Question about Whirlpool Washing Machines
Whirlpool Clean Touch Model LSC8245 will agitate but will not drain or spin.
  • 641 Answers
SOURCE: Whirlpool Ultimate Care HD Plus Model #LSR8233EQ0 won't agitate or spin
It sound like a belt issue. Open machine's cover and check that belt is not broken. Good luck!
Posted on Aug 04, 2007
fixinit4me
  • 10 Answers
SOURCE: Washer won't spin or drain.
This site may help:
http://www.repairclinic.com/0088_11_1.asp
Posted on Oct 28, 2007
jsrock516
  • 5911 Answers
SOURCE: My Estate by Whirlpool Corp. TAWX700JQ3 will fill up no drain,spi
The problem is usually related to a lid switch malfunction. The lid switch is located under the right-hand side of the tub rim and is activated by a small plastic piece on the lid, called a "lid strike". First, make sure the lid strike is not broken off. Second, double check the two mounting screws that hold the lid switch in place along the tub rim opening on the right-hand side. Sometimes, all that is required is to tighten the screws that hold the switch in place to realign it with the lid strike. If all parts are in place, open and shut the lid. You should hear a distinctive "clicking" sound indicating the switch is activating. If the switch still does not work, replace it. The following link explains:
http://www.fixya.com/support/r397101-replacing_lid_switch
A replacement switch can be purchased on line at searspartsdirect.com. Just type in your model number and look under the "Top and Cabinet" heading. The lid switch is listed as item number 9 and the lid strike is listed as item number 20. If you're exact model number is not shown, any of the listed models will do. The part numbers are still the same. You can also try any of the following other websources: repairclinic.com, pcappliancerepair.com and appliancepartspros.com. They all offer great service and competitive pricing. I hope you find this information helpful. Let me know if you have further questions.
Posted on Dec 18, 2008
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Posted on Jun 02, 2009
  • 82 Answers
SOURCE: Washing Machine wont spin/agitate
The most common problem is the lid switch. with a screw driver in hand open the lid and press down on the lid switch. sometimes the mounting screws will crack the switch housing and the striker can't move the actuator far enough. I am interested in the clicking noise, as this could indicate a pump issue or a sock seizing up the tub.
Posted on Jun 14, 2009
I have a top loading washing machine that will fill with water but then won´t agitate the clothes. If I turn it off and then manually put it on the spin cycle it will drain and spin just fine. None...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
This problem points to a couple of places:
The first unfortunately is the motor. Kenmore / Whirlpool top load direct drive washers use a reversing motor.
When in agitate mode, the motor turn one way, When in spin mode it turns the other way for draining and spinning.
I'd check the following first before assuming that it's the motor though.
First, I'd pull the agitators and check for worn or damaged splines inside the agitator or on the agitator shaft.
Following is a description of how to take them out.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the agitator and shaft are OK, the problem may be in the transmission.
See the following Whirlpool / Kenmore installation and service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
I'd also look at the troubleshooting section of the manual and check how to test the motor.
Starting at page 10, you'll see a description of how the transmission changes from agitate to spin mode.
The key (and likely problem) is the "agitator spring".
The spring holds the agitate gear down so that the two sets of splines on the agitate gear are connected and the agitate rack can turn the agitators.
See the following Whirlpool parts list for a blow-up of the transmission and how the various gears and springs connect.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
See the following for how to remove the transmission and clutch.
Tearing apart the transmission is a bit messy but if the problem is the spring or agitate cams, it's a lot less expensive to fix than a $170 transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover and drain the oil.
Pull off the spin pinion.
Carefully remove the clip that holds the main Spin Gear on and remove it.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
Check the spring, Agitate Cams and the cams in the Neutral Drain Assembly.
Re-assembly is obviously the reverse of taking it apart.
If you're reasonably comfortable with tools you can fix it yourself.
When we had a problem with ours, we ended up spending less than $30 replacing the agitate cams, neutral drain assembly and oil instead of $170 for a transmission. It was worth fixing.
As an aside, tearing the washer apart will give you the opportunity to completely clean it.
Apr 05, 2010 | Washing Machines
Agitator not working
You should be able to see the model number by lifting the lid and looking to the back of the washer. It likely starts with a 110.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=21&osCsid=24ab6056160f539e3df54ad2ca6c44de
I'd also look at the troubleshooting section of the manual.
In answer to your other questions:
Jan 18, 2010 | Kenmore 22422 Top Load Washer
Agitator just stop working. Spin cycle will run. Rinse will drain the water, add new water, but the Agitator will not work. Do you have any ideas? Do you know how old the machine is?
$FILE/L-55.pdf
As an aside, tearing the washer apart will give you the opportunity to completely clean it..
As to the age of the washer. Whirlpool / Kenmore washers use a part of the serial number to determine the year the washer was made..
Jan 11, 2010 | Kenmore 23822 Top Load Washer
Agitator does not move, I all ready replaced the coupler, but now agitator does not turn
Dec 04, 2009 | Kenmore 23822 Top Load Washer
Washer agitator does not work (turns free)
Nov 25, 2009 | Kenmore 24932 Top Load Washer
Whirlpool Washer not drain, with clicking noise
If it has a filter, clean it out and start again
Mar 15, 2017 | Whirlpool LSR7333 Top Load Washer
I have a Whirlpool Washer Model LXR6232EQ0. Yesterday something happened after it drained during the rinse cycle. It wouldn't spin. It makes a noise like the moter is trying to spin but there is a slight...
I have a Whirlpool Washer Model LXR6232EQ0. Yesterday something happened after it drained during the rinse cycle. It wouldn't spin. It makes a noise like the moter is trying to spin but there is a slight tinkle once in a while. Could it be the motor coupling or do you think it is the clutch. The agitator doesn't spin at all. does it have a belt?
Mar 17, 2009 | Whirlpool Washing Machines
WATER FILLS AND DRAINS BUT DOES NOT AGITATAE OR SPIN
motor coupler is goingto be the issue, easy enough to replace, you can find a video on you tube, search "whirlpool motor coupling"
Jan 25, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirpool washer LSN8244AQ0 motor spins but agitator does not move.
Ok this is a old school machine. Have a look at the drawing below. So no agitation or spin? How about the pump, does it drain? Now if it drains and thatis it then item 13 below is a coupler that is probably out. You can pull the machine out and tilt it back and using a flashlight examine for black dust and touch to see if it is soft in spots and the two white flanges are intact. You may have to remove the pump and motor to inspect.Use part 285753A .
Oct 14, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
146 people viewed this question
Dan Webster
Dan Webster
Sal De
