not working .. how do you open the cover to get to the fan and motor
pull straight up on the cover. Remove the 4 screws that hold the fan to the heat sink. You can then remove the 2 torx screws and remove the heat sink if you need to. Clip the wires as close to the bad fan as possible so you will have enough for the new fan.
Feb 01, 2010 | Coleman Electric Cooler 40 Beverage Cooler
The 5640 Coleman cooler motor runs, but unit does not cool.
This is a thermoelectric (TE) cooler. There is no gas' to replace in it's cooling system. It is possible the thermoelectric coupler has gone bad. Unfortunately Coleman does not seem to offer a replacement part. If you Google thermoelectric couplers, maybe you can find something on the web. Good Luck.
May 25, 2009 | Coleman (100076) Compact Refrigerator
Electric furness blows hot then warm
if this has happened since you got hte furnace it is normal
heres how a heter works
themostte tells heater to turn on
heating element turns on
followed in about a minute by the blower
during the peried before the blower kiks on the elements become supper heated
after the blower kicks on it slowly leves off the element temp and air temp coming out
Jan 23, 2009 | Hunter Fan Company 5/1/1 Programmable...
Had a ceiling fan with dual purpose, one to blow air upwards durng the cooler months and one downwards during warmer mos. unable to set the fan to blow air downwards.
Explain set it. Generally there is a switch on the fan to reverse, are you attempting reversing by that switch or a wired in wall switch? If it runs in one direction it will run in the other. Something in the control is broken or not wired correctly.
Sep 16, 2008 | Heating & Cooling
Electric Cooler 40 problem
blow out the dust around the outside fan and heat sink
Jul 01, 2008 | Coleman Electric Cooler 40 Beverage Cooler
Coleman Electric Cooler 40 Beverage Cooler Logo
2,707 people viewed this question
Top Coleman Home Experts
john h
Tom Chichester
Are you a Coleman Home Expert? Answer questions, earn points and help others
