Question about ParkerVision Signal Max USB1500 1 Mile USB LAN Adapter, Retail Box (PVLAN)
Windows zero configuration
I have on laptop running perfectly with the slide in card. I am trying to connect a second laptop using the second adapter that I oriinally purchased. When I go to connect, I get a ellow box that comes up and say Windows Zero Configuration was detected. I have disabled this but it still pops up? Any ideas?
  • Anonymous Dec 20, 2008
    hi yha while using my system suddenly wireless gone after that i opened the network connections and i tried for available networks but i got the message like windows zero configuration. After that i tried somany times but i dont know solve this problem. can you please solve my problem.
    Problem Solver:
  • 5 Answers
Uninstall the software, keep the wireless card disconnected, restart the computer, reinstall the software, install the wireless card.
Posted on Dec 29, 2008
D link adapter losing signal
Wireless Zero Configuration is a Windows service on Windows XP and Windows Server 2003 that is used to configure and manage wireless network connections on a wireless adapter. The service name for Wireless Zero Configuration is WZCSVC. On Windows XP, the display name for the WZCSVC service is Wireless Zero Configuration. On Windows Server 2003, the display name for the WZCSVC service is Wireless Configuration.
The Wireless Zero Configuration service is normally started at boot time. The programming interface for the Wireless Zero Configuration service can be used only if the Wireless Zero Configuration service has been started. If the Wireless Zero Configuration service is not started, then the Wireless Zero Configuration functions will return an error.
To enable the Wireless Zero Configuration service so it starts up automatically, go to the Start button. Select the Settings option and then select Control Panel. If you are using the Windows XP view, select the Performance and Maintenance category and then select Administrative Tools. If you are using the Classic View, then select Administrative Tools. Click the Services icon in the left pane. Click the Wireless Zero Configuration icon in the right pane and change the Startup Type dropbox to Automatic. This setting will set the service to start automatically at boot time. Then click the Start button to start the Wireless Zero Wireless Zero Configuration service and click the OK button.
The Wireless Zero Configuration can also be started and stopped from a command prompt. To start the Wireless Zero Configuration, run the following command:
net start wzcsvc
To stop the Wireless Zero Configuration, run the following command:
net stop wzcsvc
Apr 10, 2013 | D-Link Computers & Internet
My Belkin USB 10/100 Ethernet adapter is detecting as a buetooth device when I connect to my laptop... I am using Windows XP as an operating system. I guess WIDCOMM in windows is causing that...
Wireless Zero configuration is a utility that connects your computer to a wireless network.
If Wireless Zero configuration is not enabled, the following message will appear: "Windows cannot configure this wireless connection."
Note: If you have the Belkin utility installed, you'll need to change the Program Choice in the Options tab so the Windows XP Utility is selected.
Setup steps:
  1. Go to the XP Start menu and select Control Panel.
  2. Change the view to Classic View.
  3. Double-click Administrative Tools.
  4. Double-click Services.
  5. Find Wireless Zero Configuration within the Services list.
  6. Right-click Windows Zero Configuration and select Properties.
  7. Select Automatic from the drop-down menu next to Startup type.
  8. Click Apply and restart your computer.
Jun 06, 2011 | Belkin Ethernet Adapter F5D5050 Network...
Cannot get on the internet because of article 871122
This behavior occurs for several reasons. Some computer and hardware manufacturers provide their own configuration software that replaces the Wireless Zero Configuration service that is provided in Windows. In that case, you must use the software that is provided by the manufacturer to configure your wireless network. If you want to use the Wireless Network Setup Wizard or the View Available Wireless Networks feature to configure your wireless device, see the documentation that came with your computer or with your wireless network card. Use this documentation to determine whether you can use the Wireless Zero Configuration service to configure your wireless network. Sometimes, you cannot use the Windows functionality.
