Screen is darker than normal and most of the images are outlined with blue tint. Sometimes in the corner of the tv the color is normal, but still dark.
Then you have a strange color blue that is outlined on different areas of the tv. It sometimes pops in and out, at the top or the bottom. Very strange look.
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions2001 Philips 43P8341Blue outlines on images - 2c07611.pngrgence chips are bad and should be replaced. This is a common problem.
Solution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen2001 Philips 43P8341Blue outlines on images - 578ba6c.jpgll, red/orange, etc. You may even see halos around images. 2001 Philips 43P8341Blue outlines on images - 65af323.jpg>Picture of a set that needs2001 Philips 43P8341Blue outlines on images - 2c07611.pngchanged.
TV set after fluid change
Solution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Ok I think you need to go with a technician because it is possible that you may have to change the liquids in the ctr,s
