Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
Won't Turn On, Power Button Burned Out Maybe ?
Recently, I've noticed that it was getting to be more of a hassle to shutdown and turn on my mp3 player. I would have to press harder and hold the button longer to get the player to turn on and off. Now, I think the power button is shot, cause I can get it to power up and play music if I plug it into my computer first, allow it to connect, and then unplug it. All other buttons work great, it's just the power button (which is a crucial button) that doesn't work. I took it apart to see if I could get to the power button circuitry but the front buttons are sealed via plastic molding and so I was sure of what else I could do. Let me know if anyone has any ideas or thoughts, otherwise it looks like I need a new mp3 player unless I always want to boot it up with a computer and then let the battery die.
  • gr1zzly1 Aug 24, 2008
    my power button is not working on my sansa c250 mp3 player. I have tried using my patch cord and it will get me to my main menus, but the problem still persists - I can't turn it off unless I pop the battery. I can't turn it on unless I plug it into my computer. I have barely used this and am a little disappointed. Help please!
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
Ipod won t turn on
Is the battery dead? Did you notice if the charger works or not? Is there any physical damage, like on the power button?
Wasatch Techies Smartphone Tablet and Computer Repair in Utah
Mar 05, 2014 | Audio Players & Recorders
Tip
TomTom GPS battery discharge when off
With the TomTom GPS units, if you use it infrequently, you may often find the unit has a dead battery when you go to use it.
This is because turning the Tom Tom off normally with the power button doesn't actually turn it off fully, but instead puts it in a standby mode.
Even though the screen is off and it appears to be shut down, it's still using some power to maintain configuration settings.
If you know you won't be using it for a long period of time, you can press the reset button on the bottom of the unit (this can be done while it's off), and it should put it in shutdown mode, where the battery will not be drained so rapidly. If you do this, you can confirm it's in the shutdown mode by tapping the on button. This normally will power up the Tom Tom, but in the shutdown mode, it will not do anything. To wake it up from the shutdown mode, press and hold the power button for a few seconds, at which point it should turn on and greet you with the Tom Tom drums. It takes quite a while to boot up from this mode, which is probably why they defaulted to the suspend mode instead of a true "OFF" state.
For some of the newer units, they've omitted the reset button, so the process is a little different. Instead of pressing the reset button, do the following:
with the unit on, press and hold the power button. The shutdown screen should appear, but continue holding down the power button for another 12 seconds after the screen turns off. Timing is a bit touchy, because if you hold it too long, it'll end up just rebooting, and then you'll have to try again.
If you're successful in the shutdown, you can test it by briefly pressing the power button. It shouldn't turn back on with just a short press. If it comes on with the tap on the power button, you'll have to try again.
This whole process is a bit of a hassle, and extends the turn on time greatly, so you'll want to plan ahead when doing this, and just shut off normally if you expect you'll be using it within a couple days. However, the long boot up is preferable to having a completely dead unit when you need it, especially if you're away from a power plug...
on Jun 30, 2010 | GPS
I have a 2001 ford focus and recently I've noticed
it can be a number of things, 1 is somethings the fuel pump will run hot and shut down ,and maybe transmission issue. is there a check engine on. it sounds like fuel to me.
Nov 05, 2012 | Cars & Trucks
Wii won't turn on.
Reset the AC adapter by following steps below.
1. Unplug the Wii AC adapter at both ends (from the back of the
Wii system and from the wall outlet or power strip).
2. After you've waited a full 2 minutes, plug the AC adapter back in on both ends and check to see if the power light comes on.
Jul 22, 2012 | Nintendo Wii Console
My laptop Hp G60 won't turn on the charger light
Maybe you have disconnected the small cable which connects the power button to the motherboard. Or your charging unit at the back of your laptop is faulty, take the cover off and click the button without it on maybe a alternative. Only other solution would be have you had a powercut recently?
regards,
jon
Apr 21, 2012 | HP Computers & Internet
My area recently had a power failure. Oddly, during the power failure I could still see a light coming from the Canon MG5220 printer. After power was restored, it was sometime later when I noticed that...
Unfortunately, it sounds like when the power was restored, the printer experienced a surge. If this was not plugged into a surge protector, then it's possible the switch was fried at the point of power restoration. It is important that with units such as printers, monitors, towers (computer), tv's, vcr/dvd players, almost any type of electrical appliance be plugged into a surge protector. However, even if this was true in this case - when a power shortage (outage) is experienced, it is necessary to unplug everything so that when the power is restored, nothing that is plugged in will be affected; as your printer was.
Now, you can have this fixed - either take it to a local computer repair shop; that might be able to fix it, or contact the manufacturer and inquire about sending the unit in for repair - regardless of warranty or not. If it is still under warranty, they may honor it. I am not positive they will for an accidental damage such as this, but it's worth calling them.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert, Phone Support, Live Chat @ Fixya.com
Jun 25, 2011 | Canon Pixma MG5220 InkJet Printer
Key locked system shutdown
Turn off the HOLD button on the top of the SANSA Thank you Computerrep
May 01, 2008 | SanDisk Sansa e200 MP3 Player
E270 still won't turn on..hold button is not on...HELP
..Try to connect it to your computer and see if you can access the files, if that doesn't solve it bring it back, they'll hopefully give you a new one or fix it.
Dec 25, 2007 | SanDisk Sansa e270 MP3 Player
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
50 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