If your computer or your wireless network adapter did not come with its own wireless network software, follow these steps:
  1. Click Start, click Run, type ncpa.cpl, and then click OK.
  2. Click Network Connections.
  3. In Network Connections, click to select your wireless connection, and then click Change settings of this connection.
  4. On the Wireless Networks tab, click to select the Use Windows to configure my wireless network settings check box.
To start the Wireless Zero Configuration service, follow these steps:
  1. Click Start, click Run, type %SystemRoot%\system32\services.msc /s, and then clickOK.
  2. Double-click Wireless Zero Configuration.
  3. In the Startup type list, click Automatic, and then click Apply.
  4. In the Service status area, click Start, and then click OK.
Jun 01, 2010 | Toshiba Satellite A105-S4344 Notebook
Unable to use the wireless setup wizard - I am trying to connect my pc with my wireless printer. When I try to use the setup wizard on the pc it says depending on the wireless software installed on this pc...
The Wireless Network Setup Wizard and the View Available Wireless Networks feature both rely on the Wireless Zero Configuration service to provide their functionality to Microsoft Windows XP Service Pack 2 (SP2) and Microsoft Windows XP Table PC Edition 2005. If the Wireless Zero Configuration service is not available, you receive an error message that directs you to this article. This behavior occurs for several reasons. Some computer and hardware manufacturers provide their own configuration software that replaces the Wireless Zero Configuration service that is provided in Windows. In that case, you must use the software that is provided by the manufacturer to configure your wireless network. If you want to use the Wireless Network Setup Wizard or the View Available Wireless Networks feature to configure your wireless device, see the documentation that came with your computer or with your wireless network card. Use this documentation to determine whether you can use the Wireless Zero Configuration service to configure your wireless network. Sometimes, you cannot use the Windows functionality.
  3. In Network Connections, click to select your wireless connection, and then clickChange settings of this connection.
  1. Click Start, click Run, type %SystemRoot%\system32\services.msc /s, and then click OK.
If you receive an error message when you try to start the service, see the "References" section for more troubleshooting information.For more information, click the following article numbers to view the articles in the Microsoft Knowledge Base: 815485 Overview of the Wi-Fi Protected Access (WPA) security update in Windows XP 313242 How to troubleshoot wireless network connections in Windows XP
Feb 26, 2010 | Acer Aspire One PC Notebook
I have hp pavalion dv2000 laptop,it is working good,but just for3 days its wirelless is not working it does not find any network plz give me solution what should i have to do
first of all make sure the wireless key on ur laptop is turned on.
if its on
go to the device manager by
press windows key+r
in the run box type devmgmt.msc
it will open a device manger page
search for network adapters, locate ur wireless adpater under the same
right click, uninstall
reboot the computer and then try, it will work. :):)
DISCLAIMER:- make sure u keep the driver disc of ur laptop handy or create a system restore point just in case the driver doesnt *** bak successfully.
Nov 01, 2009 | Dell Inspiron 5100 Wireless Mini-pci...
Can I get a replacement AMD wireless card
Try this first before you give up...any usb adapter will work by the way....just keep the windows wirless utility as your main wireless software.
Windows WiFi Fix,
Windows Zero Wireless Configuration is one of the best programs to run a WiFi in Windows XP or Vista. Most of the other software packages that come with the different adapters have been poor at best in keeping a connection through Windows. Here is the best guide to get you back up and connected.
Windows XP:
Click Start
Right click on My Computer
When a window pops up click on properties
Click on the Hardware tab
Click Device Manager
Click the [+] next to Network Adapters
Find your wireless card and right click on it.
Click Disable
Windows may warn you that disabling the device may make it stop functioning.
Continue disabling the device.
Wait 30 seconds or so.
Right click on your wireless again and click Enable.
Exit the device manager.
Reconnect to your router.
You should now be able to connect to the internet.
