Question about Garmin StreetPilot 7200 GPS Receiver
GPS sound The gps is functioning perfectly except for the sound Thanks, Steve
    Brigadier General:
  • 3,614 Answers
Did u done checking if the volume control was set to Ozero or the sound MUTE settings was ON..
Let me knw
Posted on Aug 11, 2008
When i hit about 15 mph the system resets everytime then keeps reseting there on after but with out the gps wire in everything works perfectly except the gps of course
The speed sensor wire is to estimate your speed while GPS signals are not availible. You sometimes see problems when that wire is hooked to something it shouldn't be. Double check that connection.
Jun 10, 2010 | Pioneer AVIC-F90BT GPS Receiver
Unit functions but no display
Try this - if it doesn't work you have to send it to Garmin for screen repair.
Now when the screen goes to this - push YES -
May 07, 2010 | Magellan Maestro 4250 GPS
Pin570 using garmin Mobile XT software,GPS not working
Try Start Settings System GPS and tap ON before starting the satnav program. Not all programs automatically switch on the GPS. On hitting ON yellow light top left starts flashing. Now start your satnav program..
Aug 08, 2009 | Navman PiN 570 GPS Receiver
Gps functions
Hi!
Here is a product manual:
787C2 it will tell you how.
You will need a blank sd card inserted into the card reader slot in order to take it to your computer, or you can save it to the internal memory as well.
See page 42 in the manual for step by step instructions.
Hope this helps out!
Mike
Jul 19, 2009 | Humminbird 787c2 Combo GPS Receiver
Loosing position on GPS
I hate to be the bearer of bad news, but it sounds like your internal module is on the fritz. I am pretty sure you can buy a external puck and a harness and it will work perfect. I did that with my hummingbird 997.
Apr 29, 2009 | Lowrance Lms 522c 5" Screen Color Internal...
Screen goes blank except for a verticle streak
I had the same problem (blank screen, vertical line). After speaking with Garmin, I was told to make sure I was using the latest software version, and to turn off the WAAS function. Disable it for now, because the WAAS signal, coming from the satellite, has changed, and Garmin has not yet published a remedy to correct this problem. A fix should be out in a software update, sometime in the future, hopefully. I also did the software update, to the latest version 4.0. The unit performs perfectly now, however, the accuracy is not quite as good, due to the lack of WAAS. Good Luck!!
Nov 03, 2008 | Garmin GPSMAP 76S GPS Receiver
Answer to micromaster
did u done checking if the volume control was set to Ozero or the sound MUTE settings was ON..
Let me knw
Aug 10, 2008 | Garmin StreetPilot 7200 GPS Receiver
GPS sound problem
Let me knw
No sound
Try to reinstall the firmware....
Jul 31, 2008 | Magellan RoadMate 700 GPS Receiver
Garmin StreetPilot 7200 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
