Question about Mitsubishi VS-45607 45" Rear Projection Television
REMOVE BROKEN SCREEN
HOW DO I REMOVE THE BROKEN PART OF SCREEN FROM TOP THE MOLDING CLIPS HAVE BEEN REMOVED?
    Genius:
  • 2,920 Answers
Apply a little pressure it should pop loose
Posted on Aug 10, 2008
2006 Tahoe. Where is the auxiliary blower motor located?
It is located behind the right rear quarter panel , In the back right of the interior !
Remove the right rear quarter trim panel. Refer to Rear Quarter Trim Panel Replacement - Right Side in Interior Trim.
Removal Procedure
  1. Remove the rear seat. Refer to Rear Number 2 Seat Replacement or Rear Number 2 50-50 Seat Replacement in Seats.
  2. Remove the Third Pillar trim panel. Refer to Third Pillar Trim Replacement .
  3. Remove the garnish molding. Refer to Body Rear Corner Garnish Molding Replacement .
  4. Remove the door sill plate. Refer to Liftgate Door Sill Plate Replacement .
  5. Remove the quarter panel trim screws.
A lot involved in this but not to difficult !
  1. Remove the rear door sill trim plate. Refer to Front Side Door Sill Plate Replacement or to Rear Side Door Sill Plate Replacement .
  2. Remove the lower rear seat belt cover and bolt.
  3. Remove the trim panel from the vehicle.
Remove the sill plate. Firmly pull the sill plate up and out from the retainers.
Remove the sill plate from the vehicle. Start from the front of the door sill. Use a flat-bladed tool in order to pry the door sill plate.
Rear Side Door Sill Trim Plate Replacement
Use a flat-bladed tool in order to pry the door sill plate. Remove the sill plate from the vehicle.
Remove the rear upper garnish molding. Refer to Rear Upper Garnish Molding Replacement .
Pull down on the upper corners of the garnish molding in order to disengage the retaining clips. Pull in order to disengage the remaining retaining clips. Remove the rear corner garnish molding from the vehicle. Inspect the rear corner garnish molding for broken or missing retaining clips. Replace the retaining clips as needed.
Good Luck ! Fun job !!!!!
Jun 07, 2015 | 2006 Chevrolet Tahoe
Rear window hinge replacement
those moulding are just held by plastic clips you have to yank it out. in proper order in relation to the other mouldings of course
Aug 11, 2013 | 2005 Hyundai Tucson
Screen is black when i attempt to take pic
Move all the pictures to the camera memory card from your internal memory. Since you have to open the camera, the pictures will be lost otherwise. Save your pictures. If you do not have a memory card, transfer all the pictures to your computer.
Remove batteries from the camera.
Purchase a replacement LCD screen, specific to your camera. These replacement screens can usually be purchased directly from Canon or from a camera resale shop. Auction websites should also carry LCD screens specific for these cameras. Use the mini screwdriver to remove the four screws from the back of the camera. Be careful with this step since the screws are tiny. Take the back cover of the camera off carefully. Inside the camera, there is a piece of foam that supports the LCD screen. Do not remove the foam. Set the bottom portion of the camera to the side.
Turn the top portion of the camera so it is facing upward. Notice how there are clips holding the LCD screen in place. Carefully lift these clips up and remove the broken LCD screen. The screen clips are extremely fragile and break easily if they are lifted too quickly. A gentle touch is key.Place the new screen down gently and replace the clips. Gently dust the screen so fingerprints are removed.Turn the top portion of the camera down so the screen is pointing down. Place this on top of the foam padding. Turn the screws carefully. The best way to screw the back of the camera in place is to first screw in one corner, move to the corner that is diagonally across and turn that screw. Repeat for the other two screws.Replace the batteries. Turn the camera on and see if it is function.
Thank you !!
Jun 01, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
How do I pop off the molding to replace outside mirror on 2004 Ford F-250
the molding does not come off the mirror it self pops out if its already broken it is on clips that pop off and it comes out get a flat tipped screw driver put it in the molding just a little behind the mirror and press out for the mirror to force out it has 4 to 5 clips so you go arround all corners poping each one till the mirror is free to come out remove and replace
Apr 03, 2010 | 2004 Ford F250
Replace licence plate bulb 2003 accent hatchback
open boot and locate bulb holder inside boot lid. gently squeeze the clips to release the holder and push out the holder gently. replace bulb, and push holder back in.
Mar 08, 2010 | 2003 Hyundai Accent
Screen stays black
Purchase a replacement LCD screen, specific to a Samsung S860 camera. These replacement screens can usually be purchased directly from Samsung or from a camera resale shop. Auction websites should also carry LCD screens specific for these cameras.
Sep 02, 2009 | Samsung S860 Digital Camera
Laptop lcd
The backlight is either disconneted or has burned out. I would remove the keyboard and molding and replug the display cable. I think it probably just wiggled loose. Just be careful when you remove the molding so nothing gets broken.
If the screen still is not lighting up then you may have to send the laptop in for repair or replace the LCD yourself.
Hope this helps.
Brian
Jul 09, 2009 | Averatec Laptop Keyboard for 3200 Series
Passenger side mirror replacement
you should be able to take it off from the inside of the car directly behind were the mirror is. usually ther eis a molding cover ing the mounting screws . take off the molding , mabey a few screw then some body clips that just snap off. now you should unplug the harness if necessary and remove the three or four bolts that hold the mirror on, and that should be it. hope this helps
Apr 28, 2009 | 1997 Dodge Neon
How to remove the tail lights from a 2003 murano
Here's the step by step procedure from the beginning.
  1. Carefully remove the black one inch wide plastic molding strip that runs along the interior side of the tail light. This can be pried off carefully without breaking the plastic clips that hold it in place.
  2. Using a 10mm socket, remove the two bolts that you see which secure the tail light housing.
  3. The tail light housing is also held in place with three or four plastic clips which can be broken rather easily if you don't do this next step carefully. Begin prying the plastic tail light using a plastic putty knife or screwdriver. The top clip comes out pretty easily and so does the bottom one.
  4. On a cold winter day, the middle clip is the one that can break rather easily so gently rock the tail light or wait for warm weather when the plastic isn't brittle.
  5. Once the tail light "bucket" is removed it's a simple matter to replace the bulbs.
Oct 03, 2008 | 2003 Nissan Murano
REMOVAL OF OLD SCREEN
there should be metal brackets that hold the screen in all the way around the frame. there are usually 2 screws to each bracket..you have to remove all of them to get the screen off
Aug 10, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
32 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
