I purchased printshop 2008, couldn't get it to work, returned it for another and the same thing happened. I get error code 2908. I bought it at staples and can't get my money back. I would appreciate it if you could help me with this. Thanks.
  • 876 Answers
Printshop takes an awful amount of memory. You might get it to work if you uninstall then do a clean install by making sure all other proggys are turned off while you are installing. You also need to clean up your startup programs. To make sure there are not too many all starting up . How many little icons do you have in the lower right hand corner and what are they for?
Posted on Aug 10, 2008
Error code 2908
Driver for which device?
Apr 04, 2014 | Microsoft XP Computers & Internet
Installing print shop 23 on windows 8.1 get framework incompatibility error. what should i do?
I now have PrintShop 23.1 up and running on my Windows 8.1. This is what worked for me:
1. First, RIGHT CLICK on the Printshop icon on your desktop, select Properties, click on Compatibility, and make the selection to run the program in Compatibility Mode for Windows 8. Click Apply, then OK to exit.
2. Double click the Printshop icon on your desk top to open Printshop. If it works - great! However, if it does NOT work, it means the .NET framework required to run the program was uninstalled or corrupted by the Windows 8.1 upgrade and needs to be reinstalled, so please do the following.
3. From your Control Panel, select Programs and Features; in Programs and Features, uninstall Printshop. (You get to the Control Panel by clicking on Settings in your desktop popout taskbar, usually on the right side.) 4. Check to make sure the Microsoft .NET framework is also uninstalled. If not, attempt to uninstall. If you have recently gone to Windows 8.1, it may be partly or fully uninstalled because the 8.1 upgrade might have removed (or damaged) part of it. If it will not uninstall, don't worry! Proceed . . . 5. Follow this step even if you see no sign of the .NET framework in Programs and Features. It is almost certain that you have debris from it on your computer because this is a known problem, and Printshop will not reinstall unless the debris is removed. THEREFORE, clean your computer by using the Microsoft .NET Framework Cleanup Tool found at the following link:
.NET Framework Cleanup Tool http://blogs.msdn.com/b/astebner/archive/2008/08/28/8904493.aspx
6. AFTER Printshop is once again installed, it will very likely NOT RUN unless you follow Step #1, above, to run it in Windows 8 Compatibility Mode.
Dec 20, 2013 | Broderbund The Print Shop 23 Deluxe
Bought new computer. Cannot download my printshop
You might be trying to loading a 32 bit software packege to a 64 bit operating system. See it the store has a 64 bit version. Or you could upgrade the OS with the microsoft pro packege.
Thanks
Feb 20, 2010 | Broderbund Print Shop Deluxe Version 22...
2 months old. bought brand new. and just stopped
These things will happen. You are aware that these appliances have a 12 month warranty so return it to where you purchased it from.
Feb 17, 2010 | Microwave Ovens
I keep getting error message 2908, can you help???? I am trying to install Direct x 9 so I can play Roller Coaster Tycoon 3, but when the installation is about 90 percent complete this exact message comes...
I'd try downloading it from microsoft and see if it works that way, you might even get better results with a newer version of directx.
Microsoft Direct X
Use that link to help you learn more about Direct X, and also find a suitable download for you. A lot of times, on disc copies of Direct X have problems. This may just be one of those cases. Either way, I'd download the newest version you can and install it from there. Every Direct X package has been backwards compatible. So worrying about a newer version being troublesome shouldn't be a problem.
Oct 03, 2008 | ValuSoft 18 Wheels of Steel: American Long...
Logitech video enumerator error on instalation
hi,
when ever I am opening my laptop,insert "Logitech video Enumerator" is coming even through I did not connect any cam to my laptop,even after clicking on the cancel button also window is not going, what should I do now,
Regards
T.rajendar
Jun 03, 2007 | Logitech QuickCam Pro 5000 Webcam
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
