Question about Bosch BSA2200UC Bagged Canister Vacuum
Vacuum will not power on...
My Bosch canister vacuum worked fine one minute and then the next it won't turn on....the local vacuum repairman could not figure out what was wrong and had to admit that this vacuum got the better of him...it is an awesome vac when ON!
  • Anonymous Jan 30, 2009
    lower motor wont come on i want to know where the fuse is to replace it> it stopped after a chord got wraped up in th eroller top vacume works
  • 125 Answers
Your repairman missed the thermal fuse in the motor compartment
Posted on Dec 02, 2008
My Bosch vacuum won't start
Check the easy things first. Check your circuit breakers. Will a lamp or another appliance work when plugged into the same outlet? If it is plugged in and you wiggle the cord near the plug and near the vacuum will the motor try to run? This would indicate a faulty plug or cord. If the switch, plug or cord is bad, then you need an appliance repairman. Anything else is highly unusual and would probably require a new vacuum. Best of luck.
Sep 22, 2014 | Bosch BSG71310UC Bagged Canister Vacuum
The powerhead on my Hoover Duros will not keep running. If I push the on/off switch it will come back on sometimes, other times when I push it it turns the whole thing off as its supposed to do.
I just had the same problem with my hoover duros, the vacuum was running fine but the powerhead kept going off. I would make a sweep with it and powerhead would be running and then next sweep powerhead would shut off. I had tried checking connection and belt, etc. I thought it was the powerhead. But then I found the problem. On the duros there are 2 pieces of wands that hook powerhead to hose on canister. They both connected and clicked in fine but I decided to check them separately. I hooked just one piece to hose and powerhead and then turned it on and then I did the other piece. ta-dah! that's what it was...it was only one section of the wand. When I hooked them up separately, one piece the powerhead worked totally fine and vacuumed like normal. When I removed that piece of wand and tried the second piece (actually the bottom section when both are hooked together) the powerhead did not work at all. So I just need to get a new section of wand. Hope this helps!
Nov 17, 2011 | Maytag Hoover Duros S3590 Vacuum...
I can't get replacement bags for my Bosch Premium 1300 W vacuum cleaner.
Greetings from GoVacuum,
Your Bosch Premium canister vacuum cleaner uses Bosch Style P Bags.
We carry 2 different types of Bosch Type G bags for your vacuum cleaner.
We have the genuine Bosch Bags Available for Purchase Here;
Bosch Type P MEGAfilt™ Super TEX Vacuum Cleaner Bags
And also in bulk buy here;
3 Pack Bundle Pack of Bosch Style P Vacuum Cleaner Bags Part #BBZ52AFP2U
And we also carry a generic paper style bag that doesn't filter as well as the cloth Bosch genuine bags, but is suitable if you don't have any breathing issues or allergies in your home. Here are the Bosch generic P bags;
Bosch Type "P" Canister Vacuum Bags Generic
I hope that this information was helpful to you. If this helped you, please be sure to rate this as helpful by clicking the 4 Thumbs Up Icons in the top right hand corner of my answer.
Feel free to email me at chris.jones@govacuum.com if you have any questions or need further help with your Bosch canister vacuum.
Thank you so much,
Chris Jones
GoVacuum.com
Feb 22, 2010 | Bosch BSG81313UC Premium Bagged Canister...
Vacuum will no longer turn on. Vacuum bag was
Same problem. I suppose BOSCH dumped these into the market and have chosen to disown them. Support is pitiful and vacuums have also been taken off their website. Too bad, was a nice quiet product for the 2 months it worked. Solution = new, non-BOSCH vacuum.
Oct 04, 2009 | Bosch 12-Amp Formula Canister Vacuum with...
Henry Turbo head not working
Check the belt. see if its off the roller or if it snapped. Also, their might a reset button on the power nozzle, look for that and hit it.
Aug 24, 2009 | Henry Numatic "" Canister Vacuum
Meile s251i won't turn on
Hi If the power head isn't working it may be clogged. Try taking it apart to see if threads and general dirt has got in at the sides. Also without the power head if the Miele still isn't working then its a possibility that the on switch wiring is either loose or check the plug at the end of the power cord.
Mar 26, 2009 | Miele S251i Plus Bagged Canister Vacuum
Bosch vacuum Motor turns off after a few minutes
It sounds like you have a motor protection fuse that resets after an overheat/cooling cycle.These work the same as a circuit breaker in your house with the difference being they can reset themselves.The Bosch will also shut down if there is insufficient airflow and I would check your filters first.1) Pull the filter and let the machine run.Do not pick up debris when you operate without a filter-it will be drawn straight into the motor.If it runs fine without shutting down, all you need to do is change your filter.If it shuts down again check the external hose for any blockages.Also check the throat from the powerhead for any blockages.If you continue to have the same problem then you will need to replace the fuse because at this point you have eliminated all the other likely problems.Good Luck-Scott
Oct 08, 2008 | Bosch BUC11700UC Cyclone Jet Bagless...
Bosch BSA2200UC Bagged Canister Vacuum Logo
608 people viewed this question
Top Bosch Vacuums Experts
Billy Detlefsen
ray gallant
JoeVacs
Are you a Bosch Vacuum Expert? Answer questions, earn points and help others
