Question about Refrigerators
Whirlpool ED2GHGXMQ00 Icemaker not ejecting ice
Started with no ice, have isolated at least a broken ejector part where it runs through the plastic gear connected to the motor. I do not know how hot the mold/heater assembly should get but it seems not to be warming and the ejector can't push the ice out.
Any way to test the heater? I've tried checking it through the cycle and it just doesn't seem to warm up enough. Is there a way I can jumper the 4 contacts under the gear and force the heater to cycle by itself?
  • ChipEvans Jan 18, 2009
    The plastic tabs on the ejector that hold the "do not turn manually" are broken and I have a new ejector. What is the orientation of the gear when I install the new ejector?
3 Suggested Answers
SOURCE: Frozen ejector arm
sounds more like the heater in the ice maker is bad. The cycles of the ice maker are: 1. water comes in to fill ice maker. 2. water freezes in ice maker making. 3. heater comes on to help ice release. 4. motor comes on to eject the ice and start all over again. if the heater doesn't come on the ice will not eject. replacing the icemaker is typically what needs to be done in this case.
Posted on Jun 30, 2007
  • 2006 Answers
SOURCE: The icemaker on the KSRB25f keeps jamming. The
Where you say occasionally, I would suspect a rough edge on your stripper arm or a ejector arm slightly out of alignment.
Posted on Jul 18, 2011
Jenn-Air JCD2389GE side-by-side refrigerator ice maker. Numerous problems since purchased in 2002. The latest is flapper door opening and closing repeatedly at two second intervals and water pouring out...
Getting to the more serious water leak problem, it will be likely caused by one of two problems. the first, more common problem, is the solenoid for the icemaker valve is likely stuck open. sometimes particles in the water will literally prevent the solenoid from closing, like jamming a stone between a piston inside an engine cylinder, causing your water to overfill your icemaker, fill up the bucket, and pour through the flapping door that you also have problems with. the second possible problem, is your icemaker itself has stopped, or to be more precise, the motor has ceased up, and it happened to stop at the point in the icemaker cycle when it calls for water. You can check to see if the valve is the problem, by removing the icemaker entirely from the freezer, its held on by 3 screws, or possibly one screw and two metal or plastic clips, also unplug the icemaker from where it connects electrically. Assuming you have the water to fridge turned off presently, turn the water back on, and see if water comes through the fill tube. If it does, the valve is your problem, I suggest replacing both the primary and secondary valves. 12001892, 61005626 are the two part numbers.
If water is not coming out of the fill tube, take a look at your icemaker. Look at the icemaker as it was when mounted, and inspect the center ejector shaft, it runs down the middle top of the icemaker, and has 11 fingers on it, it is what rotates around to eject cubes. Is it in the "home" position, i .e. the position it sits while water freezes. The home position, when looking at the ice maker in its normal orientation, is when the ejector shaft teeth are pointing at 2:00. If the teeth are in any other position, either the ice maker was disconnected during its cycle, or the motor has stopped. To be certain, with the water remaining off, reconnect the ice maker, pour about 8 oz of water in the ice maker, if after 24 hours there is no ice ejected, then you have a bad ice maker. part # D7824706Q
In regards to your flapper door problem. since the path of water went through the door dispenser,its possible you may need to replace electric panel for dispenser. An inconvenient fix is to unplug the connection for the dispenser, located either at the top, under hinge cover, or at the bottom, after removing toe plate.
I fix refrigerators
my website: www.FixMyFridge.net
Mar 08, 2010 | Jenn-Air JCD2389G Side by Side...
Whirlpool ice maker (626662) runs water in and freezes but will not eject ice cubes
Hello there
Here is some things for you to check ok
The motor turns the ejector blades which rotate until they contact the ice. Because the ice is frozen to the mold, it cannot be pushed out and the motor stalls. As the blades continue to press on the ice, the ice mold heater begins heating the mold. Once the ice loosens the ejector motor turns, the mold heater shuts off and the ice is pushed out.
so what i would first do is to check the mold heater to see if it is working
and if this is good than check the motor for the ejector blade and see if it is recieving power if it is have the motor itself checked to see if it is bad ok
I hope that this is very helpful for you there is still a lot more that can be checked but try these first ok
Best regards michael
Oct 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
No ice
I would advance the icemaker by pulling on the ejector blade carefully then the icemaker should start on its own. Then listen for the watervalve to see if it comes on. You might need to change the valve.
Sep 15, 2009 | Whirlpool Refrigerators
Ice maker doesn't turn out the ice/ tray fills with water, and freezes, but doesn't turn out the ice into the door dispenser.
Top 2 possiblities
1/ The motor that ejects the ice is shot.
or
2/ the heater element that melts the ice into pieces.
Here is where you can probably pinpoint problem.
Making Ice When everything is hooked up, the icemaker begins its cycle. The cycle is usually controlled by a simple electrical circuit and a series of switches. In the diagram below, you can see how the icemaker moves through its cycle.
  • At the beginning of the cycle, a timed switch in the circuit briefly sends current to a solenoid water valve. In most designs, the water valve is actually positioned behind the refrigerator, but it is connected to the central circuit via electrical wires. When the circuit sends current down these wires, the charge moves a solenoid (a type of electromagnet), which opens the valve.
