SOURCE: gprs settings
For BSNL South prepaid or post paid use following settings:
Start/ Settings/ Connections /GPRS
Connects to : Internet
Access point: gprssouth.cellone.in
Leave other items blank.
Start/ Settings/ Connections /Proxy
Donot creat any proxy
You donot require any thing else. GPRS will work on your mobile and also in Internet share. Internet share works with cable and bluetooth. Browse on mobile or laptop !!!
9448834529
SOURCE: bsnl gprs settings for htc mobile
if your touch screen work properly,ur problem is align screen.there are three steps if ur ready to keep
SOURCE: I have an HTC dual touch phone P5530 and some one
You will need a needle, a pair of tweezers, and a lot of patience. Pry the micro-SD into a position with the pin where you can grab the edge, then pull it out slowly. If it sticks, don't force it so much as wiggle it until you begin gaining ground. It will feel like you're playing operation, but eventually it will come out. Generally you shouldn't do any damage if your careful, it isn't like a jammed floppy where the metal tab rips the guts of the drive out. the SD slot should be enclosed.
Testimonial: "Thx it helps"
SOURCE: want manual gprs setting for spice, vodafone, bsnl for
call up ur operator and ask for windows mobile GPRS settings.
SOURCE: I don't have the English manual
Hi.
You can get online English manuals for the HTC Touch Dual handsets >>>HERE<<<
I hope this is what you are after? :)
You can easily unlock HTC Touch Pro2. Just insert Invalid Sim card. it will ask you for unlock code. Enter unlock code. Your Locked Touch Pro will be Unlocked and able to accept any GSM Sim card.
You should buy an unlock code from a trusted HTC unlocking service.
Check the recommended link.
