Question about Hyundai ImageQuest DPD4210 42 in. HD-Ready Plasma Television
Power supply where is the power supply located at in the 4210? Is it the whole board or just a small part?
  • darealjermzz Aug 10, 2008
    is the power supply on the 4210 the whole board or just a little thing
Hi its the big board right in the middle ceramic resistors the big oblong white things are most troblesome measure there value out of can buy a board of ebay 125.00 cheers chris.
Posted on Dec 04, 2008
Hi, I have a Sansui SV-4210 LCD HDMI TV . It does not switch on with the remote and only works once I unplugged the power cable and plug it back again. Lately it occurs every time and I have to do th
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Sep 20, 2014 | Sansui Televison & Video
First thing you should do is to invest in a really good surge protector for your TV. Then when you replace the capacitor again use a good capacitor. Cheaper is not always better. Rubycon seems to do the best for me. There may be other suggestions, however I have the best luck with them.
Apr 03, 2013 | Computers & Internet
Sony KDL flat screen tv broke during a ligtening storm. I'm certain it was caused by the storm because our satellite dish was also damaged. Unfortunately the tv was plugged directly into the wall--not...
The tv power supply board it is dead 100% it is dead that board where the tv power a/c plug into it.Sometimes u get a burn or a chart coal marks if the power surge have big enough charges to the board,not it still kills board too because electromagnatic charges of the storm kills every electronic parts in came in contact with.Take the tv aparts.The tv power supply board are alway the one these two boards are the causes alway and the first board to dies .Replaced the tv power supply board first.Tv should work now,if not the main tv Tuner signal board it is also dead too.That the board where the incomming broadcasting signal wire plug into it.Tries websites like, to buy a whole refurbish power supply board for the replacement first and also the main tv Tuner signal board too,if necessary.70-80% changes the power supply board and necessary the main tv Tuner signal boad too tv should work again.20% sometimes the whole tv it fries and a total lost.
Aug 31, 2011 | Sony KDL32L5000 32 in. LCD HDTV
Just moved, i plugged it in but it doesnt start. at the back i see a small green light which means that there is power.
power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like, to buy a whole refurbish power supply board for the replacement.
Hoping that this will help to solve the problem...
Aug 11, 2011 | Televison & Video
Power supply
I hope I can help you with your issue,
Either the power supply has an issue , or you have a bad buffer board and Ysus scan board or light indicating may mean power supply , 7 blinks the buffers and y board.
A repairman will usually just order the boards and you will spend about $550-$600 on the power supply or over $700 probably around $850 if its the Y board and buffers.
It could be just a few bad capacitors on the Power Supply, there could be a bad capacitor on the Y board if its bad it needs to be replaced with the buffers together
If you want to attempt the repair yourself you can do a visual of the power board caps will appear swollen on top.
The ones you are looking for are located almost center bottom of the power board,Usually I can see them clearly with the back on simply shining a light into the back through the holes
With the back removed you will see a few circuit boards the upper one (ac cord runs to it through a small board) is the power supply, it has a lot of capacitors on it (cylindrical standing straight up soldered in and marked on the sides with the positive/negative sides and uf and Volts values)
Philips uses 2200uf or 3300uf at 35Volts rating capacitors, they cost about 1dollar-2dollar each
The power board and back unscrew with a torx bit and screwdriver size 10 and 15 , if you do not know how to desolder and resolder then do not attempt this as you may damage the TV more than fix it.
We do not recommend do it yourself, but depending on your knowledge and technical ability you may be able to.
You can replace the whole power supply,
Hope this help in solving the problem.....
Jan 18, 2011 | LG 37LG30 37 in. LCD HDTV
No power, no lights, no nothing. And sometimes makes a small "clicking" noise when plugged in.
Ur DM power supply board have alots of dead capacitors.U have soldering tools and understanding basic electronic's.Take the tv aparts,take out the DM power supply board.These dead capacitors are alway bulges up on it tops or puff up on it tops.Replaced all these dead capacitors,ur tv will get it power up,stable and work again.Or try website like to buy a whole refurbish power supply board for the replacement.
Jun 24, 2010 | Hitachi 50UX57B 50" Rear Projection...
My emachine 4210 powers up but it cuts it sefl off
Check the power cable connections and make sure they are tight. If they are ok then i would say you have a bad power supply.
Jan 25, 2010 | E-Machines T3958 (827103050974) PC Desktop
Techwood plasma twp 4210 broke
First make sure to hit the menu button on the TV's remote and if nothing is there then friend while the set is on turn a bright flashlight on and shine at angle into the set push the TV menu button if you can see a image then your back light is not working.
You can also check the transformers they are close to were the wires plug into the panel, make sure all transformers read the same amount of resistance if not you have found a bad one. Now you will have to check to see if the power supply is sending 24v to the backlight, if not the power supply is bad. Cost backlights around 150.00 and power supplies around 100.00. Well this should help you friend.
Dec 07, 2009 | Televison & Video
Power supply problems
Have ordered a new power supply PCB as too many parts need replacement. Best to buy the whole lot.
Ventilation seems to be an issue with this unit, I am thinking of installing a small fan at the back to cool the voltage regulator and main transformer.
Jul 07, 2009 | Televison & Video
Plasma tv techwood 4210
hi the most common fault on this tv is what you describe .i fixed mine by replacing the capacitor (1uf 630vdc) at location c19 on the power board .. cost for this component less than 90p
Oct 11, 2007 | Televison & Video
Hyundai ImageQuest DPD4210 42 in. HD-Ready Plasma Television Logo
140 people viewed this question
Top Hyundai Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jay Seifried
Level 1 Expert
Are you a Hyundai Televison and Video Expert? Answer questions, earn points and help others
