Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Kenmore S x S 253.5718860 water leak onto floor.
My Kenmore 253.5718860 is leaking onto floor from time to time about two cups of water each time. The Drain pan underneath refrigerator always dry. I cannot find out where water is coming from.
  • Anonymous Nov 25, 2008
    I have same problem, it is a leaking water valve or water valve connection
  • Anonymous Apr 15, 2009
    Me too my Kenmore 253.5718860 is leaking onto floor from time to time about two cups of water each time. The Drain pan underneath refrigerator always dry. I cannot find out where water is coming from somebody please help!
tborn6
  • 700 Answers
SOURCE: so water leaks out onto floor-Jennair side by side
THERE IS A DRAIN LINE HEATER ON MOST UNITS now days, if yours is an older one what you need to do is make sure that it's level, and that the drain line is cleared so that the water has a place to go when it thaws during the defrost cycle.
Posted on Jan 27, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool GD25DF auto defrost drain problem
There is a drain hole in the back of the freezer on the bottom. Get back there with some hot water. Most of the time it is just lime build up. Unless you know what feel back there. Another way is to move the freezer out and from the back side you can see the drain line. It just pulls right off
Posted on Feb 11, 2009
Healeyman
  • 1198 Answers
SOURCE: Whirlpool side by side defrost drain pan overflowing
Maybe your machine has a leaky door, letting moist air inside. Make sure your compressor area is lint free. The heat from the compressor is supposed to evaporate that water. Make sure the pan is exactly in the right place, level, not cracked.
Posted on Apr 25, 2009
  • 123 Answers
SOURCE: Water leak under refrigerator, Frigidaire, FRS6R5ESBC
chk out dis video
http://www.ehow.com/video_112132_fix-leaking-refrigerator.html
Posted on May 14, 2009
bozcro
  • 867 Answers
SOURCE: A small amount of water is leaking out of the
older fridges drained water into a pan with the compressor in it, thus cooling the compressor and evaporating the water, this is located at the bottom back of the fridge. if this fridge has a water and/or ice dispensor, the water could be leaking from many a place.
Posted on Sep 14, 2009
Testimonial: "Thanks, I will check it out and see if I can find the pan. Have had trouble with the ice maker leaking before but this seemed different."
Our Kenmore Elite fridge mod 596.76252702, leaks about a cup of water on floor, 1-2 times a month
The condensate drain that takes the defrost water out of the fridge is blocked.
Pour some warm soapy water down the freezer drain and this may clear it
Apr 04, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water accumulated under crisoer drawers and leaking onto floor.
That water is coming from your freezer during the defrost cycle. Normally there is a drain in your freezer that goes to a cup in your refrigerator and through the back of your refrigerator through a drain tube which extends down to a drip pan. If this tube gets plugged up, water will overflow in the cup and leak at the back wall of your refrigerator and through the holes that lead to the crisper's floor area. If you can remove the cup and using a wire dislodge anything blocking the drain, clean the cup of any debris and check your freezer drain for any obstruction causing water backing up and leaking !
Sep 26, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Water leaking from bottom of machine onto floor during fill and wash cycle
there are 3 bolts are bottom front compartment, may be taken off with a phillip screwdriver, or it may be a torx. when you take it off, cut your washer on and see where it is leaking, your gasket could be broken, your hoses or pump.
Sep 07, 2009 | Kenmore Elite HE4 Electric Dryer
106.55244400 leaking water on floor
Hello, sounds to me like you either have a leak on the nut on the water inlet valve or a pinhole leak on the inlet valve body...have come across this many times before...you may not see the leak from the valve because it is very fine spray but it's there...only real way to detect where it is coming from is to pull the valve out switch water on and see where the leak is....either this or you have a blocked drain tube in the refridge but with the info you supplied i would suggest the valve. If you have any other questions or concerns please feel free to comment again. Good Luck! Mike
Aug 17, 2009 | Refrigerators
Kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
May 31, 2009 | Washing Machines
Water leaking onto floor. no leak found in hot/cold hoses or drainage hose. can this be repaired? is it costly?
is it a top load kenmore,if so the water pump could be leaking or the tub seal,let me know more-mike
Mar 21, 2009 | Kenmore Washing Machines
Kenmore HE3 will not hold water leaks into the pedestal
run you fingers into the door boot and inspect for holes ,, that probably what it is ,,,,,,big tear
Dec 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
168 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