Windows Vista:
Click Start Logo
Right Click Computer
Windows will ask you about opening Device Manager
Sep 28, 2009 | Everex StepNote XT5000T Notebook
Running to slow and wireless not responding
Is the Wireless Zero Configuration service running? To determine if the Wireless Zero Configuration service is running, follow these steps:
  1. Click Start, and then click Run.
  2. In the Open box, type cmd, and then click OK.
  3. Type sc query wzcsvc, and then press ENTER.
  4. If the Windows Zero Configuration service is running, the words "STATE : #RUNNING" will appear.
  5. If the problem is in the user interface, collect a screen shot of the issue, if you can. To collect a screen shot, press ALT+PRINT SCRN.
Basic troubleshootingTo troubleshoot wireless network connections in Windows XP, follow these steps:
  1. Check the Windows Catalog at http://www.windowsmarketplace.com to determine if there is a Windows XP-compatible driver that is available for your wireless adapter.
    • If there is a compatible driver, install the updated driver before you perform any additional troubleshooting procedures.
    • If there is not a compatible driver, you may be able to use the network adapter, but its configuration and functionality may be very limited.
  2. Determine if the driver that you are using recognizes the Windows XP Wireless Zero Configuration service. To do this, follow these steps:
    1. Click Start, and then click Control Panel.
    2. in the right pane,click Network and Internet Connections.
    3. In the right pane, click Network Connections.
    4. Right-click Wireless Network Connection, and then click Properties.
    5. View the available options:
      • If you do not see the Wireless Network Connection icon in the Network Connections folder, or if you cannot view the properties, there is a problem with the driver for the wireless network adapter. To troubleshoot this problem, see the Driver installation issuessection.
      • If you can view the properties for the Wireless Network Connection icon, but you do not see a Wireless Networks tab, see the Drivers that do not support the Wireless Zero Configuration service section to continue troubleshooting.
      • If you can view the properties, and you can see and use the Wireless Networks tab, see the Drivers that support the Wireless Zero Configuration service section to continue troubleshooting.
      • If the Authentication tab is missing in the Wireless Network Connection properties, make sure that the Wireless Zero Configuration service is running.
Aug 14, 2009 | Acer eMachines 520-2890 Notebook
2wire wireless connection
Yes !
Wireless zero configuration service should run.
Go to control panel -> Administrative Tools -> Services, then then locate and double-click on Wireless zero configuration.
Change the Startup type to Automatic, and then click on Start. (Apply and OK).
Also you have to check your Wireless network settings configuration -> Internet Protocol (TCP/IP).
If you are using some utility for wireless connection, disable it and try with Windows (standard) wireless connection.
On the end, it might be useful to compare these above settings with the settings on your another computer and find the differences.
Regards.
Mar 28, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
My aicard is not working with my desktop bur works with laptop
welcome to fixya.com,
ok as u said that it is working fine with the laptop not with the desktop,then what u can try is that reinstall the driver for the aircard and install the aircard utility,and then try and connect,enable the wireless zero configuration of the windows..it sohould connect...good luck
Feb 10, 2009 | Sierra Wireless AirCard 580 (AC580EVDO)
G+ mimo Notebook Card
She probably has both the Mimo Utility and the Windows XP Wireless Configuration Utility running at the same time.. Try disabling the Windows Configuration Utility and see if she can connect now..
Start > Run > Services.msc (OK)
Disable Windows Zero Wireless Configuration
Here is a visual explanation I found:
http://www.ifelix.co.uk/tech/2000.html
Dec 04, 2007 | Belkin High-Speed Mode Wireless G Notebook...
ParkerVision Signal Max USB1500 1 Mile USB LAN Adapter, Retail Box (PVLAN) Logo
73 people viewed this question
Top ParkerVision Computers & Internet Experts
Aris C.
Aris C.
Folusho Adeyanju
Folusho Adeyanju
Larry Maranto
Are you a ParkerVision Computer and Internet Expert? Answer questions, earn points and help others
