Question about Car Audio & Video
MY AMPPLIFIER KEEPS BLOWING THE FUSES WHEN IT REACHES HIGH VOL. i HAVE IT BRIDGED WITH THREE 10" SPEAKERS.
    Problem Solver:
  • 17 Answers
LOOK THE SPEAKER AND IMPEDANCE WILL SAME TO OUTPUT OF AMPLIFIER OR LOOK FOR THE OTHER SPEAKER WHICH MORE IMPEDANCE,FOR EXAMPLE ,IF YOUR SPEAKER HAVE 4 OHM PUT THE SPEAKER IN SERIE FOR INCREASER THE IMPEDANCE,NEVER CHANGE THE FUSE FOR A TO HIGT.
Posted on Aug 10, 2008
10' canam outlander 650, keeps blowing injector fuse. Check engine, DPS, and low batt amp warning comes on first, any ideas? Doesn't restart with out jump and new fuse.
amp blowing fuses ' High Lifter Forums
forum.highlifter.com > ... > [Most Popular Discussions] > ATV Accessories
Dec 31, 2007 - 2006 Can-Am Outlander 650XT Bombardier ... RE: amp blowing fusesMonday, December 31, 2007 10:31 PM (permalink). I want to use an ...
Aug 30, 2015 | Cars & Trucks
My subwoofers cut out after 30 seconds of use but work fine during the 30 seconds...my fuses are all fine and i'm running thick wire with an 80 amp fuse connected off battery...I have a lanzar vibe286...
If it's only your subwoofers cutting out and your speakers are still playing and all, try turning gain down on sub amp and see if that fixes it. I know if I crank my amp too high it kicks itself off to try to keep itself from blowing.
Aug 21, 2011 | Car Audio & Video
Our sound system runs two separate xl 5000 crowns individually to 2 srx728 subs(2241hpl speakers). Amps are run bridged and have been connected to "discrete" inputs on cabinets (I think this is...
More than likely you have lost the speakers... You sent TOO much power to them and likely the voice coils have heated and distorted and are rubbing the pole pieces and hanging up on them. If the voice coils now short some of the windings, next you will lose your amps as well. If you can access the cones, you can try gently moving them in and out with your fingers and you can feel the voice coils rubbing sometimes. REMEMBER ALWAYS check the RMS rating of the speakers against the RMS ratings of the amps... DO NOT fall for the "advertising" things of "peak power" and "program power" ratings... these numbers are to sell equipment... Use RMS continuous ratings when sizing amps to speakers. Typically the RMS continuous ratings are 1/3 of the peak or 1/2 of the program ratings. You will find amplifiers rated either way so you have to dig out the real ratings. In bridged mode the full output of both halves of the amp work together. Your speakers are rated at 1600 Watts continuous... I am not sure I believe that number even... you would be deaf in front of that quickly... Your amps appear to deliver 5000 Watts RMS in bridged mode... over three times what the speaker is rated at. Since you have the amps, set one aside and run each speaker from one side of a single amp NOT using full gain AFTER you get the speakers re-coned. I would recommend putting a fuse in the speaker lead to HELP protect the speakers when repaired.
Aug 12, 2011 | Jbl Srx728s Dual 18" High Power Subwoofer
It keeps blowing fuses - two 12 inch cls subs 1
sounds like the audio stage riving the channel has a short circuit on it.need to go through the amp stage
Jul 16, 2009 | Cerwin Vega CLSC-12S Subwoofer
Amp blowing fuses
Your amp is blowing fuses to protect your circuit. The type of 12V battery does not matter. For whatever reason you are over driving the amp. 2 Ohms sounds like a very low impedance for a car amplifier output. I am assuming you have the two 12" speakers wired in parallel. Most are rated at 4 Ohms which means you are pulling twice the current with the 2 Ohm load. Also, the bigger the speaker, the bigger the magnet, the bigger the coil, the larger the inductance, the heavier the load. Make sure these speakers are matched with your amp. A small amp driving large speakers will shut down at high volumes. Try putting them in different channels. Good Luck.
Jun 17, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Ac fuse blowing, high suction pressure
Were the fuses blowing before you started charging the unit?
It sounds like you are overcharging it.
Apr 26, 2009 | Heating & Cooling
Amp keeps blowin the two 30amp fuses on the amp.
Make sure that the speaker wires are wired correct at both the amp and the speakers......otherwise it sounds like the typical death of a power acoustik amp (great amps, but prone to a premature death)
Mar 29, 2009 | Power Acoustik GOTHIC OV2-1200 Car Audio...
AMP PROBLEM
check ur speakers they can cause the short with vol
Aug 13, 2008 | Audio Players & Recorders
Repair service for AG1000 Zapco Amp.
Is it blowing the three 30 amp on-board fuses?
To have 3 speakers bridged, each speaker must have at least a 12 ohm impedance (assuming that all speakers are connected in parallel). If you're running a load lower than 4 ohms (mono), the amp will likely fail.
The fuses don't blow right away because they are cold at first. As they heat up, they can blow more easily (even though the current draw hasn't increased).
Aug 10, 2008 | Car Audio & Video
Speaker keeps blowing fuses
Sounds like a short circuit or a defect inside the circuitry that is allowing more power to flow through, thus blowing the fuse. My advice would be to dispose of these speakers for safety reasons and invest in a good quality set.
Aug 29, 2006 | Recoton Advent Advent AV570 Computer...
Car Audio & Video Logo
53 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
