Question about HP Compaq Presario 2200 Notebook
Presario 2200 won't boot up
When I try to start the computer it won't boot. I ran a hard drive scan and it came back with "Test Status: #1- 07 Fail". I don't think that the computer came with a boot disk. Would a boot disk solve this problem? If so, how would I obtain one?
Thank you,
Michelle Plutnicki
  • 477 Answers
Hello
your hard driver is broken or it can be your motherboard sata controller.
sorry
replace your hard drive and run a restore. you can get your restore cds from HP.
check if you have warranty left. then you can go to nearest hp reseller and get your motherboard or hard drive changed for free.
good luck
Posted on Oct 13, 2008
My Hp Pavilion dv9000 laptop will not boot.
You have more patience than I do. I'd load Linux on a flash drive (Mint or Ubuntu MATE are my current favorites) and see how well it ran on those, then install. HPs usually run Linux perfectly. You're not still running Vista, are you?
Most Linuxes come with LibreOffice so you can read and write all Microsoft proprietary formats; you can set it to save in .docx by default.
Apr 06, 2017 | HP Computers & Internet
My compaq presario x-1000 hard drive light and dvd rom light flashes. Won't boot up.
Try disconnecting the harddrive from the case and then place it back in. if that doesn't help you may have a faulty drive, hows warranty? Compaq / HP would fix it for you free if you still have warranty.
let me know.
Thanks,
Ekse
Oct 31, 2008 | Compaq Presario X1000 Notebook
Error code 0142 message error code 2000-0142
My computer did boot up to the desktop, but was completely unresponsive from there when trying to open anything. I ran a system diagnostics and got this error with the status byte of 70. I rebooted into Safe Mode and was then able to open files. I backed up my stuff to a flash drive and then ran Error-Checking in the HD Properties which runs the CHKDSK function the next time the computer is rebooted. That found 2 bad file clusters and repaired them. One was a file called Windows.edb, which does the hard drive search indexing for Windows and was most likely my problem with the lockups. The other was a Napinsp.dll file. After these were fixed and the computer was rebooted, everything worked normally.
This HD is only 9 months old, but if this happens again, I'll replace it again.
Apr 21, 2012 | Dell Inspiron 6400 Notebook
Dell inspiron 1545 Laptop computer is getting BSOD on boot, when first ran diagnostics got error: Hard Drive - DST Test Results - Fail Error Code 2000-0142 Msg Hard Drive 0 - self test unsuccessful status...
The error indicates that there's a hard drive issue. If it just happened after the hard disk is reinstalled, remove it and reinstall it. It could be a problem caused by loose connection or improper connections. If the same problem repeats, install the hard drive on another system (to verify whether it works on another machine or not and to confirm it still works). If it doesn't work on another computer/system then your only option to run the system is replacing the hard disk. If it works on another computer or if it's detected on another system, then there could be problem with the hard disk, eg. Corrupt Partition, Windows Corrupt etc....
First of all, try booting into Safe Mode. You have to press F8 during the startup to go into Advanced Boot Options. Once you are in the Windows Advanced Boot Options, select Safe Mode using the up and down arrow keys on your keyboard. If it still doesn't work, it's the hard disk issue. Try with another Hard Disk.
But if in case you can boot into safe mode, check the Hard Disk for errors. In other words, run Windows Checkdisk utility. Hope this helps.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Oct 10, 2011 | Dell Inspiron 1545 Notebook
HDD problems Test status #2-07 FAIL From COMPAQ Presario 2200
if it still boots try pushing the f8 button during boot until you go into the black screen and see the safe mode and click on safe mode command prompt. then it will ask you which win volume click 1 then your password if you have 1. then you will come to C:\WINDOWS> this is where you type in chkdsk /r
May 29, 2011 | Computers & Internet
Windows xp would not boot up so ran primary hard disk self test and got a test status #2-07 fail. What does this meam and how do I fix the problem
Its a Hardrive Problem you could try taking out the hardisk and cleaning the pins.. and plugg it in..
if that doesnt fix the problem you will have to press F8 While Booting the Bios test, then choose last know config, or save mode with command prompt
then type chkdsk /f and restart your computer.
Feb 21, 2010 | HP Pavilion DV5000t 1.6GHz Core DUO...
Hard drive failure compaq presario 2200
If the bios is showing no ide, means that your ide hard drive is not being detected.
This can be caused by some motherboard failure, some bad cable connection or caddie connection or bad hard drive.
Nov 05, 2008 | HP Compaq Presario 2200 Notebook
SMART error
i think u have to try to RE-install OS
Nov 03, 2007 | HP Compaq Presario v3000z Notebook
HP Compaq Presario 2200 Notebook Logo
183 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
