Hello Dear sir:
i have a D600 latitued laptop . i reinstall is windows now it has win XP
after i install win XP i want to install it sound during of the installing sound driver it massege me device object not present ,restart the system and run setup a gain.
please help to solve this problem
and iam so sorry becuse my english is weak
Download, install, and run Everest Home
Edition on this machine. (Clean FreeWare) Once it's finished loading and
running, look under Multimedia, or, under Multimedia, PCI / PnP Audio. This
will tell you what sound devices you have available on your system.
You cannot downgrade Windows 7 from Windows XP by not reformatting the hard drive. You need to Remove Windows 7 first, before installing Windows XP Operating System. In order to use the Windows XP CD to fully reformat the Hard drive, follow the steps on the link below.
You cannot uninstall Windows XP from your laptop. But you can install it over again if its Windows XP that you want to install again. Restart your computer and press the F8 key. On the next screen select Repair Computer. Follow the instructions. This option lets you re-install Windows XP to your factory condition,
Hello sir, to install window xp and 7 using a kinston pen drive you will to have a software called win to flash. Its a software that allows you to install window 7 and xp from a pen drive and for the sun solaris you also need a software called unetbootin that allows you to install solaris using a pen drive. You can google these softwares to download them for free.
I hope this solution is helpful.
Have a wonderful day.
When it asks for administrator password, and you didn't have one set, just push enter and you'll be able to continue.
If you don't need any information from the computer, use a program to writes zeros to the drive and then you'll be able to install windows. HDD manufacturers provide a program to zero the drive
you have to use a standard windows start up disk with cd rom support like win 98 works well so the computer will recognize a older version then insert it and boot the computer with the operating system that u want to install but be advised if you have a warranty on the machine you will void the waranty i found out the hard way i had xp on my toshiba laptop and i put windows me on it couple of months later i had a cd rom issue and sent it to the manufacture and found out that the waranty was voided because i put a different operating system on the machine
There could be an issue with the user accounts logins. This could be corruption in the OS when you installed it or a clashing driver . I would recommend you reinstall the Operating System with the Disks and before you start installing the drivers try to shut down and see if it shuts down properly . If it does then you know the Operating system and hardware is all fine and can continue installing one driver at a time and shutdown and restarting, continue doing this until you see which driver is causing a confict with your system. I have had a problem similar to this but it was some windows updates pack that I had done one time and had to reinstall windows too and do one by one. Hope my answer gets you closer to a solution.
Dear Sir, Have Dell laptop Inspiron 1525 with Vista loaded....but I need Win XP-2 OS on it...CD of which I have but don't have the laptop drivers compatible with XP. Can you pls guide me how & where to find these drivers....Dell does'nt have those drivers anymore (outdated) Pls...
You cannot uninstall Windows Vista, but you can reinstall your previous operating system, which then replaces Windows Vista. To reinstall your old operating system, you must have the original installation disc. Back up your programs and files, insert the installation disc into your computer, and then reinstall the old operating system. To regain the hard disk space used by Windows Vista, reformat the disk during the reinstallation process. After reinstalling your previous operating system, reinstall your programs and files.
