Question about Sony XM-2165GTX Car Audio Amplifier
My xplod amp gets power
But there is no sound n ive connected many amps and its all hooked up the right way. so if u can help me let me kno please. and by the way wat does btl mean?
  • robveg87 Aug 12, 2008
    i used the amp on two different sets of subs n the second set was the one in my car n they def still work!! n the power supply should have been good because i used all of my own wiring n my amp is still workin after i switched the Xplod out. so i dont kno if theres sumting wrong internally or if i need to bridge the amp or wat. by the way i dont kno how to bridge an amp! HELP ME WIT THIS CRAZY AMP!!! if not i have an amp for sale lmao
  • 631 Answers
If the power light is lit and the amp is not in protect mode, the power supply is probably blown.
Have you confirmed that you have a good signal reaching the amp and that the speakers are not blown?
Posted on Aug 11, 2008
  • Perry Babin Aug 12, 2008
    The 'power supply' to which I was referring is the switching power supply inside the amplifier.
    On the Sony amp, you'll use the two BTL terminals for bridging but you MUST make sure that the speakers are wired so that the impedance is safe for the amp.
    BTL = Balanced Transformer-Less.
800 watt mono block sony xplod amp blowing my dual coil 1500 watt subs
if the wiring to the sub is correct, then you have something wrong with the amp itself... something is power surging to the subs which is causing them to blow
Aug 25, 2012 | Car Audio & Video
I have a Sony Xplod 800w Amp running a 10' Sony Xplod Amp....i unhooked the amp to do some moving and i tried to put it back in today and it didnt have any sound coming from it! I did notice the power...
it sounds like it could be a blown channel in the amp. if the sub was blown it would still work just sound horrible. i have blown many subs and amps. you can bring it to an audio shop near you and they can fix it. i just got one of my channels fixed for 35$
May 11, 2011 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
I have a sony xplod 1000 watt amp.ive had it hooked up for about 6 months it sounded great.this morning i started the truck up and wasnt working looked at it and my compassador was blinking.i hooked it up...
The Capacitor block was blinking because the device it was supplying a filtered DC voltage to was drawing a lot of current. Your amp has a fault somewhere, more than likely the power stage. Could be a shorted output transistor.
Nov 26, 2009 | Car Audio & Video
No sound to the subs
Possible solution: Check to make sure your ground connection is connected to metal that is NOT covered in paint. This is not a solid connection and can ruin your amp over time. Simply scrap away the paint and re-connect. This was a problem i ran into recently.
Jul 27, 2009 | Sony XPlod CD Player w/MP3 Playback...
Hi i have a 600 watt sony xplod amp model xm-554zr and it recently stopped working. when i turn my car on the amp turns on but only for a sec then the protection light comes on, on the amp and it wont...
sounds like maybe a speaker short, try unhooking your speakers and then powering up your amp, if it then powers up with the speakers unhooked try hooking up each speaker one by one untill the amp goes back into protection and then you have your bad speaker.
Mar 08, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Subs sound terrible (Ive tried so many things)
NO it won't be your battery. Sounds more like your deck.
Jan 22, 2009 | Jl Audio 12W3 Car Subwoofer
Subs and amp problems
make sure you have the wires from the amp to the box, and the box to the subs hooked up right... red is positive black is negative
Dec 28, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Sony amp 1000w
Check the wiring of the speakers (both inside the box and between the box and the amp). It sounds like one speaker is wired incorrectly at one connection point.
Sep 09, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony Xplod 1200w
Either the speaker is shorted out (blown), or the output transistors in the amplifier are bad. Try hooking up another speaker to the amp. If it plays, the amp is good. If not, then the amp is bad.
May 22, 2008 | Sony XM-1252GTR Car Audio Amplifier
Sony Xplod 500w green power light no sound
try running the system with a cross-over configuration.
So your left + will be left + and your right + will be in the right + but put the right (-) where the left (-) is and left (-) where the right (-) is. If that doesnt work, then that means that you shorted out your audio out channels. the only way you can fix that is if you have good soldering skills. But other than that I'de say scrap it, unless you have the high outputs and then buy another amp, some mids and highs and connect the mids and highs to the xplod
Feb 23, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony XM-2165GTX Car Audio Amplifier Logo
163 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
