Question about Mitsubishi VS-45607 45" Rear Projection Television
REMOVAL OF OLD SCREEN
HOW DO I REMOVE OLD SCREEN FROM THE TELEVISION? REMOVED MOLDING CLIPS BUT BROKEN SCREEN LODGED IN THE TOP.
  • 1 more comment
  • MATTED Aug 10, 2008
    DO NOT SEE ANY METAL BRACKETSTHAT HOLD SCREEN ON. OWNER'S GUIDE SHOWS THE SCREEN COMING OUT BY GENTLY PULLING ON SCREEN
    IS A MITSUBISHI DEALER THE ONLY PLACE TO PURCHASE NEW SCREEN?
  • eggert304652 Nov 26, 2008
    hope you can help me, i need to clean the mirror,can you tell me how to remove the screen,step by step. how to remove the molding around the screen.
    thank you,
    scott
Posted on Aug 12, 2008
    Genius:
  • 2,920 Answers
There should be metal brackets that hold the screen in all the way around the frame. there are usually 2 screws to each bracket..you have to remove all of them to get the screen off
Posted on Aug 10, 2008
  • Ronnie Houston Aug 10, 2008
    try applying some pressure to pull the pieces loose.there should be a bit of adhesive holding it in place
    sometimes u can ask a tv repair shop if they can get one but they usually have to order through a dealer as well. each screen is different so i would like to suggest you tale with a repair shop in your area and see if they might not be able to order it for you.
2006 Tahoe. Where is the auxiliary blower motor located?
It is located behind the right rear quarter panel , In the back right of the interior !
Remove the right rear quarter trim panel. Refer to Rear Quarter Trim Panel Replacement - Right Side in Interior Trim.
Removal Procedure
  1. Remove the rear seat. Refer to Rear Number 2 Seat Replacement or Rear Number 2 50-50 Seat Replacement in Seats.
  2. Remove the Third Pillar trim panel. Refer to Third Pillar Trim Replacement .
  3. Remove the garnish molding. Refer to Body Rear Corner Garnish Molding Replacement .
  4. Remove the door sill plate. Refer to Liftgate Door Sill Plate Replacement .
  5. Remove the quarter panel trim screws.
A lot involved in this but not to difficult !
  1. Remove the rear door sill trim plate. Refer to Front Side Door Sill Plate Replacement or to Rear Side Door Sill Plate Replacement .
  2. Remove the lower rear seat belt cover and bolt.
  3. Remove the trim panel from the vehicle.
Remove the sill plate. Firmly pull the sill plate up and out from the retainers.
Remove the sill plate from the vehicle. Start from the front of the door sill. Use a flat-bladed tool in order to pry the door sill plate.
Rear Side Door Sill Trim Plate Replacement
Use a flat-bladed tool in order to pry the door sill plate. Remove the sill plate from the vehicle.
Remove the rear upper garnish molding. Refer to Rear Upper Garnish Molding Replacement .
Pull down on the upper corners of the garnish molding in order to disengage the retaining clips. Pull in order to disengage the remaining retaining clips. Remove the rear corner garnish molding from the vehicle. Inspect the rear corner garnish molding for broken or missing retaining clips. Replace the retaining clips as needed.
Good Luck ! Fun job !!!!!
Jun 07, 2015 | 2006 Chevrolet Tahoe
HOW DO I REMOVE STAINLESS STEEL STRIPS FROM A 1956 FORD FAIRLAINE
Depending on the clip, there were special tools made to release the clip from the molding. The tool slides under the molding and you turn it to release. The clips are usually screwed to the metal surface, or snap into a hole.
Sep 22, 2014 | Ford Fairlane Cars & Trucks
1993 toyota sprinter door removal
Hi Craig, There's a screw which must be removed from the back of the molding. Once that's removed the unit is pushed forward to un-clip from the door frame. When that's completed there's the rod behind it which operates the locking mechanism. A plastic clip holds it and is released by pushing sideways. Regards John
Dec 29, 2013 | 1993 Toyota Corolla
Removal of front bumper 1992 ford taurus
Simple and easy,
Buy the bumper cover new or cheep at junk yard your choice.
How to remove the broken/old bumper by first removing both head lights.
Then remove all plastic clips, yes you can just brake them off there cheep to buy at any auto store.
Then remove all main bolts from the top and underneath.
Then put new bumper on and reverse the steps.
