Question about Nikon Cameras
When I view my photographs on my Nikon D50 the white on the photograph pulsates with black where the white areas are on the picture. The photographs itself is perfect but this is annoying. Can you help please?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
You're looking at the blown-out highlights. These are areas where you've lost all detail. Press up/down on the multiselector to change the view. Better yet, reduce the exposure to reduce/eliminate them.
Posted on Dec 30, 2009
When in playback mode, black patches flash on the screen, only in white areas. Actual pictures are not affected once uploaded and printed but its a very annoying problem! Nikon D50
You're seeing blown-out highlights. These are the portions of your picture that have been so overexposed that they've gone pure white, losing all details. This is generally considered a bad thing, but as the camera doesn't know whether you're deliberately going for that effect, it's merely warning you. The proper fix is to reduce exposure (the easiest way is by using exposure compensation) so as to bring back the lost details. This runs the risk of losing details in the shadows as they go pure black, but this generally isn't as bad as losing details in the highlights. We don't expect to see things in the dark, after all.
That was the long answer. The short answer is to repeatedly press up/down on the multiselector to choose a different view of your picture.
Jan 25, 2011 | Nikon D50 Digital Camera
In camera mode the display turns black and white, and so are the pictures taken. No setup changes seem to work. ???
You mean to say whatever photographs you click comes in black and white photograph or nothing at all comes. Go to camera select options select effects and then select normal. If still the photographs are black and white kindly comment back.
Sep 16, 2009 | Sony Ericsson W380i Cellular Phone
MY NIKON D50 SCREEN HAS THE WHITE AREAS OF PICTURES FLASH BLACK AND WHITE
This screen shows areas of the photo that are overexposed slightly.
It flashes them to help you.
You get to this screen by pressing the up or down arrows when displaying the pictures you have taken.
To change it just press the up arrow when the camera is showing the screen until you get a display without flashing.
Once you have done this the display will be steady.
If you get any other screen in future you may have accidently pressed the arrow again.
Just cycle thru the displays to get back to steady.
Jul 21, 2009 | Nikon D50 Digital Camera
When I try to view my pictures on the LCD screen, the white area of the picture flashes. Last week on vacation, it would intermitenly stop taking pictures. I would have to set the lens and camera to...
If this is the same as my Nikon this is the overexposed highlight display option.
This shows areas of the photograph that are overexposed slightly.
On my Nikon I use the up and down arrows on the back to cycle the LCD display options.
Stop when you get a display that does not flash.
As for the focus problem check if you have set the front control to AF not M, also check if the lens is set to A not M.
Jul 06, 2009 | Nikon D80 Digital Camera with 18-135mm...
Blinking black in play mode!!!! PLEASEEEEE HELLLPP
Jul 06, 2009 | Nikon D40 Digital Camera
When viewing pictures on camera why are the white areas of pictures blinking
Jun 30, 2009 | Nikon D40x Digital Camera
How do I set shutter speed to photograph without a flash
You can take the photograps at P mode while keeping the flash off. In this mode the camera will set the speed and the appature according to the available light. This may slow down the speed so make sure you keep the camera stable.
Apr 03, 2009 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon d80 LCD screen
Hello cherdh,
To disable those blinking spots, just press the up or down cursor keys at the back of the camera while in playback mode. You will get three different views. One shows the EXIF data (Image data) as an over lay on your photograph. Press the button again to go to histogram mode, with graphs. Press it again to go to a mode where some image data is on the bottom of the display with no blinkies on the image.
Those blinking black spots are called highlights in a photograph. They indicate the areas where your photograph is over-exposed, i.e. where there is too much light and the colours are washed out. It can be a good tool to get a good exposure. Keep clicking with different settings till you get an exposure without those blinking spots.
I hope this helps.
Satdeep
May 27, 2008 | Nikon D80 Digital Camera with 18-200mm...
Yellow gym pictures
The lighting in the gym was the cause most likely. Try setting the white balance to a different mode
Feb 07, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon d50
the flashing means that the exposure is not correct for that area. if that area was the subject, then you might want to adjust the settings to reduce sensitivity in order to view that area correctly. if you spot meter the 'true subject' in the frame, there will often be areas outside that subject that are either brighter or more dimly lit. but exposure will be right for the subject. it can't all be correctly exposed if there is much variation in lighting. fill flashes will provide more light to the subject, thus resulting in a reduction in sensitivity of the resulting settings. (shorter exposure time or smaller aperture or a combination of both) and that will let the brighter areas move closer to 'not washing out' or being over exposed as some people refer to it. in either approach, its not a defect or problem unless it bothers you. the flashing just lets you know that you can modify settings if it matters that the photograph has high levels of contrast beyond what you may want. sometimes the subject is not in the center, and thus not metered for. but the framing is set to include something off to the side. you can reset exposure by adjusting exposure compensation so that while you are reading a darker area than that of the subject, you don't want the camera to use that area for light settings necessarily.
recap: exposure control via exposure compensation or fill flash
mark
Dec 22, 2007 | Nikon D50 Digital Camera
Cameras Logo
82 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