  • The valve is only open for about seven seconds; it lets in just enough water to fill the ice mold. The ice mold is a plastic well, with several connected cavities. Typically, these cavities have a curved, half-circle shape. Each of the cavity walls has a small notch in it so each ice cube will be attached to the cube next to it.
  • Once the mold is filled, the machine waits for the water in the mold to freeze. The cooling unit in the refrigerator does the actual work of freezing the water, not the icemaker itself (see How Refrigerators Work for details). The icemaker has a built-in thermostat, which monitors the temperature level of the water in the molds. When the temperature dips to a particular level -- say, 9 degrees Fahrenheit (-13 degrees Celsius) -- the thermostat closes a switch in the electrical circuit (see How Home Thermostats Work for details on this operation).
  • Closing this switch lets electrical current flow through a heating coil underneath the icemaker. As the coil heats up, it warms the bottom of the ice mold, loosening the ice cubes from the mold surface.
-->The icemaker has a heating coil underneath the ice mold.
  • The electrical circuit then activates the icemaker's motor. The motor spins a gear, which rotates another gear attached to a long plastic shaft. The shaft has a series of ejector blades extending out from it. As the blades revolve, they scoop the ice cubes up and out of the mold, pushing them to the front of the icemaker. Since the cubes are connected to one another, they move as a single unit.
  • At the front of the icemaker, there are plastic notches in the housing that match up with the ejector blades. The blades pass through these notches, and the cubes are pushed out to a collection bin underneath the icemaker.
  • The revolving shaft has a notched plastic cam at its base. Just before the cubes are pushed out of the icemaker, the cam catches hold of the shut-off arm, lifting it up. After the cubes are ejected, the arm falls down again. When the arm reaches its lowest resting position, it throws a switch in the circuit, which activates the water valve to begin another cycle. If the arm can't reach its lowest position, because there are stacked-up ice cubes in the way, the cycle is interrupted. This keeps the icemaker from filling your entire freezer with ice; it will only make more cubes when there is room in the collection bin.
This system is effective for making ice at home, but it doesn't produce enough ice for commercial purposes, such as restaurants and self-service hotel ice machines. In the next section, we'll look at a larger, more powerful icemaker design.
Jun 07, 2009 | Kenmore 21.9 cu. ft. Side-By-Side...
Defrosted and now it won't make ice again
If the compressor or fan isnt running. Check your ejector blade in your icemaker.It should be at 12 oclock. If it isnt then remove the cover of the icemaker and turn the smaller gear counter clockwise until the ejector blade gets to the 12 oclock position. This should start the unit.
May 10, 2009 | U-Line Icemaker
Ice maker stopped dropping ice or even making ice.
Try using a hair dryer to thaw out the rubber tubing leading to the ice tray. On mine, I opened up the front door to the icemaker and found the rubber tubing leading in. I squeazed it, it felt frozen, so I applied heat. Water began dripping out, the area thawed, and I had ice again within a short period of time.
Mar 20, 2009 | Whirlpool ED2FHEXN Side by Side...
Whirlpool Ice Maker Won't release ice
Jetguy77,
I have a 1993 year (16 years old now) Whirlpool side-by-side with icemaker, Model ED22PW. I have had similar problems with the icemaker - water goes in, freezes, but ice does not eject from tray. It has happened to this unit 2 times since 1993. It turns out the problem is not the thermostat. It is the icemaker motor module. The icemaker has a small synchronous (clock) motor that rotates the ice ejector. When it goes bad, the ejector does not rotate, either because the module timer had failed or the motor itself has failed. The solution is to go to your nearest applinace parts dealer and by a new "icemaker motor module" for Whirlpool Model (your model here). Mine cost $58.85 the last time I replaced it in 2006. To install the new module, you will need to remove the icemaker from the refrigerator. Mine has 3 screws that attach it to the side. Also unplug the power & control cable. The water tube slides out when you pull the unit forward. When you get it out, it is then easy to remove the motor module and insert the new one. You may have to reset the timer on the module to get the tray to fill completely.
Jan 18, 2009 | Whirlpool GS6NBEXR Side by Side...
Broken ice maker in whirlpool side by side refrig model no.ed2ghgxmq00
1. Check freezer temp. Above 5 degrees? Icemaker will not start. 2. Make sure there is water coming to the refrigerator from the supply line. 3. Is the refrigerator clean underneath? Fan running? Dirty refer bottom can cause high freezer temps, see #1. Ideal freezer temp is -5. Icemaker and valve should be checked by a service tech.
Jun 26, 2008 | Whirlpool ED2FHSS Side by Side...
Icemaker
Look at the ice maker and see what position the ejector bar (white bar with fingers that turns and ejects the ice).  Looking at the ice maker from the front (front is white plastic cover) the ejector bar should be in the 2-3 o'clock position .  If it is not then the module is broken.  In this case the module and ice maker thermostat need to be replaced.  If not sure how to do this repair then just buy a new ice maker.  Let me know what you find and we can go further if necessary.  This is the first thing to check.
Oct 20, 2007 | Kenmore 44109 / 44102 Side by Side...
Frozen ejector arm
May 02, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
123 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
