Question about Cooktops
Electronic ignition not working
Stove was working fine and then the burners just won't light when I turn it on. There's no clicking any more but I still smell gas. I can light the burners manually although when I turn to LOW or WARM they tend to go out. I can't find replacement ignition switches for my Sterling cooktop Model No. GCT360, manufactured in 1988. The company in UK does not respond to my inquiry, while the Sterling Service Center in Sharon, Massachusetts has apparently gone out of business.
  • jbee123 Oct 01, 2008
    I'm trying to find parts for a sterling gtc360. Looking for the burner igniter. anyone know how to get parts or is there a generic/other mfg part that is the same?
SOURCE:
SOURCE: Clicking noise on cooktop even when all burners ignite
Jsut a guess - see this solution: http://www.fixya.com/support/t119696-constant_clicking_when_turned
Posted on Mar 31, 2007
SOURCE: cooktop's electronic igniter started clicking all by itself
If any of the 5 burner switches are sending a signal to the spark module to light a burner, most gas cooktops have a wire from each burner control to the spark module to send a spark to all burners. Shut the power off, pull the wires off from each control to the spark module control and reapply power . Test each one at a time to determine which is the culprit. Could be more than one but usually only one.
Posted on Jul 25, 2007
  • 213 Answers
SOURCE: Thermador Gas Cooktop Won't Stop Clicking : SGC304RS
theres a part in the cooktop called a spark modual. replace it. when i goes bad the problem your having is what it causes
Posted on Nov 30, 2007
  • 150 Answers
SOURCE: igniters are not working right
when you turn any burner control to lite all ignitors should click this is normal industry wide. the ignitors are controlled by switches that are placed over the valve shafts they are wired up together so thats why they all click when you only operate one valve don't worry about it. the ignitor stays on untill you back the valve off a tad this is also normal.
Posted on Apr 23, 2008
  • 3 Answers
SOURCE: Our Dacor gas cooktop igniter won't click.
Go to RepairClinic.com and check on how much a new igniter is. Is there two or 4 igniters on your model (lift the top of the range up and it is the little silver piece sticking out with a white base around it), If its 2 is the other side working? Make sure there is no food deposits around where the gas and the spark meet.
Posted on May 01, 2009
Electronic ignitor on propane stove wont start
  1. Close all valves, including the one on the supply tank.
  2. Open valves SLOWLY starting with the tank. Safety valves are built in to prevent escape og gas if vales are broken off.
  3. Turn on ONE burner valve and, depening on the ignition type of your stove, light it. (some have an electric spark generated by a power outlet (120v) and make a sort of poping sound, some have a spark generated by a push button type mechanism.
  4. Once one burner lights, the others should light easily. Sometimes air gets in the lines, and this may have to bleed off, but it should only take a few seconds. -PS, make sure the stove is level, since gas tends to flow to the high spot.
Feb 20, 2014 | Frigidaire Stove/Oven/Range White Cooktop...
Constant clicking from electric pilot connection. won't stop after leaving for long time, unplugging overnight, cleaning all burners, running gas by lighting with match and letting the flame run. ...
Hi nancypp,
The ignition switches probably got wet.
Please follow my below Tip on how to fix it:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 04, 2011 | KitchenAid Cooktops
Electronic ignition is not working on one burner of my gas cooktop CG 206. Can this be fixed?
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Mar 21, 2011 | Jenn-Air Cooktops
I have a Wolf gourmet 30" stove. it's about 10
Interesting, I'm looking for a solution to a similar issue. Our new (7 month old) 30'' Wolf Range has this issue. When both front burners are light, the back burner's electronic starter begins to click, but only when you put a pan on the front left burner. I believe the iron/steel in the pan is causing a magnetic field thats starting the rear burner to go off.. just don't know.. will report back after the repair person comes.
Jan 22, 2011 | Wolf Range 18 in. SPR-100 Gas Cooktop
On our 6 burner gas coocktop, the right two burners don't light
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 10, 2010 | Thermador SGS36GS Gas Cooktop
Miele KM 3474 stove top lights but turns off after 30 seconds
Does the burner attempt to re-ignite after it goes out? If so, it's probably the therocouple. If not, it could be the burner valve. Be sure the caps and rings are correctly seated on the burners and be sure to firmly press the burner knob down to start the flame.
Feb 04, 2010 | Miele 36 in. KM3474 Gas Cooktop
Burner won't light
hi gud day,i think the sensor is we have problem is hard to repair in ur own,try to call the person have expireince for repair that unit, or ur igniter ligther have damage like small broken if u hear have click is ok but much better to check the igniter coz the broken igniter is not directly spark in the burner that why is not light.to check if remove the burner base cover then see if the igniter like a small niddle color white,turn the knob to click the igniter then see it wer the spark directly if u not see it means have a broken igniter.
tns gerbee
May 26, 2009 | Amana AKS3040 Gas Cooktop
Constant sparking
I don't have a Thermador cooktop but here is ma taught.
Could you unplug the two faulty igniters and see if problem remained
Could you plug one of the faulty igniter at the location of a good one. The goal is to isolate the problem. Is it the igniter or the electronic board.
Faulty ground problem may occur also after an spillover on the stove. In that case, use a cotton swab dipped in scrubbing alcool and clean the spark area on the igniter and the burner.
Good luck
Mar 31, 2017 | KitchenAid 31 in. KGCC505 Gas Cooktop
Stove-top burners
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
bvn
Jul 10, 2008 | Belling 27 in. CTC465 Electric Cooktop
Cooktops Logo
237 people viewed this question
Top Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