Jul 08, 2012 | 1992 Ford Taurus
Attempting to remove plastic molding around passenger rear vent motor, having difficulty. any help would be appreciated
This is more difficult than it looks because the rear trim panels must be removed in a certain order as they overlap at their edges.
First remove the rear seat.
Remove the step panel from the floor near the side door opening.
Unbolt the 2 seat belt anchors.
Remove the trim panel below the lift gate (rear hatch opening.) Pry the screw plugs out with a small screwdriver and remove the screws.
Pry out the rear speaker grill using a flat blade screwdiver that has been taped to prevent scratches.
Remove the rear speaker mounting screws. Pull the speaker out and unplug the connector.
Remove the passenger side trim panel mounting screws.
Use a panel clip removal tool and pry the clips that hold the trim panel then lift the panel away.
Installation is the reverse of removal.
Apr 07, 2011 | 2002 Honda Odyssey
How do I pop off the molding to replace outside mirror on 2004 Ford F-250
the molding does not come off the mirror it self pops out if its already broken it is on clips that pop off and it comes out get a flat tipped screw driver put it in the molding just a little behind the mirror and press out for the mirror to force out it has 4 to 5 clips so you go arround all corners poping each one till the mirror is free to come out remove and replace
Apr 03, 2010 | 2004 Ford F250
Grill removal
the lower clips are pushed down with a long screw driver from the front , when the grill is removed the clips need to be removed from the vehicle and put in the grill then push the grill in
Apr 18, 2009 | Mitsubishi Pickup Cars & Trucks
Door panel removal
Sorry it took a couple days to post, computer problems I can't fix.
If he has not already taken care of it, here is what should be the case for the door panel.
On the door panel there will be either clips or screws in miscellaneous places, for full removal of this panel, one will need to have the window down on the car. There is a piece of molding that goes across the top back of the door panel that serves as both a guide and a noise reducer for the window. This piece clips the panel into the door itself. There should be a couple of screws around the door handle itself, and a couple on or under the armrest. There is a panel that I believe clips on at the base of the door panel called a kick panel. The keywords here are patience and kid gloves. This panel needs to be removed to access a series of screws that will need to be removed in order to get the door panel off. a flathead screw driver would work for the removal of this item, lightly prying around the edges. There should be two or three screw on either side of the panel as well.
I'm sure there wont be any difficulty for him in finding the screws, but the only thing I can't emphasize enough is patience. When dealing with 10 year old plastic clips, there is an imminent risk of breakage, they are cheap enough to replace, just an avoidable hassle.
Dec 05, 2008 | Cadillac STS Cars & Trucks
Headlights. sensor
You could replace the sensor or try disconnecting the DRL control module .What relay was replaced ? I see no relay on wiring diagrams or in service info. Replacing the Daytime Running Lamp (DRL) Ambient Light Sensor isn't hard . Just take the top dash pad off ,easy .
Removal Procedure
Remove the instrument panel (IP) upper trim. Refer to Instrument Panel Upper Trim Pad Replacement in Instrument Panel, Gages and Console.
Remove the security system LED. Refer to LED Indicator Replacement - Vehicle Security System in Theft Deterrent.
Twist the DRL sensor counterclockwise in order to remove the sensor from the IP upper trim.
Remove the DRL sensor from the wiring harness.
Removal Procedure
Remove the windshield garnish molding. Refer to Windshield Pillar Garnish Molding Replacement in Interior Trim.
Important: Remove the upper trim panel slowly, the retainer clips could possibly fall into the instrument panel.
Lift the instrument panel (IP) upper trim panel approximately 51 mm (2 in) and pull rearward to release the retainers.
Remove the DRL ambient light sensor. Refer to Daytime Running Lamp (DRL) Ambient Light Sensor Replacement in Lighting Systems.
If equipped, remove the sun load sensor.
Pull the windshield garnish molding from the A-pillar in order to disengage the retaining tabs and clips.
Remove the windshield garnish molding from the A-pillar.
Daytime Running Lamps (DRL) Control Module
Left side of the IP
Removal Procedure
Disconnect the battery negative cable. Refer to Battery Negative Cable Disconnection and Connection in Engine Electrical.
Remove the instrument panel insulator. Refer to Instrument Panel Insulator Panel Replacement - Left Side in Instrument Panel, Gages and Console.
Slide the daytime running lamp module from the bracket.
Disconnect the electrical connectors.
Oct 24, 2017 | 2002 Chevrolet Venture Passanger
REMOVE BROKEN SCREEN
apply a little pressure it should pop loose
Aug 10, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
96 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
