Question about Sony Cameras
My Sony Cyber Shot flashes what I think is an error message on all settings.....E91:01. The camera will not flash even in dark. Any ideas?
  • stevecatlin Aug 10, 2008
    Lost my manual so I don't know how to check to see if flash is enabled
    Solution offered is not helpful
    Master:
  • 623 Answers
Same problem on fixya solved click this link
www.fixya.com/support/t293797-e91_01_error_dsc_w50 - 29k
Posted on Aug 10, 2008
  • Sony Master
  • 13,433 Answers
A camera malfunction has occurred. Reset the camera, then turn the power on again
  • Sony Master
  • 6,487 Answers
Check this link it has a solution that work for other client before http://www.fixya.com/support/t293797-e91_01_error_dsc_w50
Hope that helps...........
    Sergeant:
    Champion:
  • 310 Answers
Check whether ur flash is enable or not.
My flash is set on always on but no flash?!
Set it on auto flash, go into a dark area and fire off a shot. If the flash doesn't fire, the flashtube is probably burned out or shorted out. In either case, you will need service.
Feb 16, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
Sony cyber-shot dsc-w50 problem
When “FLASH error” (Self-diagnosis Code E : 91 : ** ) occurs, to prevent any abnormal situation caused by high voltage, setting of the
flash is changed automatically to disabling charge and flash setting.
After fixing, this setting needs to be deactivated. Flash error code can be initialized by the operations on the Setup screen.
Method for Initializing the Flash Error Code
Initializes the setting to the default setting.
1 Select [OK] with v on the control button, then press z.
The message “Initialize all settings Ready?” appears.
2 Select [OK] with v, then press z.
The settings are reset to the default setting.
• Make sure that the power is not disconnected during resetting.
Jul 26, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Flash won't work and flash setting cannot be changed from menu
This is eather caused by a bad flash circuit or a bad mainboad. Repair cost around 65.00 to 75.00 to repair.
May 25, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Flash and dark photos
Perform Initialize option in camera menu,
if problem doesn't fix, camera needs Strobe Adjustment and this can be perform in Sony service center because it requires spacial tools.
Thank you.
Sep 21, 2008 | Sony Cyber-shot DSC-W35 Digital Camera
Hi I have a sony cyber shot dsc t20 and I get an error message flash settings cannot be changed whe I try and select another flash setting?
I had the same problem, and i tryed everything, even opening
the camera and see if any visible damage on any part (nothing), so
when i try initializing again ( menu>setup>option #1), right after the
"OK" over reseated date, i went to the Flash Button, and turn it off
and at least the annoying flashing error is not there - that means it is
software error, because all flash functions work till it detects that
has ans error wile charging/loading the flash. Hope it helps.
TENFERRE
Aug 25, 2008 | Sony Cameras
Sony DSC H3 Flash not poping up?
Dear Frac1969,
There are many reasons when flash isn't poping up. Flash selection could be OFF from menu or its setting is Auto. Are you geting any error message in camera when you try to use Flash function?
May 21, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony cyber shot camera 2004
Perhaps you have set the camera to a record mode other than Auto. Twilight mode for example, does not activate flash so as to set the camera on a tripod and shoot dark landscapes.
Check your camera record mode, and use auto or portrait mode, which they usually activate flash when there is not enough light.
Hope this helps.
May 15, 2008 | Sony Cyber-Shot DSC-P92 Digital Camera
E:62:10
Hello, this error message means that there is an melfunction in angular velocity sensor, peripheral cicuits. Simply speaking steady shot function does not work well. Please contact nearest Sony Dealer. Best regards, Arpi
Jun 11, 2007 | Sony Cyber-shot DSC-T10 Digital Camera
Cameras Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
