Question about Singer Featherweight 132Q Mechanical Sewing Machine
Singer 132q sewing machine
I have a singer 132q but no manual. I have been trying to hem my daughters jeans, however, the thread keeps breaking. I am not sure if I have it threaded properly or if the tension is correct. I would really like to have a manual. If anyone can help me I would greatly appreciate it.
Thank you,
Frustrated
  • 1 more comment
  • mmsavage Aug 21, 2008
    We have exactly the same problem...
    New needle and rethreaded properly
  • tortugafeliz Sep 03, 2008
    I have the same problem...no manual for this machine.
  • Anonymous Mar 13, 2014
    singer 2404 thread keeps breaking
  • 3 Answers
I wanted to turn my daughters old jeans into shorts since they still fit, but were too short. I was having the same problem, but I was able to make some progress. I switched the thread from a poly/cotton blend to 100% polyester and it was a big improvement. I still was unable to stitch through seams. I am going to try a more heavy duty polyester thread and an upholstery needle (18/110).
Posted on Jun 21, 2009
Try this. it's a online manual.
http://www.scribd.com/doc/2384747/Singer-Sewing-Machine-Manual
Posted on Sep 01, 2008
How to adjust the tension?
here is a link for a free manual, the information you need should be in it
http://www.singerco.com/uploads/download/1288_132.pdf
May 20, 2014 | Singer Featherweight 132Q Mechanical...
Sewing jeans hems
You need a couple of things. One is to flatten the seams before you try to sew them. One of the best is to spread the hems on a wooden cutting board or simiilar smooth surface and beat the hems flat with a flat faced hammer. This is an official sewing hammer: http://www.fashion-incubator.com/archive/tools_and_supplies/ and it will compress the fabric so it doesn't lift your presser foot up and let the tension off the top thread (which is what's causing your looping problem).
For crossing thick seams, you need a shim to keep the presser foot flat while sewing. These are usually called hump jumpers or jean-a-majigs, and are a couple of bucks. Or you can use a fold of fabric in the same way: http://www.youtube.com/watch?v=WbYenXIDaDk http://www.youtube.com/watch?v=ZKdW_vIZLBo
Alternatively, you can do the jeans hem alteration that pros will charge you more for (because it's "fashionable"), and it's also faster and easier. Often called Euro-hemming: http://www.sewmuchado.com/2011/06/tutorial-how-to-hem-jeans-and-keep-the-original-hem.html
Feb 03, 2014 | Elna Sewing Machines
Using Juki DDL555, Thread breaks when trying to hem jeans
Sometimes using a larger needle will help. That is if it's shredding the thread when it goes through the needle which causes it to break.
Mar 25, 2013 | Juki MO-644D Mechanical Sewing Machine
I have a Singer Quantum model 9240. Whenever I sew hems on jeans and go over the thickest part of the hem (where the vertical seam of the leg meets) the thread jams underneath, making a jumbled mess. I...
The problem happens when the thickness of the fabric being sewn is uneven. You need to raise the rear of the presser foot so it is even with the front of the foot. There is a little tool called a "hump jumper" or "jean-a-ma-jig" that makes it easy to do. When you get to the hump place the tool at the back of the presser foot and sew slowly. The machine should do the rest and the tool will fall away when it's no longer needed.
Jun 01, 2017 | Singer Sewing Machines
I cut off jeans and turned them up to hem. Following all the directions in the manual, I began to sew, but the thread broke after only a few stitches. My thread is all-purpose thread. I tried tips in...
I turned up my husband's jeans using a size 100 needle. You can get easy thread needles that have a small gap in one side that you slide the thread through. There is a good way to turn up jeans and keep the original hem without having to cut them. Have a look at this site http://www.daciaray.com/?p=38
Aug 25, 2010 | Brother CS6000i Computerized Sewing...
My singer starlet 353 is giving problems. The thread keeps breaking and I have no instruction book.Please advise which settings I should have each control on to do both overstitch and regular stitch for...
Remember that early Singer machines would only sew properly with number 40 or 50 mercerised thread, anything else and all sorts of things happen, top tension should be about 4 or 5
Jan 31, 2010 | Singer 7462 Mechanical Sewing Machine
Bottom thread is loose and loopy
I would use a denim needle, these are blue coated to slide through the fibres, usually in size 100. But the looping is more about the weight of the seam, ie thickness. Also aremyou trying to use thick yellow jeans thread on the outside and normal thread inside? This is difficult to achieve as the thick yellow thread wont go through needle, you need to use it on the bobbin and sew right side down. I have never had much success with jeans hems on my Japanese machine and usually end up using my industrial Singer to do it. You can try usinf a seam jumper Sometimes called a jeans-a-ma-jig, this helps give leaverage to the feed dogs as you approach the side seams. Also, belt the seams flat with a hammer first.
Jan 18, 2010 | Elna Heirloom Edition 6005
The needle thread on my bernina minimatic keeps breaking.
There is special thread for denim/jeans. It usually comes in shades of brown. It's a little heavier and might help with the breakage. You might also want to try a little less tension. I assume you already have a Schmetz denim needle?
Apr 06, 2009 | Bernina Virtuosa 160
Thread breaking during sewing on Ericco sewing machine
replace the needle, use a heavier thread, insure the material is advancing properly as you sew.
Feb 08, 2009 | Singer Sewing Machines
Singer Featherweight 132Q Mechanical Sewing Machine Logo
1,462 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
