Question about Dometic Rooftop RV Air Conditioner
Heater option disappeared
I don't have an option on my thermostat for the heater anymore. It's a Duo-therm model digital thermostat. I used to have the option of A/C, heater, fan and mode off on the thermostat. I don't believe that the thermostat recognizes the heater anymore. I know I have a heater and I've used it before but, when I went camping recently the option wasn't available on the thermostat. Has anyone run into this problem and what might be the fix?
Thanks,
David M.
  • Dometic Master
  • 6,674 Answers
This link may help you identify what you need. What year is your trailer, & AC unit. Have a model # handy ?Have you checked your operators/owners manual ?
http://www.dometic.com/enus/Americas/USA/RV-Products/climate/ac-display-page/?productdataid=66938
Posted on Aug 14, 2008
  • Mike Butler
    Mike Butler Dec 12, 2011
    Sounds like thermostat was changed and furnace wasn't hooked up either, due to wrong thermostat installed. I have a vision of someone grabbing a thermostat to change a faulty one in summer, then realizing it didn't accommodate furnace, but put it in anyway to get AC working. When you take thermostat off wall my guess is you'll find 2 more wires not hooked up, that will be furnace. Thermostat with furnace as same as other will be needed, or a separate thermostat for furnace beside that one, if method of wiring allows.
It is 9 degrees outside and my duo therm furnace is blowing cold air
I hope you have fixed it by now. Probably was the limit switch? don-ohio
Dec 18, 2016 | Heating & Cooling
Need a wiring diagram for duo therm thermostat in a 1994 Kountry Star motorhome
didnt specify model number of stat --can notify domestic they make the duo therm products
dometic com
Aug 31, 2016 | Heating & Cooling
My Duo Therm furnace was working last night and not this morning
I would make sure there is power to the unit before I attempted any repairs. Gas being available will not allow the thermostat or gas valve to operate if there's no power to them
Dec 04, 2013 | Heating & Cooling
Ac comes on when heater is on
board or cable issue between thermostat and board.
Mar 14, 2013 | Dometic 457915 Duo Therm Brisk Air...
What replace Duo Therm Thermostat 3105356.001
Can you attach a picture? Does it look like this one?
Jan 14, 2013 | Dometic Rooftop RV Air Conditioner
Just replaced my digital therm, does the blue wire that was in C for the old therm go into "O", or "B" now? New therm is a Braeburn. Also do I have to reset something at the furnace?
Should go to C terminal. B and O are only used if you have a heat pump system. If you have a voltage tester you should have 24 volts between the wire connected to R and the blue wire (common)
Jan 23, 2011 | Honeywell Programmable Thermostat Heater
I just installed the optional heater on my Dometic
The heater should be in the opening high enough to allow cover to be back on as it was. Please double check your mounting instructions.
May 27, 2010 | Dometic 57915531 Air Conditioner
How many amps does ac draw?
Im taking this is a RV Heater and Air.
Amps 14.7 cooling (at 95 degrees ambient), 12.7 Heating w/optional heat strip
Jan 20, 2009 | Dometic Heating & Cooling
Dometic Rooftop RV Air Conditioner Logo
211 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
