Question about Nintendo Wii Console
Getting on line
I search for an acess point it finds my 2wire but it says its secured but iam not
  • 20 Answers
It is, theres a default password for the 2wire on the bottom as a 10-digit number in brackets.
Posted on Jul 12, 2009
6ya staff
SOURCE:
Compaq Laptop Windows 7 Acess Point Problem att 2wire
use wired Ethernet, so it works. easy.
wifi is far more complex.
best is to own the router, you have.
then login to it and set it up for wpa./wpa2
wep off.
and a nice password for wifi so others cant hack it. in the hood.
then use those credentials all all your toys. xbox, PCs and cell.
that is the best way
the access point is covered in you manual for the router
there is AP button there, you push.
the PC in question my guess is the drivers are no good.
missing wrong, or corrupted.
no PC full model stated.
no OS stated
no router stated.
so answers will be weak to wrong,.
Oct 29, 2017 | Compaq Computers & Internet
Hi,Iam with aircel chennai.Iam using N73 mobile for past 3years & now i had activated 3g on my mobile.whnwver i go to connect youtube it is opening with Real player option automatically & iam...
Get into your N73's Internet settings and use these information:
Aircel GPRS settings
  • Homepage : Whichever you want
  • User Name :Blank
  • Password :Blank
  • Use preferred Access Point :aircelgprs
  • Open Access Point Setting
  • Proxy:Enabled
  • Proxy address :192.168.035.201
  • Port :8081
  • Data Bearer : Packet Data
or
call the toll free number of Aircel and ask them to send you the internet settings to your phone.
Mar 21, 2011 | Nokia N73 Cellular Phone
Where and how do i find my access point I'am trying to set up a wireless internet connection
Hi Kregerbc,
If you want to know your Access Point it is the Name of your Network or Network Key (SSID). Usually the Network Name of 2wire router is 2WIRE and the Last 3 digits of the Serial Number of the Router. The Serial Number is located at the side of the router you will find a Sticker and look for the Serail Number you can also see there the Wireless Network Key under the Bar Code. Another Procedure to find the information of the router is to access it. listed below are the steps on how to access the router.
  • Open a Web browser and type http://gateway.2wire.net or http://192.168.1.254; the 2Wire Home page opens.
  • Click the Home Networking tab at the top of the 2Wire Home page.
  • Click on Wireless Settings. then click EDIT SETTINGS located on the right panel.
  • Here you will be able to fine the setting for your Wireless Connection
  • You can change the SSID, Wireless Channel, Wireless Security, and Network Key
Rate me if this helps so i can help others
Thanks for using Fixya.
Feb 04, 2011 | 2wire (2701HG-B) Wireless Router
Router
only if you have a program disc to use
try this website to download the driver as needed
http://www.opendrivers.com/company/27712/2wire-free-driver-download.html
Jul 12, 2010 | 2wire Wireless-G 802.11g ADSL Gateway
Okay so im trying to use my dsi's internet and it says something (i forget what but thats not it)anyways i got to connection settings and put my password for the internet thing then i go to save and run...
if your using search for acess point it will find your own acess if you put manual setup it has 99% posibility that the error happens if it says no acces point in range move closer to your computer and it may work if it doesnt it means theres a problem with the telephone line so tell a fixer for the telephone line to help or tell your parents
Feb 04, 2010 | Nintendo DSi Black Console
I have reached the point in setting up ROKU where I am advised on screen to "enter your security info". Where can I find that on the AT&T 2wire modem?
I believe that you have setup WEP/WPA encryption key to network, please contact your service provider to know the security key.
Regards
Rizwan
Jan 27, 2010 | Computers & Internet
Where is the security code to connect to the wireless gateway 2wire?
Usually you can find the security key for the wireless on a 2wire modem/router underneath it there's should be a 10 digit key in there as the wireless security key, if you cannot find it there you need to access the router setup page and it will be better if you can contact 2wire support to walk you through in getting that key from the router page..
Aug 10, 2009 | Gateway 56K Modem (Half Height) (1529412)
Need to find security codes for 2wire dskl
When you say security code do you mean you wireless password?
Jan 04, 2009 | AT&T High Speed DSL Modem
Switch from WEP to WPA wireless protocol
First have a computer directly plugged into the 2wire
Using windows xp: click on start> then run> then type "cmd" and hit enter.
Type "ipconfig" and hit enter.
You are looking for a default gateway address, usually "192.168.1.254" on 2wire gateways.
Skip the vista section if you are using xp
Using Windows Vista: click start> then click on the search bar and type "cmd" and hit enter.
Once you find the gateway address, you now have the website address you need to get to your 2wire. Open internet explorer and type that default gateway address in the address bar.
This should take you to a 2wire homepage. At the top click on the "home network" or "local network" tab at the top.
Once there, click on the wireless network link at the top. It will prompt for a password, if you do not know the password, click I forgot for a hint. Click I still cannot remember if the hint doesn't help, it will ask for a system key, which is a 10-digit number on the bottom of the 2wire.
After entering the password you will be in the wireless settings window where you can change the security type to any available that the 2wire has, if it doesn't have it available call the provider and see if they have a firmware upgrade available.
Nov 13, 2008 | Gateway Wireless-B Router (wbr-100)
I'm trying to find out on how to connect my other computer wireless to my 2wire. My other(desk top) has a linksys card in it. It was already setup for Linksys Broadband Router, wireless-G 2.4GHz 54Mbps. I...
Hello Art G.
The easiest way to get connected to your access point is by using the CD that came with the AP. If you don't have it, you have to get connected to the access point in order to get the WEP KEY.
If do you have the model of the Access point (2wire) i can help you with that.
Jul 04, 2008 | Computers & Internet
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
