Question about Garmin StreetPilot 7200 GPS Receiver
Answer to micromaster
The gps is functioning perfectly except for the sound
Thanks,
Steve
  • profsteve Aug 16, 2008
    Yes I checked those, as noted in my original posting.
    Steve
    Brigadier General:
  • 3,614 Answers
Did u done checking if the volume control was set to Ozero or the sound MUTE settings was ON..
Let me knw
Posted on Aug 11, 2008
Just acquired a used "Micromaster" scope from
Sounds like you have the wrong bulb installed. This scope requires a 6v-20w halogen bulb. They are available from: Delta Optical Instruments, Inc. email: robin@deltaoi.com
Oct 28, 2010 | Fisher Micromaster I Binocular Microscope
When i hit about 15 mph the system resets everytime then keeps reseting there on after but with out the gps wire in everything works perfectly except the gps of course
The speed sensor wire is to estimate your speed while GPS signals are not availible. You sometimes see problems when that wire is hooked to something it shouldn't be. Double check that connection.
Jun 10, 2010 | Pioneer AVIC-F90BT GPS Receiver
Loosing position on GPS
I hate to be the bearer of bad news, but it sounds like your internal module is on the fritz. I am pretty sure you can buy a external puck and a harness and it will work perfect. I did that with my hummingbird 997.
Apr 29, 2009 | Lowrance Lms 522c 5" Screen Color Internal...
Screen goes blank except for a verticle streak
I had the same problem (blank screen, vertical line). After speaking with Garmin, I was told to make sure I was using the latest software version, and to turn off the WAAS function. Disable it for now, because the WAAS signal, coming from the satellite, has changed, and Garmin has not yet published a remedy to correct this problem. A fix should be out in a software update, sometime in the future, hopefully. I also did the software update, to the latest version 4.0. The unit performs perfectly now, however, the accuracy is not quite as good, due to the lack of WAAS. Good Luck!!
Nov 03, 2008 | Garmin GPSMAP 76S GPS Receiver
GPS sound problem
did u done checking if the volume control was set to Ozero or the sound MUTE settings was ON..
Let me knw
Aug 10, 2008 | Garmin StreetPilot 7200 GPS Receiver
GPS sound
Let me knw
No sound
Try to reinstall the firmware....
Jul 31, 2008 | Magellan RoadMate 700 GPS Receiver
Will not start or turn on
I have had the same problem several times (as well have some friends).
This resolves it EVERYTIME though... at the SAME TIME, hold the BOTTOM LEFT front button AND the Bottom LEFT SIDE button (this reboots it). Then just hit the power button... I am sure you will see that it powers right up.
Jun 07, 2008 | Garmin Edge 305 GPS Receiver
Thumping sound from all speakers
Ever find the cause of this? I have the same problem. Thanks Steve
Jan 21, 2007 | JVC TH-C5 System
Garmin StreetPilot 7200 GPS Receiver Logo
50 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
