Question about Kenmore 24 in. 15782 / 15784 / 15789 Built-in Dishwasher
665.15782300 Wash cycle fills but then pumps right out to drain. Dishes do not get washed.
catriver
  • 878 Answers
SOURCE: Dishwasher fills w/ water, does not wash, but does drain.
Joel, it's hard to tell whats going on here without the full model number. The number you posted should start with a 665, 363,587 or 464.  Here is a couple of things to look for.  It sounds like you have a seperate drain pump. Remove the bottom toe panel and hopefully there will be a tech sheet behind it.  Check the harness to the motor itself.  You want to verify that there is 120V going to it when the wash motor should be running. If you hear the motor humming and kicking out on the overload, then we can assume you have something stuck in the impeller or the motor is bad itself. The tech sheet will give you a diagram for the hot and nuetral.  Check the float switch inside the tub, it should move freely up and down. This is a safety device to insure the dishwasher does not overfill.  If this is a 665,  there will be a start capacitor on the left side of the wash motor.  If one of the wires came off the cap,  the motor won't run.  Regarding the door switches,  if you have 120V going to the motor during the wash cycle, you can assume the door switches are o.k.   Hope this gets you started in the right direction...Catriver.
Posted on Oct 14, 2007
SOURCE: Bosch SHU43C02UC/47
How to loose up the circulation pump
Posted on Nov 03, 2007
SOURCE: beko dishwasher fills with water, does not wash but will drain the water away
impellor buggered. Needs replacing
Posted on Apr 12, 2008
  • 126 Answers
SOURCE: GE Nautilus GSD4200 Dishwasher will not wash/drain
The average life of a dishwasher is 7-10 years. The symptoms strongly indicate a motor pump problem and my personal opinion is if that is the case youd be better to put the money toward a new dishwasher.
Posted on Dec 30, 2008
  • 744 Answers
SOURCE: Does not pump water during the wash cycle.
It sounds like you are on the right track.
Open the dishwasher, remove the bottom rack, then remove the thumb nut in the middle of the unit that secures the lower wash arm and housing. Look for debris and clear any you find. Try again. If no joy, you will have to repeat the first step and also remove the wash pump upper housing that is secured with torx head screws. Same thing after you remove it - look for debris in the impeller area and remove it.
If you have to remove the wash impeller, you will need a 1" offset box wrench and as I recall a 1/4" socket. The 1" offset box wrench is needed to keep the impeller from turning while you remove the center nut. You will also need to remove the upper discharge line retainer clip to get that out of your way. Inspect the impeller for any debris and especially cracks or missing blades. If the impeller is damaged it will need to be replaced.
While you have this thing apart, check the lower wash arm and upper wash arm discharge pipe assembling for any obstructions.
I am assuming the motor runs ok and the timing cycles seem normal.
Posted on May 03, 2009
My dishlex global300 seems to fill and drain but dosnt pray to wash the dishes.... help, what can i do?
Does it leave water in the bottom after going through the wash cycle?
Jan 28, 2013 | Dishwashers
My dishwasher won't drain. It runs through the whole wash and dry cycle...and when I open it to unload the dishes the bottom is filled with standing water. None of the lines that I can see appear to be...
If you hear the drain pump run after wash and rinse cycles then it is likely the problem is in the kitchen drain end. Have you got a disposal unit in the kitchen sink. Sometime it is full and causing a block.
If you don't hear the drain pump run then the dishwasher may not be getting out of wash cycle and simply timing out. In this case the drain pump could be the problem.
it might help if you provide the make and model of dishwasher and also confirm whether any lights are flashing when cycle is complete.
Feb 01, 2011 | Dishwashers
Doesn't wash dishes properly and leaves some soap powder in holder
water is there enough in there and if so does is syphon out after a while, my guess is the drain goes down thru the floor, not good if it does
Jul 28, 2010 | Kenmore Dishwashers
Kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
Nov 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore disher skips wash cycles.
HI, this is the result of a faulty timer control module. replacing this damaged device will restore the normal functions of this unit.
Jul 17, 2009 | Dishwashers
Smelly dishes from Kenmore Ultra Wash
If you post the model number of your dishwasher plus its approximate age (in years) I can help more.
But the most common cause is a weakening pump motor. On many dishwashers, the wash pump motor is also the drain motor. Replacing that motor / pump assembly will solve the problem. While you are replacing the pump, check the heating element to confirm that it is not shorted out or broken.
For now, add a cap full of bleach to the water _after_ the initial dishwasher fill cycle ends and the wash cycle begins. White vinegar would also work, but this will not fix your problem.
Good Luck!
May 04, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Fills with water and drains will not run to wash dishes
The main water pump is not working. A repair will be pricey. it may be best to get a new dishwasher
Apr 21, 2009 | Dishwashers
Fills but does not wash
Hi!
That happens when for some reason any of the two drain/spin cycles are interrupted. Try this:
have the washer empty, then set the machine to run the last cycle to the end of it, when you usually
lift the cover to take out the clothes, that ought to do it, I had the same problem when diagnosing a
timer problem.
Nov 09, 2008 | Maytag Performa PAV2200
Wash cycle
Check first that the filter located inside the machine (on bottom) is clean. In case it clean - The problem is with the pump. It could be a blockage between pump and the tub, or just a defective pump (The pump takes suction from the tub and forces water up through the spray arms, which spray the dishes. The water then simply drops back into the tub for recirculation). Good luck !!
Jul 01, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore 24 in. 15782 / 15784 / 15789 Built-in Dishwasher Logo
243 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
