Question about Garmin GPS 12 GPS Receiver
Data lost my garmin 12 was not used for about 5 months when i turned it on again all my way points lost can it be recovered
  • wayneos Feb 04, 2009
    GPS wont stay on long enough for me to retrieve the data from it, is there a way to download the info from it to another GPS?
Sounds like the memory battery ran low. Did you get a "Memory battery low" warning message when you switched it on? If so then that confirms it, and I'm afraid your waypoints are lost.
As for the memory battery it will take on some charge if you just put in fresh AA batteries. How much charge depends on the age of the GPS, mine is over 10 years old and the memory cell is pretty much dead now.
Grmin may or may not replace the cell for you depeniding on the age of the device. If you want to do it yourself it's a very fidldy job requiring some expertise with a fine pointied solderign iron. The case is held together with solicone sealant aroung the joining edges - there are no plastic catches - one piece of the case has a sort of trough around the edge that the other piece/side slots into and the trough was fileld with silicone sealant and the two pieces sandwiched together. It's not a very strong glue though so it can be prised apart with a fine knife and patience.
Posted on Aug 31, 2008
How to recover my lost contacts from my iphone 4s?
If you already have an iCloud account, you should be fine.
Just restore you iphone with icloud and you will have all your contacts again.
if not, check if you got contacts on your SIM card. To do that, go to settings, Mail and contacts and choose import SIM contacts.
If you have a google email adresse set up in your phone, you can recover them from gmail.
hope i helped you
Nov 21, 2014 | Apple iPhone 4S
How to recover data from water damaged iphone?
Best try is to put the phone, after drying it as much as you can and separating the battery, about 3/4 days in a container with one kg of rice together with battery, the rice will dry the water and maybe it will turn on again just to let you copy your needed infos. Look at the battery level after the procedure and recharge if needed.
Hope this help :)
May 07, 2014 | Cell Phones
How Can I recover iPhone lost contact sms and photo?
There are two ways to recover lost data for iPhone
1. Directly scan and recover data from iPhone
a) Connect your iPhone to the computer
b) Enter DFU mode and scan iPhone
c) Preview and recover iPhone data
2. Scan and extract iTunes backup to recover iPhone data
a) Scan your iTunes backup for iPhone
b) Preview and recover iPhone data
c) Do backup well
Mar 09, 2013 | Apple iPad Cell Phones
Some pictures and contacts were deleted from my 3GS . Is there a way to recover them?
Yes, there is a way though iPhone use quite different storage mechanism, still you can recover the lost data (such as text messages, contacts, photos etc) with a specific iPhone data recovery software ->
Good luck & best regards!
Apr 29, 2012 | iPhone Apps
Hi i am using gps 12, unfortunately my store waypoins all are lost, is it possible to recover them
Unfortunately the answer is no. When the Garmin 12 was being made there was no facility for recovering any deleted waypoints.
Nov 07, 2010 | Garmin GPS 12 GPS Receiver
Can you recover deleted files from the Olympus Recorder VN-4100PC? also, one of my files is unable to play. any way of recovering it?
YES, it is definitely possible to recover such kind of files deleted from your Olympus recorder.
First things first: DO NOT take any more videos or audio with the recorder that you want to recover files from in case you may quite possibly ruin your chances of voice memo file recovery.
Then connect your recorder to a PC with a recovery program installed. Photo Recovery Software (also recover Voice memos, audio and video files) is right what you need to use if you are running Windows. If you are Mac OS X users, turn to Data Recovery for Mac.
But you should remember - the more you use your recorder, the less likely you may be able to recover the deleted files back! So STOP using the device ASAP. I hope this will help. Best regards!
Sep 01, 2010 | Olympus VN-4100PC Digital Voice Recorder
I have a garmin gps 12--s/n 35854358. No auto-locate?
If you haven't used the gps for a while they can try to operate with the incorrect catalog or time. Unless these are both correct it gets lost. Usually you can correct this with a forced reset. There is also a update for this unit which also forces the update.
The data cable sort of screws on and makes contact with 4 pins. This is the little round connector. It does both power and data. The cable is a wee bit pricey from Garmin but you can make them or just get one from ebay.
The reset usually wipes out any saved routes poi's etc so using the data cable will save all of those. To reset the 12 I believe you hold the lower right corner of the screen and then power it on to reset. Then you need to let it rub until it gets the new data which can take 5-50 minutes. Makes sure your batteries are good.
I'd recommend the data cable route (use a 'gasp' non garmin cheap cable) and upload the update at the same time and you should be good to go try and get lost again.
Jun 28, 2010 | Garmin GPS 12 GPS Receiver
Lost destination after saving it
Sounds like the internal memory battery is run down - it's charged from the AA's. Usually does not recover. Battery (the VL1220) is shown here:
It' easily replaced once the case is open but requires a steady hand with a fine tip soldering iron. Local story started by me here.
Sealing the case up again is very fiddly - hard to make a tidy job with silicone.
Feb 22, 2009 | Garmin GPS 12XL GPS Receiver
Garmin GPS 12 GPS Receiver Logo
237 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
