Question about Canon Cameras
Battery door won't close anymore on Canon A630. Is it replaceable?
  • newsdude64 Aug 10, 2008
    I took the door apart (three little screws) and played with the spring that opens and closes the latch on the cover. It still works kind of hard (always has), but at least I can close it now. I'll see how long it lasts.
  • 876 Answers
It is probably replaceable. I had the same problem on one of my cameras and took it into a camera shop. The guy there took some strong tape and taped it closed. He said" It would cost more to replace that little door than the price of a new camera." You could take your camera into a shop and ask them about replacement though. Yours might not be as expensive as mine would have been. You could check your manual also for replacement parts available. it might be something you could install yourself. It is worth a try and if you don't have the manual go to and look for manual downloads. Good luck to you.
Posted on Aug 10, 2008
Camera acts like no batteries, doesn't turn on
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Oct 02, 2011 | Canon PowerShot A630 Digital Camera
I don't know how to open the battery door for the
Slide the latch in the center of the battery cover toward the front of the lens, then flip open the cover. It's hinged toward the center of the body, so it flips open in that direction.
There's an illustration in the "Preparations" section of the Basic manual (page 5 in my copy). If you need manuals, you can download them from
Aug 11, 2011 | Canon PowerShot A630 Digital Camera
My Canon Powershot A630 use to dowload pics onto my Widows Vista but now it won't acknowledge the camera. I tried to find a dowload fix on Canon site but it says that this may not need a driver or is not...
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( ).
Sep 12, 2010 | Canon PowerShot A630 Digital Camera
SD card slot/battery cover broke
Ebay, Canon,,
Dec 25, 2009 | Canon PowerShot SD600 Digital Camera
A630 will not power on. Says batteries are dead.
You have to clean your battery compartment contacts. To do this Dampen a Q-Tip swab with rubbing alcohol and clean the contacts well. Also you'll want to clean the battery and charger contacts as well. Thank you, Dana
Oct 05, 2009 | Canon PowerShot A630 Digital Camera
Lens shutter will not close on my canon a630
If you can't take it apart and clean/repair the broken part, your best bet is to send it off to get repaired. Time & Materials would likely be under $150. If it is still under warranty via the store/Canon/credit card you bought it with, try getting it fixed/replaced via that route.
Aug 10, 2009 | Canon PowerShot A630 Digital Camera
Battery cover not closing
worngly he inserted take it to service centre
Jun 20, 2009 | Canon PowerShot A630 Digital Camera
Remove battery door of Canon A630
This is an old A70, but the way it's done is very similar as I don't think this has changed much over the years. It's a pin design that you have to push out with a stiff unbent paperclip. You push in on the side with the smaller hole. To access the pin you'll need to remove the front and back case covers. See the following:
Jun 19, 2009 | Canon PowerShot A540 Digital Camera
Cameras Logo
116 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
