HP Photosmart C7280 All -In_one---can't get it to scan
I need to scan something and when I scroll down to Scan to Computer I get a message that says: Refer to device documentation to troubleshoot. I read the guidebook, however, I do not see a solution to this problem. I would expect it to ask me to scan to my computer which is set up as the default, but this isn't happening.
Please help.
Thanks!
    Novelist:
  • 180 Answers
1. Tried opening HP Solution Center
2. Try scanning using the solution center
3. If you still unable to scan using the HP Solution Center try to check if there is Digital Imaging Monitor in the lower part of your screen. If you can not see it download the scan diagnostic utility.
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=oj-45265-1&jumpid=reg_R1002_USEN
Note : do not save the software. Just run it. If it still unable to solve your problem.
4. Click on start and go to control panel. Under control panel go to scanners and cameras. Try testing the scanners and cameras. If it works try restarting your computer and then try to scan.
5. Try to scan using a shorcut from the hp software. Right click on MyComputer and open it. Open C drive and go to ProgramFiles. go to HP and then go to bin folder. Under bin folder look for hpqscnvw.exe and try scanning using the software. If you are satisfied using the program you can put a shorcut of it in your desktop. If you are unable to scan using that program.
6. Uninstall the software using the CD. Do not use the uninstall button on the cd software. Once the installation screen would come up just click on exit. Open MyComputer and then explore the CD software. Under the CD look for the "util" folder and under it look for "CCC" folder. If you are connecting the printer using a usb cable unplug it. Then uninstall the software using the Uninstall l1, l2, l3 and l4. After uninstallation put a check mark on restart later and click ok.
7. Close all the programs you have open.
8. Click on start and then Contro Panel. Go to Add/Remove Programs. If there is an entry for the printer software uninstall it. After uninstalling it close the programs being opened.
9. Click on start and then Control Panel. Go to printers. If there is an icon for the printer delete it. Right click anywhere in the printer folder screen and then select server properties. Click on port tab. If you see their a port for your printer delete it. Click on the driver tab. If you see their a driver for the printer delete it.
10. Close all the programs.
11. Remove registry entries for the printer
11a. click on start and then click on run. Type in there regedit.
11b. create a back up registry by right clicking on computer and select export. The file name for the backup registry should be HPBackUp and save it on your desktop.
11c. After creating a backup registry. Delete printer entries. Click on the computer. Then Press and hold CTRL button and then f. A new window would open up. Make sure that in that window only the first and last option have a check mark. On the search box type in their printers. and then press enter. It will search for printer folder and under printer folder if you see there an entry for the printer delete it. Keep searching "printers" folders until you have completely remove the entry for the printer.
12. Download the software of your printer in the website. www.hp.com/support
13. Install the software again
14. Try scanning afterwards using the HP Solution Center
Posted on Aug 11, 2008
Can not scan to mac computer from hp c7280. What should I do? I need to know how to scan hp c7280 to my imac computer. I receive the message "refer to device documentation to troubleshoot." ...
There are multiple ways to use the scanner on your Mac. If your Mac recognizes the scanner as a device, then you can use the scan from the Mac using Preview or Image Capture apps (in your Applications folder). You can also use Picasa by going to the import function and finding the scanner and try it from there. If you are having issues getting the HP scanner to recognize the Apple device. Here is the official website for the download from HP. Apple drivers sometimes do the job of getting the scanner to be recognized, but the official drivers might do better.
Mar 02, 2011 | HP Photosmart C7280 Printer
HP Photosmart c7280 all in one can't be found
Assuming its all connected and powered up, try re-installing the drivers.
Jul 21, 2010 | HP Office Equipment & Supplies
When trying to scan a photo from the c7280 to the computer the printer displays the following error message No Scan Options : refer to documentation and troubleshoot. This is not covered in my printer...
That's because it's not a printer problem. The scan options are in your computer in the scanning software for your machine. Before you can scan you need to be connected to your computer with scan software running to tell it how to scan, what you're scanning, and where to send and save the image you scan.
Apr 20, 2010 | HP Photosmart C7280 Laser Printer
Can not scan to my computer
Scanning thru a wireless connection is not supported on these printers. Printing does not require that much data to be sent back to the computer, scanning of course does. Printers require a bi-directional signal path to allow scanning such as USB and parallel ports. Sorry to be the barer of bad news.
Buddy
Corporate Computer
Over 21 years supporting/repairing PCs and printers
Jun 18, 2009 | HP Photosmart C7280 Laser Printer
Can't scan to computer
I am not an expert, only a c7280 user. I use my printer wirelessly and was having problem scanning when using the controls directly on the printer (scan menu). By trial and error, I tried scanning by going to HP solution center on my computer and just followed the directions from the scan menu. That worked. If you can print wirelessly, you can scan wirelessly. I agree the HP support is a huge waste of time. I only get mad talking to them.
Apr 16, 2009 | HP Photosmart C7280 Printer
Should be in the HP print centre software on your computer
Apr 13, 2009 | HP Photosmart C7280 Printer
My C7280 HP photosmart will not scan to my computer.  I get the message "no scan options"
I have had a similar problem that appeared soon after an automatic HP software update over the internet. I solved the problem by uninstalling and reinstalling the HP software that came with the CD. I inserted the CD and ran the de-install for only the program that controlled print and scan and then re-installed the software for print and scan. Straight afterwards, the scanning started to work again
Dec 15, 2008 | HP Photosmart C7280 Laser Printer
638 people viewed this question
jasbo
jasbo
