Question about Nintendo Wii Console
Need help everytime i put in a disc it says unable to read disc
  • 1 more comment
  • cove road Aug 29, 2008
    It constantly says unable to read the disc and to eject the disc and go to the troubleshooting part of the manual, I don't have it here. Is it broken? Can I reset it??
  • davalynns Aug 30, 2008
    unable to read disc- please eject the disc, turn off the console, and consult the manual- i cleaned all of the discs the way it says- nothing works- it makes a squealing sound when you put a disc in to play- you can hear it spinning and squealing, but it won't work- then the light goes off and it's finished- this happened after i bought the Mario Olympics game and a new controller- the next day, it stopped working on everything!! i can't afford a new one- please help!
  • a1eXh0ng Aug 31, 2008
    I put in a game disc in the wii. When It was finished uploading, It said Unable To Read Disc. I tired this with all my game disc and it has the same problem. Can anyone help me please?
Take the disk out turn it around and put it in.
Posted on Aug 31, 2008
On the wii menu, everytime when I put a game disc in, it would say it is unable to read disc. I tried a different game disc and it said the same thing.
Hello there
From what you have said it sounds like you have the DISK READ ERROR
The main causes are Hardware failure, overheating or wear & tear.
You may need to perform simple maintenance, clean or in some cases adjust settings.
To get the best advice on where to start I recommend a Wii Repair Guide , From this you can fix the problem at home and avoid any large repair bills. Its easier than it sounds when you have help from the guide.
The other solution would be to send the console off to Nintendo, This is free if your still in warranty. If your console is out of warranty then the usual price of repair is $90-$150
Glad I could Help!
Good Luck & Best Regards
Jan 24, 2011 | Nintendo Wii Console
Games disc wont read
the disks might be damaged or scratched or the xbox's disk lens might be dirty, try to get a cleaner disk for an xbox
Sep 02, 2009 | Microsoft Xbox 360 Console
Everytime i insert the disc counter strike the screen shos this message - Unable to read from the disc. Please check if the disc is dirty or damaged.
then try cleaning it or maybe its true that your disc is is dirty or damaged. and to avoid this clone your discs for backup. or try downloading games from pirate bay. download your counter strike there.
Aug 16, 2009 | Microsoft Counter Strike for Xbox
My 360 keeps saying unreadable disk no matter what game i put in
Ok, this is optical lens assembly failure. the lens is burned out and unable to scan due to lens failure. simply replacing the dvd rom optical lens assembly will restore the reading ability of your unit.
May 27, 2009 | Microsoft Xbox 360 Console
Reads "wrong disc" when I insert any disc
Tru cleaning your lens,(pysically) give it a blow ,or similar
May 03, 2009 | Spectroniq PD-1100 DVD Player
Not reading disc
If Wii gives Disc Read Error, First step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives Information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Dec 30, 2008 | Nintendo Wii Console
I got wii fit the disk wont work !!!!!!
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Dec 27, 2008 | Nintendo Wii Console
Unable to read disc
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Jul 05, 2008 | Nintendo Wii Console
Unable to read wii discs
I had the same problem, I take it you have a modded wii(chipped), if you use a backup disc it is of a lower quality then original discs, the wii gets read errors without you noticing and tries to read those disc areas again sometimes suceeding and the gaming goes on, sometimes it fails, and a disc read error occurs. Over time the dvd assembly will take some damage it will loose it rigidity it once had and the wii stops reading discs. The problem gets worse if you have standing up, so first thing si to flip it down and try. Otherwise you (or someone you trust) will have to open the wii and adjust the lens sled so it wont flap as much up and down. Hope this helps..
Oct 01, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
22 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
