There are two 110 volt supplies to an electic dryer. One supply will supply all operations of the dryer save half of the heater ckt. The heater requires both 110 supplys for heater operation. Check if one of your two 110 dryer breakers in your house is "tripped" to off. If it works when you trip it back on good, if it only works temporarily then trips again, suspect a bad heater element drawing too many amps. Another possiblity is a weak breaker in the house breaker box, but usually if you get a reoccuring breaker trip its the dryer heater element pulling too many amps. Hope this helps.
