Question about Mitsubishi WS-55511 55" Rear Projection Television
Mitsubishi Ws 55511
Hi, I just would like to get an opinion! the screen on my tv is starting to show shadows and color discrepancies any idea? Thank you,
  • 927 Answers
Good Day;
My opion is that the TV"s convergence Ic has failed > STK393-110 > 267P155010.
Good Luck, big IRISH.
Posted on Oct 01, 2008
The picture is bigger then the screen how do I adjust so that the picture is same size as TV thanks
Please confirm tv model number as question shows its Mitsubishi WS-55511 rear projection tv.
This info will help me to suggest a solution.
Do you get correct colors in picture though its over size?
Thanks.
Aug 13, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55511 convergence problem?
No,need to diagnose.It a 100% convergence problems.Convergence problems very easy diagnose.The picture look like 3D,colors lines don't lines up.Fuzzy,out of focus.Convergence controls don't work to lines up any colors cross.The tech is cheating u if he said cost $125 to diagnose.If u know how to solders u could fix this convergence problems about $100.U can buy a convergence kit at Websites Tv repair World.com,Tvrepairkits.com.The shop everythings fix parts and labors only $300.
Mar 16, 2010 | Mitsubishi WS-55511 55" Rear Projection...
How to reset convergence? on mitsubishi ws 55511, has a shadow colored blue or yellow
There is an option in the user menu on the tv. Using either the remote or control panel on the front of the tv, press MENU then select SETUP. After you choose SETUP go to the 3rd column with the 3 icons. Here you can adjust the red or blue color or reset the convergence back to factory default.
After a few years the set will begin to show increasing problems with the convergence settings. When you can no longer adjust either red or blue horizontally or vertically an IC replacement will be needed. Your set uses (1) SANYO stk393-110 and you want to make sure it's SANYO and not a knock off brand as those usually fail prematurely.
Jan 23, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi HDTV 1080, model WS-55511. Color convergence is off but only on the outsides of the screen; in the center it is fine. Can this be fixed or do I need to replace the television?
Yes, it can be repaired, replace convergence out chips (two ICs) on main board.
If you are not comfortable with TV repair or have no experience, call local tech to fix it. Cost of repair would be $180 or so.
Nov 11, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Color is off on my tv im seeing colored shadows how do i reset that without a remote
Ok, it is a Mitsubishi-I see you have posted it here two times with different model numbers.
What is actual model number of your set--It sounds like a convergence problem and I can tell you what exactly is needed to fix it.
get back to me.
sd tech
Nov 09, 2009 | Mitsubishi WS-55511 55" Rear Projection...
I have taken the back off and cleaned everything and i am still having an out of alignment coloring on the outsides of my tv. the middle is perfect bet the outsides, mainly the left side(my right facing...
Post shows its Mitsubishi WS-55511 TV, if that's correct then check convergence section for dry solder joints and resold these joints. Specially check convergence out ICs pins.
Below is an exploded image of main board of TV and convergence area is marked to have an idea...
Let me know if problem remains to check further options.
Thanks.
Jul 13, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55511
Good Day;
Sounds like you have bad Convergence Output IC > 267P155010 > STK393-110, replace and it will correct the problem TV uses only ONE, make sure all resistors look good in the circuit around IC.
Sep 19, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Blue color shadow problem
Redo crosshairs. If they don't move, replace the conv ICs.
Mr Bob
Jan 30, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Three color dots
check out self test first, look at threads here or ctechnicians.com
Dec 31, 2007 | Mitsubishi WS-55511 55" Rear Projection...
Gaming on a Mitsubishi WS-55511
MetCom, you can use a video game on any rear projection big screen, heres the issue you DO have to be aware of, if you PAUSE the video game for prolonged periods of time it will PERMANENTLY damage all 3 picture tubes in the tv, so heres the trick, when you need to pause the game for more than 2-3 minutes just shut the tv OFF, you`ll never hurt the tubes this way because they aren`t on, when you come back to the game turn on your tv, un-pause the game and "life is good", been doing it for years and I`m a tv tech so trust me and now you know the real answer, pass it on to others and enjoy, BMW Rider
Dec 28, 2007 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
97 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
