No sound from one of the magnavox speakers? - Audio Players & Recorders
  • 682 Answers
1-check its cable and confirm from good connection.
2-check speaker setup and confirrm that the bad speaker is set to on and has good audio level.
3-check that system is in surround mode.
Posted on Aug 11, 2008
I have a magnavox 32mf605w/17 flat screen TV my sound us not working is there any way to hook up external speakers to it?
Hi Lisa,
Many a times the speakers in flat panel TVs go bad. You either change the speakers or hook your tv to some sound system like a home theater or some music system in your house. There is AV out sockets at the back of the TV. Out of the three ie. yellow, red and white use red and white to connect to the music system, put the system on auxiliary mode and enjoy the sound of your tv. Good luck.
Apr 08, 2015 | Magnavox Televison & Video
Philips magnavox sound just went out?
based on the model number its an older set--check the simple things first---does set have sound when a DVD player is used with the rear inputs? If it does look in menu that speakers are not set now to OFF or set to External speakers(sometimes on rear of set).
Let me know
Nov 07, 2012 | Philips Magnavox 51MP392H Rear Projection...
PHILIPS MAGNAVOX MODEL 19PR15 C122 HAS NO SOUND
Check speaker. Audio circuit. Mute signal
Apr 01, 2010 | Televison & Video
My phillips magnavox big screen tv model number 55p8288 doesnt have any sound when i turn it on
Check the audio setting to make sure the internal speakers aren't turned off. Check to see if it's set to use external speakers. If it is setup to run sound through an av receiver check all connections, make sure the receiver is on the correct input setting, and speaker wires.
Jul 05, 2009 | Philips Magnavox 55P9271 55" Rear...
No sound on Any Speaker
Magnavox would suggest the following as would I
  • Increase the speaker volume
  • Disconnect the headphones
  • Switch on the selected source or select another source
  • Reconnect the speakers
  • Change and play another disc
  • Swap speaker connections
Oct 12, 2008 | Philips Magnavox MRD20037 System
Magnavox 9p6444c102
I had the exact same problem with my Magnavox TV. No sound and no video but the power light was lit.  You can find the solution here.
http://www.magnavoxhelp.com
May 27, 2008 | Philips Magnavox 9P6034C 60" Rear...
Magnavox mwd7006 dvd player hookup
if you are useing componet output and the pic is black and white you have them hooked up in the wrong order
The Cableguy
Oct 17, 2007 | Philips Magnavox MWD7006 DVD Player
Magnavox projection tv hookup to external speakers
The external (audio out) connectors are intended for use with an external amp, not direct speaker connection.
Sep 02, 2017 | Televison & Video
No sound on television
the speaker may not be connected to the board, check the wire. try replacing the speaker.
May 19, 2007 | Philips Magnavox 27MS343S 27" TV
22 people viewed this question
 Grubhead
Grubhead
