Question about JVC GD-V4211PCE 42 in. Plasma Television
Loosing Picture I am loosing my picture to a milti coloured screen and have to keep switching it off an then on until it stops which is getting more frequent. I have looked to the DMTECH support pages regarding trying a EEPROM RESET, but my remote does not have the functions/buttons that is needed to perform this (IE. the 'line' button) Does anyone have a solution.? Thanks
Loosing picture
Posted on Nov 25, 2008
Keep loosing picture. Screen turns grey
What is the brand name and model number of your TV? If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Jan 11, 2017 | Televison & Video
Tip
Cathode emission check for colour picture tubes
<p>How to check the colour cathodes of a picture tube for emission<br /> <p> <br> <p>It is very easy to cehck the emission of the cathodes of a colour picture tube. Assuming all other circuit parts are working, including LOT [Line output Transformer] and video output section.<span> </SPAN>There is proper screen voltage; focus voltage and EHT [Extra High Tension]. Locate the three cathode points on the base card, usually marked as Gk, Bk and Rk.<span> </SPAN>Keep the brightness, contrast and colour control to zero position.<span> </SPAN>Take a wire of suitable length, say 50cms or so, tie its one end to TVs chasis [negative].<span> </SPAN>Take one resistor of value 100K 1W, tie its one end to the other end or the wire, thus one end of this resistor is now connected to negative chasis and the other end of it is free now.<span> </SPAN>Hold this resistor with with some electrically noncunductive material [using hand gloves will be better]; switch on the Tv, wait a minute or so to get it warm up.<span> </SPAN>Just make a touch at each cathode of the picture tube base card solderings.<span> </SPAN>Just one touch will give you a colour of the respecive cathode on the screen.<span> </SPAN>Never hold it for long time. This process can be used for checking cathode emission of any type of Cathode Ray Picture tubes. <br> <p>
on Apr 18, 2011 | Televison & Video
Tip
SONY TRINITRON ONE COLOUR PREDOMINANT SCREEN
Sony Trinitron sets are of CRT [Caothde Ray Tube] types. The common fault seen in these type of TVs are any one colour predominant on screen wih sound OK. Either red, blue or green colour with some thin horizontal lines at about an inch apart will be seen on the entire screen. This is totally a display card problem, which can be seen pluged onto the picutre tube neck. There are three electron guns for every picture tube, which emits red, blue, and green beams, which in turn illuminates the phosphor on the screen to get that colour. If no emission from all guns, results in a blank screen, ie black screen without any disply at all. The three colour beams together produces proper coloured picture what we see on screen. These three gun's terminals are brought out by pins of the picture tube outside to which video signals are given in appropriate proportion to produce a TV picture. Normally, all these three pins are biased with a voltage of about 170 to160VDC+ve. Take one colour gun, as an example and and let me describe the problem.
Let it be a green gun. These guns are called cathodes of the picture tube. If it gets a voltage with respect to its grid, it will emit electrons according to the voltage applied to it. This is a negative process, that is, as the voltage at this pin drops, its emisson incresses and vice versa. If the emission increase, the colour with respect to that gun also will increase and gets predominant at the screen. So when we see a green predominant screen, there will be less voltage at the green cathode with resepect to the other two. If red colour is predominant, the voltage at red cathode will be less than the other two. If blue colour is predominat, the voltage at the blue cathode will be less than the other two.
We must find out the reason for this fault first. Assume that your Tv has a red predominant screen with some thin lines across it, at about one inch apart of the entire screen, it is clear that the the red cathode voltage is very lower than the other two. the main reason for this fault, normally seen in most of the Sony Trinitron, are loose soldering points either to the picture tube base socket or the resistor connected between the red drive transistor's collector point. Resoldering the most of these points on the base card by applying a little more solder will rectify this probelm. Other possibility is shorted video output transistor of that cathode. A direct short [collector to emitter] of these transistors will drop volatge to very low at that respective cathode of the picture tube, and that colour will be pridominant along with lines. Replacing the transistor will solve the problem. In some cases, the resistor connected to that transistor may have blown out. If so, it should alo be replaced. Whatever the case may be, voltage at the respective cathode that emits colour will be very low with respect to the other two. Find out the reason and rectify it. You can compare the voltages of the other two cathodes with respect to the faulty colur cathode. Cathode pins will be marked on the base card, and can be identified. It is best to pull out the base card from the picture tube neck and place it somewhere a safe place without shorting it with other parts of the TV. You can measure the voltages of these points very easly, without fearing the damge to the picture tube. After all are found Ok, replug the base card and switch on the TV. The set will be alright. In rare cases, chroma IC also can be a reason for this fault. if it is faulty, after a short period after switch on the TV, the IC will overheat and shutdown the entire system.
on Mar 21, 2011 | Televison & Video
My Phillips 47 LCD TV is loosing picture but is keeping sound.
Main board feeds the t con board. However try the flash light test on set because it might just be the inverter board that powers the backlighting.
Mar 17, 2016 | Televison & Video
My tv picture freezes and coloured lines go across the screen
you are loosing digital signal, are you using cable or direct tv / dish?
Aug 14, 2014 | Televison & Video
Screen keeps loosing picture
When? Does it boot up to windows? What were you doing when it loses the picture? I assume you mean the screen is black when you say losing picture.
Apr 04, 2012 | Sony VAIO VGC-LV290J/S 24 in. PC Desktop
Sony bravia loosing the top and bottom of picture.
Try the aspect ratio button on the remote or it is possibly an on screen aspect adjus
Aug 08, 2009 | JVC LT42P789 42 in. LCD TV
DLP TV SHUT OFF, LOSS PICTURE,
Hi and welcome to fixya, it is the colour wheel problem,,,,,,,,,this is common problem please check it ...it may be also cathode ray tube... thank u.........
Jun 03, 2009 | Samsung HLS4676S Television
Blue Tint
Most likely cause would be a loose solder connection that expands as the set warms up until it no longer makes a connection. You may get the blue to come and go by hitting the side of the cabinet after the set is warmed up awhile. (don't hurt your hand doing this, and don't keep doing it to "fix" the set. The connection will have to be located and repaired). Otherwise, there could be a component going bad, including the blue picture tube.
Nov 21, 2006 | Samsung HCN473W 47" Rear Projection...
JVC GD-V4211PCE 42 in. Plasma Television Logo
201 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
