Question about Dryers
Kenmore gas dryer 970-c91062-00 leaving brown marks on clothes
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: Brown streaks on clothes
mich, The brown streaks are probably caused by worn drum guides and lower basket seal. I've seen this quite often on Frigidaire dryers. Part numbers 5303937139 upper felt guide and 5303283286 lower basket seal. This can be a task for an inexperienced person but can be done. It requires removing the top panel and front panel/door assy. The old guides have to be scraped off. The upper felt guides and lower seal glue on. Catriver...post back.
Posted on Nov 21, 2006
catriver
  • 878 Answers
SOURCE: Brown marks on clothes
This is a pretty common problem with these Frigidaire dryers. Crice hit it right on the head when he said the clothing is getting stuck between the guides and drum. The upper and lower felt guides need to be changed. This is not one of the easiest jobs. The top and front panel have to come off and the guides are glued on with high temp. adhiesive. The old guides have to be scraped off. Part numbers for the upper and lower guides are 5303937139 -(upper) 5303283286 -(lower). Catriver...post back
Posted on Mar 14, 2007
agitateme
  • 88 Answers
SOURCE: Dryer is leaving brown streaks on cotton clothes
The 417 dryers have two seals on the front panel, the top seal has drum glides which wear down over time. Because the drum rests on those glides, when it wears down it leaves a gap between the drum and the seal, clothes will drag in that gap and come out with rust and/or seal adhesive stains. Try replacing the top and lower seals, this works most of the time...sometimes though, if left unattended long enough, the lack of support from the front glides causes too much strain on the rear drum bearing, and even after replacing the seals clothes may still catch, although the brown spotting will stop for awhile. You can feel the gap if you run your hand along the inside of the drum at the seal point.
Posted on Jan 17, 2008
larryyb
  • 291 Answers
SOURCE: Kenmore 70 series dryer leaving brown marks
you can get the parts direct from www3.sears.com and to replace it you pop up the top, take 2 screws out holding front panel onto cabinet and take off, take belt loose from idler and motor and slide drum out ,, go back same way / thanks
Posted on Jan 14, 2009
  • 10865 Answers
SOURCE: My dryer leaves burn marks on the clothes. What
Hi. Thanks for using fixya. I can help you. When clothes get marked or torn in your dryer, check these: Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it. small_8_13.jpg
Posted on Nov 09, 2009
Sears kenmore dryer 970-c69042-00
YOU MUCH REPLACE THE FELT / GLIDES ASSEMBLY PART # 5303937139 THAT IS FOR THE UPPER ONE,THEN YOU CAN REPLACE THE LOWER FELT AT THE SAME TIME THIS IS THE ONE THAT MARKS AND CUT YOUR CLOTHES YOU CAN ASK SEARS PARTS FOR THE NUMBER FOR THIS PART THE LOWER ONE IS ABOUT $18.00 AND THIS WILL FIX YOUR DRAWER. THEY WILL SEND INSTRUCTION SHEET WITH THE PARTS THEN YOU WILL KNOW WHERE TO LOOK FOR IT.
Jan 16, 2012 | Kenmore Washing Machines
Dryer leaves small dart-shaped brown marks on clothes.
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 03, 2011 | Kenmore Dryers
I have a 2006 Whirlpool Duet Electric Dryer that leaves brown marks on my cloths. I have cleaned the inside of the dryer per the manual's diretions, but it still leaves the marks. They almost look like...
Usually, if you are getting brown streaks or marks on clothing, one or both of the drum seals are going bad. Clothing will drag between the bulkhead and the drum, leaving brown marks. If you want to do the repair yourself, I can provide instructions, otherwise call for service.
Dec 30, 2009 | Whirlpool GEW9250 Electric Dryer
Brown marks on my light coloured clothes
I just noticed My Frigidaire doing the same thing. Using a lightly soapy damp cloth, I cleaned the interior, paying particular attention to the small gap between the drum and the housing. I also took apart the lint pre-filter and screen and cleaned them. There was a filmy build up of the same colored substance. I suspect that dryer sheets are leaving a waxy residue that over time is sufficient enough to rub off on lighter colored, primarily synthetic, fabrics.
Jul 11, 2009 | Kenmore Elite HE4 Electric Dryer
Brown marks on the clothes
Yes, the felts are what seals the unit and allows the drum to turn without much heat loss. The felt can become damaged and the clothes will get caught between the drum and the housing leaving these marks.
Apr 09, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer
ck rear (or front if it has one)drum seals they tend to develop rust stains over time the rust comes off on clothes leaving brown streaks ..seals will need to be replaced although you may try a bleach and water solution first drum will need to be removed to replace seals
Nov 03, 2008 | Kenmore Dryers
Kenmore dryer leaving brown burned lines on clothing
the rear drum seal was bad and as things rub against it they will get black marks on them.
Larry
Aug 02, 2008 | Whirlpool GEW9250P Electric Dryer
Brown streak on clothes
It could be from scorching due to getting too hot. This may be the start of a problem for you.
It is best to judge how long clothes need drying for before drying them. If they are left too long, sometimes the heat builds up.
Try a smaller load in there, and if you can reduce the temperature any then do.
Often it's just overloading is the issue.
Hope this is a solution for you, If so, Please rate as Fixya! Thanks.
Jun 18, 2008 | Kenmore Elite HE4 Electric Dryer
Dec 29, 2007 | Kenmore 73952 Gas Dryer
Dryers Logo
94 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
